London to Glasgow Non-Stop
Bertie the bus
15 Aug 2014
It's not about how fast that train was or how fast this one is, - ultimately it's about how fast available modes can get passengers from where they start mtheir journey to where it ends. On a city centre to city centre trip, a sub-4 hour train time beats many of the sub hour flights when all the niff naff hassle of security, baggage and to & from airport journeys are added in. Of course not true for all those whose origins/estinations are a 10 minute bus ride from the terminal. In the more environmentally considerate future, changes are more likely to have negatibe impacts on flying than surface travel.
It isn't about that at all. I would put good money on there never being a non-stop London - Glasgow service and certainly not a public train that does it in 4 hours (pre-HS2). You are desperately trying to attach significance to something which doesn't exist.
Ianno87
3 May 2015
I don't get this argument for having different records for different sets of infrastructure - at the end of the day the APT still holds the record for the fastest run between Euston and Glasgow down the WCML. It still beats yesterdays run by 21 seconds and that is all that counts.
The same reason you don't have the same 100m World Record in Athletics for the hurdles as you do without the hurdles.
Grumpy Git
13 Oct 2019
Sorry, but that's a very poor analogy.
Maybe comparing one set on a cinder track v a modern surface is better?
AM9
13 May 2014
St Albans
You have no idea what I am 'trying to attach significance to' so don't waste your time trying to infer that.
I wasn't even talking specifically about non-stop services. As has been said elsewhere, when full ERTMS is launched on key parts of the route, speeds will increase and paths will be cleaner and end to end times improved, (with suitable stops). Even without HS2, the exercise this week was a valuable lesson in managing traffic around a key path.
I can't remember if there was a Glasgow equivalent, but there was certainly an Edinburgh-Euston service which was nominally non-stop, during the 2010 ash-cloud crisis.
Virgin Trains put it on because aircraft were not allowed to fly for several days.
There were also other special runs, eg Holyhead-Euston, because everybody went for the ferries instead of flights from Dublin.
Unique conditions, but it did happen.
Record times not on the agenda, of course.
dk1
2 Oct 2009
East Anglia
Just as I was travelling St.Pancras-Marseille & return. I’d always planned to travel throughout by rail but so many others hadn’t. So exciting to see how well operators like Virgin grasped the opportunity & ensured the media knew about it.
Mcr Warrior
8 Jan 2009
At the end of the day, APT never achieved practicality, whereas Pendolinos do it every day.
Have to say that four-and-a-half hours on regularly timetabled London Euston - Glasgow Central runs in public service, including stops en route, is still quite impressive on a day in, day out basis.
Could this ever regularly be reduced to four hours, end-to-end, but still with some intermediate calls? :?:
dk1
2 Oct 2009
East Anglia
Especially as it’s hourly. I think people have short memories with frequency on the full length of the WCML.
Three hours 53 Minutes from London to Glasgow ....o_O
Just to put it into perspective..
Wonder what the record is for an Embraer E190 as it regularly completes the journey in well under an Hour
Forget HST ...HSA is already here :E
I’d like to see an Embraer do Euston Road to Gordon St in under an hour.
Efini92
14 Dec 2016
The APT had two 20mph TSRs, two 50mph TSRs, a 65mph TSR, a signal stop of two minutes and nine seconds, and ran on infrastructure in the Rugby and Crewe areas that demanded much lower speeds than the 390 was limited to. By @Railperf’s admission the 390 was ten minutes up at Crewe, so on today’s infrastructure there’s no reason why an APT would not be that much up too and be well ahead of a 390 into Glasgow.
So the numbers suggest the APT has the moral upper hand in terms of performance as well as the record. The real improvement over the APT will come with HS2, not an artificially enhanced run over exiting metals. Avanti had its chance, gave it a great go, and it didn’t quite work. To me it now feels a bit like someone sometime in future trying to beat the Mallard’s steam record - not quite right - and the west coast record should belong to APT. So I hope it’s left alone now and not tried again.
Didn’t the APT also run at speeds far greater than the permissible speed? I believe at one point it was upto 140mph.
Ianno87
3 May 2015
Yes. It's called HS2.
Yep. Wasn't very many years ago that the regular timing was well in excess of 5 hours.
jfollows
26 Feb 2011
Wilmslow
I calculated earlier in the thread ( #318 ) that with calls at Preston and Carlisle only, 17 minutes would be saved by omitting Warrington, Wigan, Lancaster & Oxenholme (from a service which called at these places and omitted Penrith anyway). You'd end up at about 4h12m for a service calling at Preston and Carlisle.
EDIT But you have to work out the demand for services from the omitted stations, and how to cater for it with other services if it's significant.
And there used to be a service (1S82 16:30 Euston to Glasgow) in 4h8m with only one call (Preston) in the recent past (extract below from the December 2014 working timetable). 1S82 had 9 minutes of additional time added to the schedule for normal recovery reasons and had no additional pathing time in its schedule, so its net running time was 3h59m but it couldn't have been timetabled without the extra time.
jfollows
26 Feb 2011
Wilmslow
1974 electrification introduced a 5 hour "headline" timing, but there weren't many services and many of them took longer:
1M18 07:10 Glasgow to Euston 12:29 5h19m
1M25 07:15 Glasgow to Euston via GSW 14:03 6h48m
1M05 09:10 Glasgow to Euston 14:29 5h19m
1M30 11:10 Glasgow to Euston 16:28 5h18m
1M19 13:10 FO, dated Glasgow to Euston 18:18 5h8m
1M35 14:10 Glasgow to Euston 19:17 5h7m
1M46 16:10 Glasgow to Euston 21:26 5h16m
1M52 17:30 Glasgow to Euston 22:37 5h7m
I expect there was a 5h schedule in the down direction, I don't have the timetable for Glasgow arrivals in 1974. Although there was a hourly xx.45 down departure "slot" it wasn't used every hour.
It's only been recently that there's been an hourly service, but that will presumably rely on traffic from intermediate stops, certainly in my experience the trains are relatively empty north of Preston.
EDIT GSW - Glasgow & South Western, via Kilmarnock and Dumfries. The 15:45 down service used this route also, diesel-hauled between Carlisle and Glasgow of course.
BrianW
22 Mar 2017
IIRC it took quite some time before the 'powers that be' were convinced about electrifying north of Weaver Junction, let alone into Scotland. While speed, frequency, regularity, reliability, comfort etc may produce more business it's never going to be possible or worthwhile to do everything. The planners if not the politicians do their best to manage a reasonable balance.
And while 'here' congrats to all involved in the 'failed' 'worthless' record attempt- it's good to see the good feeling generated, overcoming my tendency to grumpyoldgitness.
Time to do something to help government show the 'rightness' of relocating this and that to Leeds and Darlington while not ignoring the needs of Welwyn (and Uxbridge?)?
Scotrail314209
1 Feb 2017
Edinburgh
I swear in the regular WTT that the 17:30 is still 5 hours long.
Shows how far things have actually come on some services.
jfollows
26 Feb 2011
Wilmslow
Today 1M18 17:30 Glasgow to Euston arrives 22:27, 4h57m
Probably stops more than 1M52 did in 1974 .... Carlisle, Preston and Watford Junction
EDIT: 1M18 today calls additionally at Lockerbie, Penrith, Oxenholme, Lancaster, Wigan, Warrington, Crewe, Rugby, Milton Keynes Central but not Watford Junction
Robertj21a
22 Sep 2013
If they got just 21 seconds behind the record while respecting a maximum of 125mph and all of the speed restrictions, it does beg the question of if they managed to get an exception to safely run a bit beyond 125 and none of the restrictions were present, how much more time could they shave off the record.
Why bother, what does it really achieve?
So not for over a decade (or even more) then?
Or ever ?
HarryL
14 Sep 2020
What do any of these speed record attempts achieve to be fair. Some money raised for charity, a day out for those onboard, a bit of PR sprinkled in and the company can lay claim to beating the previous are basically the goals of any of these attempts. Doesn't achieve much ultimately but is some fun to do if the opportunity arises.
Ianno87
3 May 2015
You could say this about pretty much anything humanity does, as we cling to our rock hurtling through space in our finite lives.
alf
1 Mar 2021
Bournemouth
Or ever ?
It gave me, & 2 friends I discussed it with, pleasure in following its progress & in thinking about it after.
Manutd1999
21 Feb 2021
I guess the 'ideal' solution would be to have 1x fast and 1x semi-fast Euston-Glasgow each hour. This is similar to what LNER offers from Edinburgh to Kings Cross.
The issue is where to find the paths...... If you assume the Birmingham-Scotland service continues in some form (even if it doesn't start at Euston), then you need to find 1x extra path north of Crewe to enable 2ph Euston-Glasgow.
Ianno87
3 May 2015
Well, the Euston-Birmingham-Scotland service effectively is the semi-fast.
The alternative would be truncating the Euston-Birmingham service at Preston or Blackpool to give a path for a second Euston-Glasgow service.
dk1
2 Oct 2009
East Anglia
Exactly. It’s all good fun with some PR thrown in for good measure. The likes of Virgin where absolute masters at this sort of thing. I miss them very much.
Railperf
30 Oct 2017
Because the average speed of the PLM doesn't even compare to what the WCML can do today, particularly south of Crewe. A much harder bar to improve on.
Yes, the PLM is limited to 160 km/h and French schedules include a standard recovery time of 3.5 min or 4.5 min per 100km (62 miles).
The geography also helped the new LGV route, as Paris-Lyon is 75km shorter than the old PLM route via Dijon.
HS2 will not be significantly shorter to any destination than today's lines.
