London Overground special (via unusual route)
Domk
21 May 2019
Hi
I know in pre LO days th3 5:30am on Saturdays from Liverpool Street to Enfield Town went via South Tottenham. Is this still the case?
Hi
It is still scheduled that way.
https://www.realtimetrains.co.uk/service/gb-nr:Y21909/2022-06-04/detailed
However, that doesn't mean it will always use that route. In particular, it has been retimed to go via Stamford Hill on the last two weeks.
https://www.realtimetrains.co.uk/service/gb-nr:Y21909/2022-05-21/detailed
https://www.realtimetrains.co.uk/service/gb-nr:Y21909/2022-05-28/detailed
Taunton
1 Aug 2013
I never got why this link was electrified. Notably when the Goblin was electrified a few years ago it was all dismantled, then reinstated new.
JBuchananGB
30 Jan 2017
Southport
I believe this is an example of a "parliamentary" service which runs once a week to maintain the Tottenham South Curve as a line open for passenger services. It is then available if needed for diversions.
SargeNpton
19 Nov 2018
Also helps to retain train crew route knowledge.
nanstallon
18 Dec 2015
I must 'do' this trip. Can you buy a ticket for Liverpool Street to Seven Sisters? Or perhaps more sensible to just buy a day travelcard, which presumably on Saturdays is valid at that time of the day.
Malaxa
9 Mar 2022
Not much freight (if any this way now is there?
Certainly not with electric traction. Last year London Gateway to Leeds container trains were diverted over this route for a short time. A planned Harlow Mill empty wagon return to the new aggregate terminal at Tilbury2 has been in the system for some time using this path, but has never run so far.
You would do it using Oyster / Contactless PAYG unless you intended to travel for the rest of the day.
Malaxa
9 Mar 2022
I suggest the purchase of a reliable alarm clock beforehand. Ticketing is much less of a problem. Best enjoyed in the summer.
Freightmaster
Verified Rep
7 Jul 2009
One of the two Broxbourne-based RHTTs also uses the link on a daily basis from October to December.
MARK
Yes, as it's a direct train between the two (it's also within 3 miles of the shortest route). A Day Travelcard would be the most sensible option if you will be doing lots of 'bashing' that day and don't want to worry about maximum journey times and resultant maximum fares, otherwise Oyster/contactless will be the cheapest option.
