LU/Elizabeth Line 4G update
announcements
31 Mar 2011
Isn't a shame our updates coming into thread are so bitty wouldn't it be so satisfying to say a whole chunk of line has been completed? We are nearly halfway through the year with very little to say on this matter.
djw1
22 May 2024
West Midlands
Yes it is disappointing but hopefully they’ll rollout a big chunk ready for the main part of the summer. I’ve noticed now on Vodafone (but not EE) that it shows 5G on the Piccadilly platforms at Gloucester Road but it doesn’t actually work yet so I’m guessing they have a few areas that are ready to go.
Recessio
4 Aug 2019
Still no EE signal at Victoria, or the tunnel between Victoria and Pimlico. Otherwise working Vauxhall to Warren Street (at least - that's as far as my commute goes lol)
kacper
27 May 2022
Ee works until halfway up to Highbury and Islington
Recessio
4 Aug 2019
Now getting 5G with EE on the Victoria line platform at Victoria, but not in the northbound tunnel between Pimlico and Victoria station
MTW
1 Apr 2026
This week there is (O2) signal in the Jubilee line tunnels between Finchley Road and Swiss Cottage, both directions. Hopefully they are finally extending towards Westminster.
And now also between Swiss Cottage and St. John's Wood (but not yet at either station).
BJames
27 Jan 2018
My O2 signal generally works between Victoria and about halfway between Kings Cross and Highbury (maybe slightly less than halfway) when going northbound. When going southbound, it kicks in near Kings Cross but doesn't work very well when on the platforms until Oxford Circus.
JonnyM
4 Jun 2022
Morden, Surrey
Edgware Road to Queen's Park on the Bakerloo is live according to TfL.
From looking at the TfL press release they have now reached 60% of tube stations which are 'underground'. So, very slowly edging toward the 100% they say they're going to reach by the end of this year. From reading between the lines, it seems TfL are basing coverage based on actual tube stations, not on whether the signal is live in the tunnel (?).
JonnyM
4 Jun 2022
Morden, Surrey
Ok technical question: what’s the difference between the larger antenna points on the platforms compared to the smaller, circular ones in the ticket halls and circulation areas?
MrJeeves
28 Aug 2015
Burgess Hill
The small ones are just antennas, fed using coaxial cable from a radio located elsewhere. The large ones are an antenna and radio unit combined.
JonnyM
4 Jun 2022
Morden, Surrey
Thanks. is there there more capacity on the larger antenna/radio units compared to the smaller ones? Or is it a non-issue? I've seen the larger ones on the platforms mostly, and the smaller ones in ticket halls and circulating areas. Is there any preference for what goes where?
MrJeeves
28 Aug 2015
Burgess Hill
My understanding is that the small ones all get the same "signal" from one set of radios. So if you're moving around, there is no need for a device to switch between different "cells" within the station to retain connectivity. This presents benefits for everyone, as changing to a different cell requires messages from the network which eat into the available bandwidth for data traffic.
However, as they all share the same broadcast, the capacity is more limited because, while you're in some random corridor connecting two lines, you're also receiving the same radio broadcast intended for someone up in the ticket hall.
While, for the larger units, they will have their own individual cell which they broadcast, which grants higher capacity and better signal quality (there isn't any signal loss or interference between radio and the antenna). They're more important on the platforms since they'll be rather crowded with people, and they have to handle people switching onto those cells while pulling in and back out on a train. If every antenna in the station broadcasted those same messages, you'd lose a lot of data throughput.
There are exceptions. I know Euston has some of the active antenna+radio units in some circulating areas, for example. I don't think I've seen a passive antenna on a platform though. I can only imagine that Boldyn did some traffic modelling, potentially using stats from the WiFi system.
JonnyM
4 Jun 2022
Morden, Surrey
I've noticed the smaller units on the Northern line platforms at Embankment where I was surprised to see them, I thought the larger units would have been fitted here? In contrast, I've seen many of the larger units in the ticket halls of the Northern line stations on the southern section of the line, some several larger units in duplication. I would have expected to see the smaller units here as the ticket halls are quite small (with the possible exception of Tooting Broadway).
Alxxxs
14 Oct 2024
I see that the TFL map was recently updated. From what I can see, they added coverage between Victoria and Pimlico, closed the gap south of Kennington and probably added a few tunnels on Jubilee and District/Circle/H&C lines
Northampton
Also added (since the March 2026 map) -
Bakerloo: Marylebone - Queens Park
Northern: Camden Town - Euston (Bank Branch), South Wimbledon - Morden
Piccadilly: Hyde Park Corner - Knightsbridge.
Jubilee: Swiss Cottage - St John's Wood.
Sub-Surface: Great Portland Street - King's Cross St Pancras International, Farringdon - Moorgate, Monument - Cannon Street, Victoria - Sloane Square, Bayswater - Paddington.
gfa
14 Mar 2023
Would I be right in thinking this bit of the article above means that if you are on a piggyback network e.g. Lebara you are fighting over the remaining 2% of bandwidth?
All four UK operators are live on one shared network, and customers use it in proportion.
Below-ground connections split EE 33%, Three 24%, Vodafone 21%, and O2 20%, with the remaining 2% on MVNOs such as Sky and on international visitors roaming onto UK networks. No other UK mass transit deployment has matched that tenancy mix. London locked it in before the first major post-pilot expansion, with all four networks signed by July 2022 and the Emergency Services Network (ESN) providing a separately funded public service workstream.
I was down in Wood Green on the platforms with disruption the other day, I had no signal and the person next to me had rapid connection so we could check the departure board (the hanging screen wasn't showing any trains).
MrJeeves
28 Aug 2015
Burgess Hill
This seems like nonsense AI slop, quite honestly, and it's very badly worded, and it's probably wrong.
My assumption is that this has been determined by what the phone is reporting its home network as. Most MVNOs will use the same network code as the operator they operate on so won't show in that 2% figure, but Sky is one of the exceptions to that so would be included in the 2%.
It's just trying to break down the network split of users on the TfL 4G system, and not what bandwidth is available or used by which network. So it's saying 2% of users were on one of these rare MVNOs, or tourists roaming on a UK network.
Mojo
7 Aug 2005
Don’t know if anyone else has picked up on this but the signal coverage on the Jubilee line has got worse this week. On Monday there was no signal at all Westminster - Waterloo, since then it hasn’t been available until after departing Westminster whereas previously it was available in the platform.
Class15
30 Dec 2021
North London or Mildmay line
I’ve noticed this too - a far cry from getting Westminster - Finchley Road done!
Recessio
4 Aug 2019
It seems to be getting worse on the Victoria line too, around Oxford Circus and Green Park I noticed my signal (EE MVNO) collapsing
martin2345uk
21 Sep 2011
Essex
Can someone remind me... if there is 4G coverage in the tunnel for, say, EE, does that mean all MVNO's using EE will also have signal?
