bcarmicle
- Joined
- 11 May 2018
- Messages
- 409
I will be travelling from London to Ebbw Vale, then to Cardiff, and then back to London in a day. However, depending on the timings, to get from Ebbw Vale to Cardiff, it it might be necessary to go via Newport.
If I buy a return ticket from London to Ebbw Vale, that is valid via Cardiff, so I can go London -> Newport -> Ebbw Vale, then Ebbw Vale -> Cardiff direct, and then Cardiff -> London on the way back.
If i need to go Ebbw Vale -> Newport -> Cardiff, and then Cardiff -> London, I think I would need to buy a Ebbw Vale to Cardiff single on the day to make my journey valid. That's reasonably cheap, so I'm not too fussed about it; I just want to check that that's right and that no one sees an obviously better way to do the tickets? (I'm quite keen to retain flexibility so am not too interested in doing splits).
Incidentally, while I was looking at the Routeing Guide, I don't obviously see why London to Ebbw Vale is valid without going via Cardiff, given that Cardiff is the only destination routeing point for the Ebbw Vale stations (Newport isn't, for some reason). Is there an easement I've missed? Having thought about it some more, it is presumably the shortest route rule that validates not-via-Cardiff.
