jfuller595@gma
As a lorry driver, I've found bridge height signs frustrating at times. Plenty of bridges are far from the displayed height but I've had to use themJust wonder why some bridge height signs are advisory (triangle) and some circular (set out the law). A long time ago I was given to understand that an (over) bridge strike is an absolute offence (i.e. no defence) but does the sign being advisory alter that?
Presumably, if you drive a (say) 13' 4" vehicle under a bridge with 13' 3" in a circle, an offence is committed even if the vehicle does not make contacts with the bridge (because of the tolerance in the sign for e.g. resurfacing)
Your suggestion is one that, as far as I'm aware, hasn't been considered so I'll mention it next time I contact NR. Thank youIn this example, the Triangle advises you of the upcoming hazard/restriction before you get to the actual prohibition (the sign on the bridge is circular).
I've seen it mentioned on here before - so may not be totally accurate - that flat deck bridges are prohibitions because the signed height is continuous across the road but arch bridges should be advisory because the signed height is taken at a particular section and specific vehicles taller than the signed height may be able to pass safely under the bridge. I'm sure there will be counter examples of both.
Regarding the OP's question - I take it from the photographs there is a watercourse behind the road that prevents a widening of the angle of the road junction? In this case I would explore the installation of priority chicane gates. Relatively cheap to install and self-enforcing. Widely used to good effect in many villages that suffer from being a sharp bend on a fast road. Closure of the underpass to motor traffic will increase the risk on the crossing itself which NR won't sanction paying for the upgrades as you've pointed out, while modification to the road junctions is unfeasible given the apparent constraints of the site and if the council refuse to sanction direct enforcement then an "engineering enforcement" would appear to be the only reasonable option left. Something like this: https://rosehillhighways.com/traffic-calming-chicanes/ (other manufacturers are available)
