London Travel card - Yate help please.
Class707SE
2 Aug 2025
Hi, I am travelling tomorrow from London to Yate and need to take the 05:23 from London Paddington - Filton Abbey Wood before changing onto a service from there to Yate.
I was looking for a travelcard ticket so that I could use the bus to get to Paddington, but I couldn't find anything, so maybe I should just use Oyster.
Please let me know if there is anything I'm missing or if I should just get split ticket advances.
Thanks in advance.
Starmill
18 May 2012
Bolton
The bus is only £1.75 on its own so the advances are going to cost less. Try www.trainsplit.com.
Technically a Yate - London Zones 1-6 Day Travelcard is available but it's almost £300.
Peter Mugridge
8 Apr 2010
Oakham
He's outwards TO Yate in the morning, though, so if he did this he'd not be able to get back to the zones on the same ticket would he?
05:23 is a service via Bath, and there is a 5 minute connection at Filton Abbey Wood.
If it helps can use GWR Bristol area PAYG, from Swindon to Yate, if you had the smart card it would have been £15.20 for peak single on PAYG. But you wouldn't be able to touch in at Swindon.
The Anytime single fare for Swindon to Yate is £29.10 (Per PAYG fare tables for non smart card holders) So consider splitting your tickets
Class707SE
2 Aug 2025
I bought an advance to Filton for £25 and will do PAYG for the remainder of the journey. I think that's probably easiest.
Starmill
18 May 2012
Bolton
I don't think a return journey was needed, but indeed you're quite correct.
Have you got a compatible card for the Bristol pay as you go area?
Class707SE
2 Aug 2025
Yes, with my Railcard on it as well.
