London Underground Driving
2 Sep 2013
Just a curiosity prompted thread, I know LUL Drivers usually have years as Station Assistants before they can progress to driving.
However, anyone know what the tests are like, are they the same as TOC's?, would someone who lost both their lives still be eligible for Tube Driving?
Tubeboy
9 May 2009
You can sit the tests as much as you like on LU. Tests are understanding instructions, interpreting technical information, fault finding and a concentration test.
Daniel
5 Oct 2005
Lots of new drivers nowadays have had months not years as CSA's. LU have also been direct recruiting train operators externally, though exclusively from the military at the moment I believe.
Met Driver
8 Jun 2005
Dead end job everything will be going ATO.
GO MAINLINE
Depends what you mean by dead end! I agree that anyone who wants a career as a train driver would do better to look at trainee driver positions with a TOC. I have been a driver at LU since 2008 and even in that short time things have changed a great deal with training for new candidates almost cut in half, withdrawal of several types of 'proper' train which really did have to be 'driven', and introduction of replacements which have simplified defect handling. ATO on more lines is an inevitability but in what form this will be is still the subject of speculation and there are questions of how to tackle the issue of interoperability on Network Rail sections, and LU sections over which TOCs run services. Although things don't look particularly rosy in the long-term, there is still a lot that needs to happen between now and then, and in the mean time there is certainly no sign of LU needing less drivers; quite the opposite in fact.
As I've said on here before, unless the new TOC assessments are vastly different (I have not sat them, only the old ones), then a period serving as a Train Operator at LU provides masses of relevant experience for obvious reasons. Although, should anyone use it as a stepping stone, they'd be well advised not to get too accustomed to the salary!
In terms of forging a career in railway operations, not necessarily limited to train driving, LU offers masses of opportunities ranging from operational management to positions in signalling/service control, and to those with relevant professional qualifications, a vast number of other areas from engineering to IT. Many of these openings are only open to internal candidates.
In a nutshell, if you want to drive trains for the rest of your life, only consider LU as a stepping stone (if at all) on the way to a mainline career. If you fancy giving driving a go and then moving on but sticking with railways, LU has a lot to offer.
Aivilo
15 Jan 2014
Was a driver from 06 to 11 and thought I would leave while I still had youth on my side and start fresh.
Although giving me experiences to have good competencies for applications and interviews that's where it stopped.
The driving part is not recognised at all anywhere (to my knowledge) if you want to get on the underground, then stay on the underground.
If you have aspirations to drive on the mainline make that your focus because you will have to take a massive cut in salary (initially) and start from the bottom again.
