London to Crawley and return
Talent
17 Aug 2013
Dear all,
is there a cheaper possibility to get from Central London to Crawley and back than 17.60 (on a saturday, same day return)? Oyster PAYG is available.
An Off Peak Day Return (CDR) from Coulsdon South [CDS] to Crawley is £9.40. In fact, the fare is no cheaper than from Croydon Stations, so you may as well get that for convenience!
So yes, slightly cheaper, assuming "central London" is Victoria, or London Bridge, or anywhere else with a National Rail only fare to Croydon.
greatkingrat
20 Jan 2011
7.50 Super Off Peak Day Return London Bridge - Gatwick (Thameslink only) (also available from any station up to St Pancras)
3.80 Off Peak Day Return Gatwick - Crawley
Total 11.30
radamfi
29 Oct 2009
If Three Bridges is good enough then you can get a Super Off Peak Return from London St Pancras to Three Bridges for £8, route "not Underground". You could use this from stations between St Pancras and London Bridge. That's better than getting it from, say, Blackfriars, as the route would be "Thameslink Only".
A Three Bridges to Crawley Off Peak Return is £2.90, but you can walk that in about 20 minutes if you want to save money.
Talent
17 Aug 2013
As I have to go to Crawley Town FC Three Bridges is too far I reckon.
Isn't there a bus between the ground and Three Bridges? There certainly used to be! It used the ridiculous guided busway which some people are fooled into thinking is like having a tram system.
radamfi
29 Oct 2009
In that case you could get a St Pancras to Gatwick ticket, then Gatwick Plusbus for £3.70. Bus 10 goes direct from Gatwick to the stadium every 6 minutes, as well as bus 20 every 20 minutes. Route 20 also goes via Three Bridges. Three Bridges Plusbus is also £3.70.
James Wake
30 Aug 2013
Please do not call the Fastway ridiculous, since those new Volvos came in, staff and passengers seem a lot happier, I really like the new buses :) good suggestion from radamfi, I would come down to Three Bridges then get the 20 to the ground, then just board whatever you can coming back, and go to Gatwick or Three Bridges as required.
RJ
25 Jun 2005
Back office
Dear all,
You could buy a Super Off Peak Day Return from any of the following stations to Crawley (or Three Bridges) for £12.00. It'd give you freedom over which train you take from Central London to Crawley. They're all routed Any Permitted and include a Cross London journey on the Underground.
Code:
Blackhorse Road
Caledonian Road
Camden Road
Cricklewood
Crouch Hill
Elstree & Bhwood
Finchley Rd & F
Gospel Oak
Hampstead Heath
Harringay Grn La
Hendon
Kentish Town
Kentish Town W
Leyton Mid Rd
Leytonstone H Rd
Mill Hill Bway
South Tottenham
Upper Holloway
W Hampstead Stns
Walthamstow Q Rd
Wanstead Park
Woodgrange Park
