Loco parking
richieb1971
28 Jan 2013
How does a driver know where to park a loco?
Take any siding scenario, how do you know when to go right down the bottom of the siding vs parking it somewhere in the middle? I've always wondered this as its so random.
Surreytraveller
21 Oct 2009
Rule Book says to the end of the Siding. Unless a Shunter or Signaller or someone else instructs the driver to put it somewhere else
12LDA28C
14 Oct 2022
A driver doesn't really 'park' a loco, it's stabled although a 'parking brake' would be involved as part of the stabling process. Generally a loco should be taken all the way onto the stops of a siding - if it was left anywhere else it may prevent another loco/train entering the siding behind it. If a loco will only be in the siding for a short time, eg whilst shunting then it may just go 'in clear' of the points or signal before leaving the siding again.
DarloRich
Fenny Stratford
You have to find a space and hope no one has parked a 66 accross the lines.
Then you have to work out which app to use to pay for the parking or find the machine doesnt take google pay and you havent any money!
I think the convention is you drive to the end of the siding so someone else can park behind you.
That can lead to blocking in which causes all manner of fun!
Welshman
11 Mar 2010
Then you hope the Revenue Inspectors don't visit and find you've left it for longer than you've paid for.
12LDA28C
14 Oct 2022
Can just any siding be chosen?
That wouldn't generally be up to the driver. Where signalled, the signaller would decide dependent on siding capacity, what other movements were planned, if the loco were required to be fuelled and so on. At an unsignalled location with say handpoints, which siding was used would be down to a shunter if there is one, although the driver may well have a specific siding indicated by either his docket or route knowledge and so on. In any case the final location of the loco would probably be communicated to someone eg a supervisor and/or the signaller.
Iskra
11 Jun 2014
West Riding
Thank you
greyman42
14 Aug 2017
If you only go half way down a siding and park, do you get a ticket?
43066
24 Nov 2019
More likely a rollicking from the signaller, unless you shut the cab down quickly enough to kill the GSMR before he calls… ;)
richieb1971
28 Jan 2013
Are the jokes because I said "parking" rather than something like "stabling"?
Although I cannot find examples I've definitely seen locos stabled with gaps between it and the buffers.
Although not any buffers in sight locos stabled at Eastleigh adjacent to the station seem to be in slightly different places from time to time. Sometimes the siding isn't a terminus.
Certainly makes sense to utilise the track in an efficient manner.
Welly
15 Nov 2013
The driver has to hope the ANPR camera used by certain parking companies has accurately read the loco number otherwise he would need to scroll through blurry photos on the machine to find the right picture to pay for the parking!
12LDA28C
14 Oct 2022
I should hope so. Locos and other trains should be stabled 2m from buffer stops, unless a local instruction or similar notice states otherwise.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Hours of fun to be had watching someone trying to parallel park a 66! Jokes aside, it's only called stabling because of the railway's terminology roots in the horse-drawn era.
Northampton
Drivers are generally briefed to pull up a bit short to avoid accidentally denting the buffers. However I've seen times when drivers have needed to use every last inch of space and the skill to bring the train to a stand almost kissing the buffer stop is an art in itself.
On through lines it can be slightly different, as it depends on what other trains might need to come in from either end and whether any shunting is planned. I guess different FOC locos can also complicate matters, as the signaller will need to make sure a loco isn't trapped in when it should be forming a train. So on a double ended line a loco may be placed more in the middle to allow shunts in from either end.
Indeed. some of the yard plans are very carefully worked out.
ExRes
16 Dec 2012
Back in Sussex
I think @66701GBRF is the closest in post #15 as route and depot knowledge are far and away the number one priorities, drivers should know exactly where a loco should be berthed and if there are any changes to the norm then there should be groundstaff there to advise
cf111
13 Nov 2012
The Caledonian Sleeper at Euston is a great example of this, it always impresses me how the drivers can get such a long train to stop smoothly so close to the buffers.
Here is an example, photo I took at Southampton (berth 106) today, plenty of siding remaining, but blocked by a public walkway to the car park, so loco drawn up just clear of the points. Saw two 66s do this few minutes apart.
Cowley
15 Apr 2016
Devon
That literally looks like they’re parked (stabled) in an airport carpark.
“Gold Zone for two weeks sir? That’ll be £10,000…”
