Locos with noses - why?
BRX
20 Oct 2008
All those loco designs with "noses" - 37s, Deltics, etc...
Why were they made that way - is there a particular reason? Surely setting the cab back from the front like that just obscures the view for the driver...is there some benefit that I haven't thought of?
theageofthetra
27 May 2012
Beckenham
I have wondered about that too. The US still builds locos like that (as do their truck manufacturers). In the case of trucks the max overall vehicle length is huge is the US wheras in Europe the length is much shorter- so the cab and tractor need to be a small a part of the overall length to maximise freight capacity. Wonder if the same applies with European trains?
TimG
26 Jul 2014
Could be to absorb impact of deer etc?
krus_aragon
10 Jun 2009
North Wales
The view was significantly better than that over the boiler of the steam engines that were being built a decade before.
The Crab
7 Apr 2011
I recall two reasons being put forward:
The nose would give some protection to the crew in a collision, and,
The nose would reduce "sleeper flicker" as the crew could not see the track close to the locomotive. I can't quite remember who put this forward or why he thought it a problem (a hypnotic effect?) but I think it was a steam design man possibly E S Cox.
lincolnshire
12 Jun 2011
It must help in the case of collision as it like your car bonnet been in front of you. It has to be remembered that they did have equipment inside too, like a an EE type 3 (class 37) it had the traction motor blowers inside as well as the compressors, exhausters etc in there and in the case of some of the class which was built with the equivalent of corridor connection between two loco,s of the same class for the fireman to pass from one loco to the other while on the move.
D60
16 Feb 2015
Did one or two classes built for long-distance expresses, ie EE Type 4 and Deltic classes, have a handy toilet in there as well? Or did I dream that up..!?
Ash Bridge
17 Mar 2014
Stockport
Not sure about Deltics, but I think there was a urinal located somewhere in the engine room of a class 40.
Jamesb1974
20 Mar 2006
I'm not old enough to remember the original quote but I am old enough to remember the article in 'Rail Enthusiast' (as it was at the time) about the class 60 being designed. I recall that there were two cab front designs, one of them being raked forwards in a similar style to the French electric locos (BB class??) in order to reduce 'sleeper flicker'. It sounds like the reasoning for having a nose on early diesels could be partially due to this and partially due to the styling of the time. Borrowed American influences and all that??
Boothby97
24 Apr 2011
Cleethorpes
I'm sure there was a loo in one end of a Deltic. I recall being sat in the cab of 55002 at NRM Railfest (back in 2012) and there was a bloke in the cab involved with the loco, who I'm sure made reference to there being a loo in the nose???
spongsdad
17 Sep 2013
Were not certain such smokebox-door fitments trialled on express steam locomotives of "The Big Four" at one time very many years ago.
I think you may be thinking of the inspection shelters which were from time to time affixed to the front end of steam locomotives when they were undertaking accurate performance testing "out on the road". So far as I know, they were usually of timber construction and were fitted with two "spectacle" windows at the upper corners. The purpose of them was to allow a couple of guys to measure as accurately as possible, front end performance of the locomotive, by means of instrumentation temporarily fixed to for example, the smokebox.
From the photos they always looked rather flimsy; I certainly wouldn't have fancied riding there as "front-end Charlie" though I guess that it would have been more exciting than any contemporary amusement park ride.
Ash Bridge
17 Mar 2014
Stockport
Yes, it appears you're spot on, was reading on rmweb that the 55s had a toilet & washing facilities in the No.2 end nose, similar to what table38 mentioned about class 40s.
Xenophon PCDGS
17 Apr 2011
No, these items to which I referred to were metallic aerodynamic artifacts that "streamlined" the area of the smokebox door. I am sure that I recalled one of the better Great Western Railway locomotives having its outline aesthetically ruined by this trial.
However, I am aware of the inspection shelters to which you make reference and I think that O.S.Nock wrote quite an interesting article about them.
spongsdad
17 Sep 2013
Ah, I see. I too recollect seeing photos of, I think, a Churchward engine, either a 'King' or a 'Castle'. The smokebox had a rounded front and there was even some "streamlining"/fairing of elongated triangular shape behind the, chimney and the safety valve cover. Period was the mid 1920s, I think. It looked pretty gross, too.
In fact, I've just come across this link:http://www.greatwestern.org.uk/loco_draw.htm The loco WAS a King and if you look down the list that this link opens, you'll find a drawing.
sprinterguy
4 Mar 2010
Macclesfield
5005 "Manorbier Castle" and 6014 "King Edward VII" were pseudo-steamlined by the Great Western Railway during the mid-thirties in a half-hearted attempt to keep up with the much publicised streamlined efforts of the LNER and LMS.
The streamlining features were gradually removed after only a short period of time, and the two locos so treated have little to no relevance to this thread as the effect was purely aesthetic and served no practical purpose.
spongsdad
17 Sep 2013
Well thanks for that! I will consider myself suitably rebuked for going off topic.
But then the title of the thread is Locos with noses-why?. Maybe I'm not off topic after all.
sprinterguy
4 Mar 2010
Macclesfield
I wouldn't consider it a rebuke as I have also provided additional material in answer to the query from Paul Sidorczuk; but from the opening post it seems reasonably clear that the original query was regarding the practical purpose of the noses fitted to modernisation plan diesels, rather than the "bullet" noses fitted to a couple of GWR express engines.
Taunton
1 Aug 2013
Noses on diesels have been pretty universal on US railroads precisely to give collision protection to the crew, which trains over there are far more susceptible to than in Britain. Any major loco works on the US trunk carriers will generally have one or more units in with a smashed front nose from level crossing collisions, landslides, or whatever.
The Road Switcher type, long typical, had the cab at about the 80% mark, short hood in front and long hood behind. Some of the old major companies, Norfolk & Western, and Southern, used to run their diesels until quite recent times what appeared to be "backwards, with the longer hood leading ("long hood forward"), and the controls in the cab turned round to suit, precisely for collision protection.
In Britain the greatest exponent of noses was English Electric (Deltics, Class 37/40, etc), who had a considerable export experience to Africa etc where unguarded level crossings, washouts, etc, were even more prevalent, let alone occasional experiences of the locomotive being charged by a rhinocerous (dented bodywork) or a bull elephant (derailment not unknown). Seeing one of those coming at speed towards you in the headlight at night, you would be very glad that the EE draughtsman back at Strand Road, Preston, had seen fit to put the cab back behind a nose of steel framing.
I'm not aware that a rhinocerous has had a go at a Deltic yet!
The Crab
7 Apr 2011
To correct my previous comment, it was H G Ivatt CME of the LMS who insisted that the LMS 1600hp diesel electric of the LMS built 1947/48 had noses. Roland Bond, who was involved in the BR pilot dieselisation designs, agreed adding a third reason -"They looked better".
I understand that when the designs changed to flat fronted the windows were made relatively small for the same reason. Do modern units have shallow windows?
3141
1 Apr 2012
Whitchurch, Hampshire
I think that's likely: the LMS diesels 10000 and 10001 (and I think 10100 as well) had these "noses" in the American style.
But the Southern diesels didn't have them.
The idea of "sleeper flicker" is interesting, but the AC electric locos classes 81-87 put the crew right at the front, without a protective nose, and they were among the fastest locos of their time and would have suffered from flicker if it was really a problem.
