London connection time query
Contactless is fine for local journeys but anything long distance is best e-ticketed where practical, for the whole journey.
Eventually e-tickets will work for cross London transfers, and that will make it easier. You then get one PDF document for the whole journey, with one page per ticket.
Hadders
27 Apr 2011
This is a large part of the reason why I may come across as anti-contactless at times. When contactless wasn't available, people starting their journey at Maidenhead would have booked their tickets from their origin to their destination and been better off for it.
I don't think this is a contactless thing as such, more that people don't realise that through tickets are available (which is a shame because through ticketing was one of the protections at Privatisation) . For example, someone travelling from Maidenhead to York will search for tickets from London to York with LNER often because they don't realise they can actually buy a through ticket from Maidenhead. To be fair train companies don't help by not offering through &connections Advance tickets on many routes.
MarlowDonkey
4 Apr 2013
When you have a Railcard, contactless should perhaps be avoided because it doesn't apply. That said and talking specifically about Maidenhead does contactless give additional rights to use the fast services during the evening peaks? Restriction codes on evening departures from Paddington specifically exclude the services that are non-stop to Slough or Maidenhead.
redreni
24 Sep 2010
Slade Green
Yeah, that's true, although not relevant to any of the journeys I'm talking about as they'd almost always be on Saturdays. (If going to a weekday game it'd invariably be an overnighter). Contactless also has the benefit that you can double back at Reading if you want (although with the change a year or so ago to the regular Didcot Parkway train with the calling pattern Slough, Maidenhead... the double back at Reading is rarely quickest these days).
If the outward and return portions are on different days then contactless will often be the cheaper option, but you still have to factor in the headaches not having a ticket could cause. In that case booking a through ticket for the outbound and just an Advance single to the relevant London Terminal for the return can often make sense, using contactless for the last segment returning to Maidenhead.
