LO West Croydon to Clapham Junction via Sutton and Wimbledon
londonteacher
10 Aug 2018
Chatham
Hi all,
I'm just wondering if this would be possible, although would probably need some new infrastructure. But, a service from West Croydon to Clapham Junction via Sutton. It would follow the line West Croydon to Sutton, then to Wimbledon upto Clapham Junction. Obviously pathing might be an issue.
big all
23 Sep 2018
redhill
there used to be a direct rush hour service years ago when i was a driver at coulsdon north -----
-----well i say direct it was something like 0740 coulsdon to victoria then something like the 0825 to holborn viaduct via west croydon sutton wimbledon streatham herne hill
the usual was london bridge to west croydon and the same as above every half hour
Hi all,
Directly via Earlsfield? Almost impossible, with the SWML being paired by direction at that point you’d never get it across the down lines. It would be an even bigger problem with Crossrail 2 in place.
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
Can't see the point IMO
Unless Southern trains take over the TL services on the Wimbledon-Sutton loop but then where would they go after Wimbledon? There is no link to the SWT lines (from memory) and even if there was one, it would conflict badly with SWT metro services. The only option would be to continue back to Streatham and thence on to Clapham - unless...
Analogous to the Kingston Roundabout services to/from Waterloo, maybe a Victoria - West Croydon - Sutton - Wimbledon - Streatham - Clapham Junction - Victoria "Roundabout" service, but again, only if TL trains didn't serve the loop any more
Another point is that none of the approaches from the outer areas towards Clapham Junction really allow for terminating and reversal of services. About the only possibility is P16/17, but that still requires a crossing of the ‘Southern’ Down Slow...
Eddd
8 Apr 2018
This should go via Southfields and Wandsworth Town to Clapham Junction. Those proposals to extend the District Line to Sutton have always been looking at it the wrong way round!
Ianno87
3 May 2015
Quite the understatement!
What need would it fulfill?
Sitton already connected directly to Croydon and Wimbledon.
Wimbledon and Croydon directly connected by Tramlink.
Sutton/Wimbledon to Zone 1 faster via other routes. Sutton to ELL already an easy change at West Croydon.
