ISTR a OPO shorter version is being ordered for such routes, it is shorter by one window bay in the rear section.
Wikipedia has spoken, with its usual mix of half-truths and fabrication. Only 2 LTs were involved in the accident on routes 24 and 148, plus a non-LT on the 211. This is stated even though the photos clearly show an LT on the 11 embedded in the LT in front. The four routes running the length of Victoria Street are (unusually) operated by four different companies, so there is no chance of a blind having been rewound to disguise the facts. Doh!
Then the LT is even less fit-for-purpose than I'd assumed.Still, no need to worry about emergency exits when they crash, as they have almost as many as they do seats.
Do they actually have any more accidents than any other type of bus?:roll:
You're probably right, because it can be extremely difficult to replicate a defect, especially if it has only happened once in many miles. I had a jammed accelerator linkage on an Audi, many years ago while joining a motorway from the slip road. I realized there was a problem when I took my foot off the pedal but the car carried on gaining speed. I switched the engine off, stopped and freed the offending linkage and continued my journey.The old 'accelerator jammed/brakes failed' chestnut! I'll wager that no such defect will be found!
I never had it happen again on that car, so I guess if there'd been a crash, people might have made the same 'old chestnut' comment, but that doesn't mean it didn't happen. It was quite interesting watching the speedo go through 60, 70, 80 and keep rising, and of course, even when I pressed the brake pedal, it made hardly any difference.
I agree, at least I hope they are......You would like to think that drivers of big, expensive buses with lots of people on would be adequately trained in all aspects of its control, including how to stop the thing if for whatever reason the normal method becomes impossible. I'd have thought handbrake/master switch etc etc would be an immediate consideration.
