LT1967 Stock Screenshots
The Snap
10 Jun 2005
The train is nearing completion - I am not giving anything away yet, but it has that extra touch to make you love it... ;)
28 Jan 2007
A6-EHF
Ive just read this , wonder what the touch is...., loooks niceee!:D.
T
Tom
Guest
Well if it didn't have it, it wouldn't be realistic. Besides I normally can quite easily look it up ;)
The Snap
10 Jun 2005
This screeny will give it away if you no where to look...compare it to the other similar one above. ;)
The Snap
10 Jun 2005
If Mr Cairns has noticed what I hope he's noticed, then he is correct!
Upon closer inspection, you'll notice the deamans (large red button) is pressed in in the first 3 screenies. On the 4th, it is not.
http://www.trainweb.org/tubeprune/67 TS Orig Cab Photos.htm , and scroll to Figure 2 - read the info on the right of the picture. ;)
And Kelvin, the door buttons remain the same, so are the two to the left of the deadmans.
Turbostar
15 Aug 2006
Plymouth, Devon
So basically, it's going to be as realistic as possible, hence you have to hold the button for the train to run, release & it stops, as in normal practice?
Mart
5872
28 Jan 2007
A6-EHF
Oh yes!:D. An ATO LUL train , any route for it? or will it use the route from where 'bay park' is from???.
*1 Post away from a 1000*
The Snap
10 Jun 2005
Mart
The plugin doesn't allow that unfortunalty. But, the cab image for both manual and ATO versions have been adjusted to show the deadmans pushed either in or out.
