Loconundrum
8ace
25 Dec 2019
Brighton
I think I've had Kings Cross to Euston as a 10 minute walk. The way it handles cross London transfers messes my thinking up, as Tube journeys aren't indicated as such until after the puzzle is solved (or you've used up all your guesses) and for some transfers the tube isn't used at all. The first time it sent me up the ECML from Huddersfield it confused me, as it insists on doing the Wakefield shuffle instead of just changing at Leeds.
I've avoided London starters because of how confusing the routings can be if the target station is accessed via another London terminal... but maybe it is worth a try!
Living where I do means that I have to go via London to get anyway not local so I'm familiar with the routes/times from the big smoke's many termini.
61653 HTAFC
18 Dec 2012
It's the newer routes that throw a spanner in the works for me- I might get routed via Crossrail, but I have to keep reminding myself that it exists... I haven't even got used to Thameslink or HS2, so a routing to a station in East Anglia will throw me off if it wants me to change at Kings Cross/St Pancras and Stratford International, and then walk through Westfield to Stratford!
Without giving any spoilers today's puzzle threw me a curveball too, one of my guesses was a station in a town with two stations- I'm pretty sure you can get a train to the target station from either in reality, but the game still insisted I walk to the other one!
8ace
25 Dec 2019
Brighton
Ah yes that 2 min walk, that cropped fairly recently so luckily I remembered. The one that nearly threw me the other day was Hereford - it chose to route via Newport from PAD!
Royston Vasey
14 May 2008
Cambridge
Yesterday my new starting station paid off again...
1. ELY
2. BLY!
Today... I got cloae geographically quite quickly but I don't know that area anywhere near well enough, and it's a lot more obscure than we're used to! 7.
gazthomas
5 Jun 2011
Llandudno
I was quite surprised to see Rotterdam come up in the list of railway stations today!
61653 HTAFC
18 Dec 2012
Without giving any spoilers, I was not happy with the way it routed me from some guesses today. If there's a direct train it should use it, even if it takes a little longer.
8ace
25 Dec 2019
Brighton
Likewise, got today's in five turns in the end - Hereford specifically annoyed me the other week routing via NWP when there's little difference from the direct service (not overly familiar with that area TBF)
61653 HTAFC
18 Dec 2012
Some of the quirks are no problem once you've encountered them, as long as you remember it the next time it comes up again- for example it insists on doing the Wakefield shuffle if you start at Huddersfield and need to head south towards London or Birmingham, despite Leeds being an easier interchange if you're an actual passenger!
Dave W
27 Sep 2019
North London
Down in 3 today here. I always start at Euston so half the fun is working out where to go across London. Weirdly it's only the last couple where I've paid any attention to the CRS letter indicators at all! Great game.
61653 HTAFC
18 Dec 2012
Had another annoying one yesterday, as I started at Huddersfield but it had me changing at York for Northallerton... but it keeps me on my toes by throwing the odd curveball!
cornishjohn
1 Feb 2011
The routing+timing algorithm definitely has some quirks.
One of my favourite "starts" is sometimes 50 min to the first junction, and sometimes 1 hour to the same place!
Today, using Swindon as my start I initially get a route that involves a walk. On a second browser, using a different start, a subsequent guess of Swindon gives a very different route that doesn't include the walk at all!
I have also seen a link that is 15(ish) min in one direction but 40(ish) min in the opposite direction.
61653 HTAFC
18 Dec 2012
Based on yesterday's puzzle, I can only assume there was a blockade on the Cross City line on the day the data was sourced- as it insisted on walking 15 minutes from Birmingham New Street to Five Ways which was the target station...
I know New Street is grim, but not compared to walking for 15 minutes in Birmingham! :lol: ;)
I suspect it puts you on the optimal service for meeting the next connection at whichever interchange:- thus you're sometimes put on a slow service from your starting station to the interchange point, because that offers a shorter interchange time for the next leg of the hypothetical journey. That's just me trying to reason why we see these anomalies though.
8ace
25 Dec 2019
Brighton
It does like trying to make you walk, from St Pancras to Waterloo it says train to to Blackfriars then 15 minutes walk, Marylebone to St Pancras 30 minutes walk!
61653 HTAFC
18 Dec 2012
That's odd, as for Kings Cross to Waterloo it uses the tube via Oxford Street!
gazthomas
5 Jun 2011
Llandudno
I wonder if there is a bug highlighted in today's quiz? Three character code had the same letter for two of the thee characters. I had correctly guessed the letter but it only populated one of the two.
I just did archive day 41 too, same issue.
cornishjohn
1 Feb 2011
I think the code is working, but it is a "feature" of the reasoning that it doesn't handle double letters. It would need another colour for "right place but also needed again". I'm getting the correct result for a one right place + one wrong place candidate.
Castle Cary
My day 41 isn't double lettered so i'm not sure what you are suggesting?
gazthomas
5 Jun 2011
Llandudno
Castle Cary
Sorry day 42!
Is this not similar behaviour to the New York Times Wordle (where this takes its inspiration from)? Double letters there are somewhat concealed unless you guess a word which also has the same two letters in it?
Royston Vasey
14 May 2008
Cambridge
Yes. The logic is working as it should.
If you had guessed DEE and the answer was EDE (not a real station) it would show yellow yellow green.
If you had guessed DEE and the answer was EDB, it would show yellow yellow blank. If it showed yellow yellow yellow, it would suggest that all three letters were correct but not in the correct place, which wouldn't be correct.
The "but also needed again" bit is for you to deduce :)
61653 HTAFC
18 Dec 2012
How do you get to do archived days? Is there a link?
gazthomas
5 Jun 2011
Llandudno
If you go to the "burger" menu (three bars, top right) one of the inks says "Archive". I think you're also reminded of the archive when you've completed the current day's challenge
Henffordd
27 Apr 2023
The Marches
Puzzled that, if my guess involves a journey between Birmingham New Street and Leicester, Loconundrum only does this via Derby (30 minutes plus 20 minutes), when there are direct trains very half hour, half or* which take the same time.
*of*
61653 HTAFC
18 Dec 2012
Thanks- there goes my evening!
Having done a few of the early rounds, I'm a bit baffled by a 50 minute journey time for Peterborough to Stevenage!
