Locomotive Services 1Z61 at a stand at Poole
liamf656
2 Aug 2020
Derby
1Z61 is currently sitting in Poole sidings due to the fact that the train is formed with Mk3s featuring Long SwingLink Bogies.
For those less in the know Long SwingLink bogies are not permitted on third rail due to the possibility that it could come into contact with the third rail.
The service was supposed to go to Weymouth, so I'm unsure now what will happen next
The first few posts in the below link explain the differences between Long and Short SwingLink bogies. For some reason the forum won't let me quote any posts
The Mk3 set ran numerous times over third rail lines during its brief spell on Steam Dreams workings.
Defiance149
30 Dec 2013
There's only one Mk.3 in the formation, presumably it will be removed for the return if not sorted.
Trainguy34
29 Apr 2023
Kent
Looks to be on the move again, only 167 mins late... Looks like it's only going to have around an hour in Weymouth.
brownandrew15
12 Aug 2020
Winchester
It’s a ScotRail livery one at the rear next to 47593 - didn’t see which one though. The rest of the coaches appear to be the same as the last time I saw it when it was going to Windsor at the beginning of May, including the blue and grey mark 1 buffet
D6130
12 Jan 2021
West Yorkshire/Tuscany
....and HSTs consisting of Mark 3 vehicles ran into and out of Waterloo numerous times in the mid-1990s on Eurostar Connect services....or does the restriction only apply to the loco-hauled Mark 3a stock?
Those would have had bogies with short swing links.
The arrangement at one time was to try and concentrate the coaches with long swing links on the Mk3 routes that didn't cover the third rail network.
Mk3s all carry a LSL or SSL marker on the coach end to demote the type of bogie fitted.
D6130
12 Jan 2021
Thanks for clarifying!
Brush 4
25 Nov 2018
It must have been hard explaining that to the non enthusiast members of the public on board.....
HamworthyGoods
15 Jan 2019
LSL just have to be honest and say they’ve made a mistake. It is a fairly basic requirement to make sure the train you wish to run is cleared for the route you wish to run it on!
Iskra
11 Jun 2014
West Riding
What was the remedy here? Was it removing the offending coach from the rake, or locking it out of passenger use? If so, how are the passengers from that coach being accommodated for the journey home?
hexagon789
2 Sep 2016
11082 was shunted out at Poole.
hexagon789
2 Sep 2016
Thanks, and what about the passengers? I thought there were rules about no standing passengers on railtours? (Assuming it was a sell-out)
No idea on either point, sorry - neither what happened to those booked on the removed carriage nor whether the tour was a sell-out or had up to 48 seats free among the other carriages.
fgwrich
15 Apr 2009
Hampshire
Indeed, now left abandoned awaiting a decision on how it will be recovered. More than likely by road unless LSL can obtain a dispensation to run it carefully off of the Southern, and with the airbags as high as possible.
Still, it goes to show that scrapping a lot of those Mk3 bogies (particularly SSL) wasn’t such a good idea after all.
theblackwatch
15 Feb 2006
11082 (the offending coach) is a more recent addition to the LSL fleet, being acquired from Barry for the ScotRail set. I'm sure the Platform 5 combined used to show which coaches had which bogies, but the 2024 version doesn't.
GC class B1
19 Jun 2021
East midlands
Raising the air suspension doesn’t increase the clearance between the bolster and the third rail. This clearance is only dependent on the wheel diameter. InterCity also carried out a modification to Mk3 vehicles to allow the minimum in service wheel diameter to be reduced which further reduced the clearance between the bolster and the third rail with wheels at scrapping size.
43096
23 Nov 2015
You cannot rely on the vehicle end lettering as it didn’t always get checked/changed when bogies were swapped. The only sure way is a visual check of each vehicle’s bogies.
Ashley Hill
8 Dec 2019
The West Country
But what was the problem in that case? It's already been stated upthread that the restriction only applies to loco-hauled Mark 3a stock.
HST coaches also have long and short swing link bogies. The guard happened to read the POIS list and raised the problem. The service was terminated at Andover where it was turned round.
43096
23 Nov 2015
It doesn’t just apply to loco-hauled Mark 3A vehicles. It applies to ANY Mark 3 (loco hauled or HST) as the bogies are common to both types.
D6130
12 Jan 2021
HST coaches also have long and short swing link bogies. The guard happened to read the POIS list and raised the probloem. The service was terminated at Andover where it was turned round.
Thanks for the clarification. That must have been rather unfortunate for anyone with a Eurostar connection from Waterloo.
I'm rather confused here. Cross-Country HSTs used to run to Bournemouth did they not? Plus the Cross-Country HST Farewell railtour from Leeds to Swanage. Were certain units specially formed of short swing link bogied stock specifically for these services?
Iskra
11 Jun 2014
West Riding
Yes, that’s exactly it :)
ajs
2 Feb 2018
Can anyone say why the train made it all the way down to Poole (apart from fact problem was not noticed ) before the problem was noticed and what sort of person would have noticed the problem - change of crew/guard?
D6130
12 Jan 2021
Perhaps the electrical control room noticed that there were several temporary shorts on the third rail after the train passed Basingstoke?
