the sniper
- Joined
- 4 Sep 2007
- Messages
- 3,498
RBT from 20 mph is only significant re tread brakes, the coefficient of friction between block and wheel, increases slightly at lower speed. Disc brakes are even throughout the speed spectrum; low brakes force gives relatively low retarding force, higher brake force gives superior braking compared to tread brakes.
Regarding the calculation requirement of TDLCR, the gradient component is part of the general calculation. Railway gradients are elongated triangles when viewed in profile; thus 9.81 m/s/s divided by the gradient gives the correction. No need to go off on a tangent, remember: knowledge not a procedure, intuition first.
Braking in the wet does not necessarily increase stopping distance. Wet clean tribometer values range from 0.3 to 0.13 . The latter value will sustain a deceleration of about 1.27 m/s/s; hence modern traction will possess an emergency rate of 1.2 m/s/s, in the wet clean.
Wet dampened leaf has a value of 0.06 to 0.01, average being 0.05, this will mostly accommodate typical step 1or 2 braking. RAIB report Salisbury will surely explain the relationship of friction and stopping, or at least refer the reader to previously released information.
Aside. Just because I refer to psychometric tests as fancy, (elaborate in structure) doesn't mean I fail to appreciate the benefits.
If nothing else, I now finally know what the typical solitary, silent bloke in the messroom is thinking about while he stares into the middle distance.
