London to Reading Off Peak
96tommy
18 May 2010
Travelling from paddington to Reading in the rush hour time tomorrow evening (5-6), does anybody know what trains around this time are off peak? I seem to remember that some were peak at this time but don't know which ones?
Thank You
Tommy
Quakkerillo
23 Jan 2015
As I understood it from my experience on this forum, it's not per train, or per time. Your ticket will determine whether or not a train is peak or off-peak, as some off-peak tickets can be valid at 'peak-time'.
So if you could tell what type of ticket & price you hold, I 'm sure someone will be able to give you clear information.
If you want a look yourself, you can start at http://www.brfares.com/#!fares?orig=PAD&dest=RDG and select the approrpirate ticket and read all restrictions below it.
bb21
Emeritus Moderator
4 Feb 2010
What ticket do you have, in which direction?
me123
9 Jul 2007
I'm quite surprised that this is the case, but there are indeed Off-Peak fares from London in this time frame!
Assuming you're going out on an Off Peak Day Single or Off Peak Return (Day or otherwise, either portion), you can apparently catch the following trains from Paddington for travel to Reading.
17:06 to Westbury
17:18 to Oxford
17:24 to Banbury
17:36 to Oxford
17:57 to Reading (*Overtaken by a later train that allows Off-Peak ticket holder to travel)
18:05 to Frome
18:18 to Oxford
This is confirmed by VTEC website and the BR Fares website (Restriction Code 5K is in force).
As above, it would be worth confirming which ticket you hold to clarify which of these services are definitely valid for you.
96tommy
18 May 2010
Thank you all, not bought a ticket yet but just looking at an off peak day return with 16-25 as it is £17 cheaper tHan the anytime day return of £30
maniacmartin
Fares Advisor
15 May 2012
Croydon
GWR are the exception though, because the restriction codes on tickets they price out of London do refer to specific trains. As a rule of thumb (that you shouldn't rely on), the uncomfy stopping Turbos are allowed but longer-distance HSTs are not.
maniacmartin
Fares Advisor
15 May 2012
Croydon
Check out the left hand column of this page on BRFares then, which will tell you everything you need to know for the J9 restriction code that applies to the £12.35 London Terminals to Reading Off-Peak Day Return [CDR] with 16-25 discount
Quakkerillo
23 Jan 2015
I see I sort of muddled what I meant with a slight contradiction in both halves of my sentence. I meant to say it's not necessarily a certain train/destination (i.e. Paddington - Oxford), nor always a specific time (in case of a slow and fast train departing simultaneously), but that it is decided on a specific train at a specific time (to a specific destination).
After a member's frequent encounters with a certain validity code at Paddington, I've learnt a lot about the system here! I just worded it a bit vague.
96tommy
18 May 2010
The following trains which your ticket is valid on should be operated by HST's
17:06 to Westbury
17:36 to Oxford
18:05 to Frome
That's grand! Only done this journey after 20:00 before so expecting these to be jam packed especially being a few of the only off peak fares.
FenMan
13 Oct 2011
All trains to Reading in the evening peak are jam-packed! :)
cactustwirly
10 Apr 2013
From experience the 1706 is probably the best (its not too busy, about 75% full)
