London: travelcard or oyster?
28 Feb 2017
Hi all,
Sorry if this is a frequent question but I've not seen it before. I live near Cholsey and go into London reasonably often on the weekend. With a network railcard, an off-peak day return to London is £15.05 and an all zones day travelcard is £17.95. I always buy the travelcard even if I don't have any particular plans to use the Tube because, I thought, I'd only have to make one or two Tube or bus journeys on contactless to wipe out the savings of not getting it.
But I just learnt that you can load a network railcard onto an oyster card. If I do this, will the off-peak fare capping kick in and limit my oyster spending to £2.90? That seems too good to be true!
Cheers
clagmonster
8 Jun 2005
Network Railcards can not be loaded onto an Oyster card. Only Young Persons, Senior, Forces and Disabled railcards are eligible for Oyster discounts.
CyrusWuff
20 May 2013
It's not permitted to put a Network Railcard discount onto an Oyster card due to the £13 minimum fare that applies on Mondays to Fridays.
Whilst there is nothing physically preventing the discount from being set (as most railcards, except the Disabled Persons one, use the same discount type), it could potentially result in criminal charges being brought if caught.
28 Feb 2017
Damn that's unfortunate, I did read that it could but it seems that was mistaken. So we're stuck with paper tickets?
28 Feb 2017
No doubt. It wouldn't really be physical but IT based anyway, right? It's not like they are punch cards :D
MikeWh
15 Jun 2010
Crayford
... and annual gold cards (which get the same Oyster discount code as the other not disabled ones).
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Even if you could add the railcard to your Oyster, and even if you only travelled within Zones 1-2, the cap would still be £4.35 (source: http://content.tfl.gov.uk/railcard-fares.pdf). Whereas with the Travelcard from Cholsey you can have unlimited travel within Zones 1-6 for only £2.90 extra (the railcard-discounted Oyster cap for Zones 1-6 would be £7.90!). Out-boundary Off-Peak Travelcards really are great value since the huge increases in Off-Peak caps (and in-boundary Travelcard prices) brought in by Boris Johnson in January 2015.
28 Feb 2017
That's interesting, thanks. Are there any cases you know of where it's cheaper to buy a ticket from outside London, even when starting within London?
Hadders
27 Apr 2011
Yes, if using Groupsave. For example an Off Peak Zones 1-6 Travelcard is £12.30 or £36.90 if three people are travelling. An Epsom - London Zones 1-6 (route Southern only) for 3 people is £24.30.
Groupsave is not available on travelcards starting within the Zones.
28 Feb 2017
Nice! If on the weekend, it's cheaper to buy a zone 1-6 day travelcard with a network railcard isn't it?
