LU flood defences
jopsuk
13 May 2008
Not sure about external floods- I know several (all?) of the lines going under the Thames have flood doors in case the river breaks in.
According to a BBC documentary 5 or 6 years ago the vast majority of the LU floodgates are non-operational, having not been maintained since the Thames barrier was completed.
Galvanize
8 Jun 2005
South East london
Apparently, having read about them on other forums:
*The ones on the Jubilee Line at Canning Town (beneath the Thames Barrier esque structure) are the ONLY operational floodgates on LUL.
*The ones on the Bakerloo Line last worked in the late 1990s when the tunnels were strengthened.
*The others are isolated out of use.
Peter Mugridge
8 Apr 2010
Epsom
We must not forget about the various sump pumps throughout the system - it is surprising just how much water there is beneath some of the platforms and tunnels etc, and with several highly publicised long delays to trains in the tunnels caused by power failures in the past couple of years, we must be very thankful that in no instance ( yet! ) has the pumping system failed.....
DavyCrocket
27 Oct 2006
Galvanise is spot on.
The floodgate protection signals are still in use, numbered as such and wired up!
The floodgates used to be tested on a Sunday (I think), until one morning on the Bakerloo, they got stuck!
And indeed an awful lot of water is pumped out.
Simon11
7 Nov 2010
Does that mean the public safety is at risk if the barriers don't work?
oversteer
26 Jan 2011
I thought all those gates were originally to protect against bomb damage in WWII ?
DavyCrocket
27 Oct 2006
Only if the Thames floods in the areas west of the Thames Barrier (until that can't cope in however many years), then yes, you risked being drowned!
I'd be more worried about pumps in stations failing though, having heard about the volume of water that came into Charing Cross from the Trafalgar Square fountain leaks!
Daniel
5 Oct 2005
The one at Canning Town is the only one "operational" AFAIK.
I do have a map showing the projected extent of flooding of the network should the thames barrier fail.
150001
24 Jul 2011
How do the gates go around the rails though? DO they come from above or something. The one at Waterloo on the Bakerloo, how would that actually close?
Thanks!
Peter Mugridge
8 Apr 2010
Epsom
The gates seal off the platforms from the passageways, not the stations from the running tunnels.
Peter Mugridge
8 Apr 2010
Epsom
I've not seen those; only the ones that were ( some still are ) positioned above the platform exits.
Dstock7080
17 Feb 2010
West London
On the District, the tunnel ones are at South Kensington and Embankment.
Where the gates cross/drop to track level a landing plinth is built up to rail level. Yes, a small gap would persist when the gate is fully closed but a negligible amount would flow through.
simple simon
13 Feb 2011
Suburban London
I would wish that they were all fully operational, and that more of the Underground was similarly protected.
I would not be at all surprised if an event occured which required their urgent use 'in anger'. Possibly even later this year, when the comets pass by.
Simon
SS4
30 Jan 2011
What on earth (or not as the case may be :lol:) have comets got to do with LUL flood defences?
All I can imagine is that their gravity will cause movement of water in much the same way the moon affects the tides
It would have to be one ruddy huge comet and pass really close to have much effect upon the tides. I also suspect it would have to coincide with high tide in London and possibly even a storm surge to really give London something to worry about.
Whilst I agree that would seem to be the only reason I'm not convinced that there is actually a danger here...
SS4
30 Jan 2011
Same reasons I'm skeptical.
Dstock7080
17 Feb 2010
West London
We must keep remembering that the UndergrounDs floodgates are for an entirely different reason than tidal flooding.
They were designed to prevent whole-scale flooding of the 'Tube' system after the piercing of the under-river tunnels, in wartime.
simple simon
13 Feb 2011
Suburban London
re: comets and flooding in London, you've obviously not been following Terral03 on youtube, or all the talk about Elenin, YU55, Honda etc.
In theory nothing is expected to impact the planetary surface, but with several of the space bodies passing closely by no-one is 100% sure.
Whilst this is OT the possible ramifications are anything but.
I have been expecting a tidal surge up the Thames and around the sides of the Thames barrier since I was a teenager - in the 1970's.
Rather than give data here I'll just give a link. btw, this link suggests that the big quakes such as Japan earlier in March, the Boxing Day tsunami a few years ago and even Alaska in the 1960's are directly linked to Elenin, and that these big quakes shifted the earth's rotation, changing its climate.
I dont have a link at hand about the solar flares, but from what I've read our government is worried that they will damage the electricity system. All I can say is to investigate the Carrington Effect of 1859, but imagine it happening much more powerfully this time.
Simon
http://alamongordo.com/mysteries/elenin-timeline/
