LNWR/WMT Super Off Peak Query
96tommy
18 May 2010
Good evening,
Tomorrow I am looking at travelling with a Priv from Crewe to London Euston and back. However, my itinerary is
Crewe 1313
London Euston 1524
London Euston 0039
Northampton 0203
Northampton 0520 (starts here)
Crewe 0702
Looking at BRFares there seems to be a Super Off Peak Return fare for around £10 from Crewe to Euston if travelling on WMT/LNWR
However I can’t work out if it is valid on the 0520 Northampton to Crewe 0702. The only information I can find is restrictions on what time you can arrive/depart London
Is the ticket valid on the 0520 or not?
Thanks!
I would say yes because:
"Not valid for travel on northbound services timed to depart any station before 10:30.
Not valid for travel on services timed to depart the origin station on the ticket after 15:59 and before 19:01 in either direction."
But...
"A connecting service can be used to complete a journey begun at a valid time."
You left Euston at a valid time so you are OK. Though the chance of a ticket check on that train is somewhere around zero I reckon.
However because this is impossible to implement in a restriction code planners won't show it. This has been a known issue for 20 years now and staff are well aware of it.
Tazi Hupefi
1 Apr 2018
Nottinghamshire
Yes, but you're relying on two things here.
1) Even though you're not as it's after midnight, you're relying on travelling the "previous day" otherwise you can't leave Euston before 10:30am.
2) You're starting your connecting journey at an original departure time that the ticket was otherwise valid.
However, you may well be kicked out at Northampton for a few hours and only allowed back in closer to a train departure time - no idea how strict the staff are or how they operate the station throughout the night.
It seems rather a difficult and uncomfortable itinerary to follow personally - but horses for courses!
Presumably that train will be a Northampton (?) rather than Bletchley crew but I'd still be amazed if there was a ticket check on it anyway. I'd also be surprised if NMP gateline wasn't open at 0520, or if it is staffed it'll be staffed by a security guard who really doesn't care.
I'd be surprised if doing this led to a problem, particularly for staff, aside from maybe needing to sit on the steps for a couple of hours.
96tommy
18 May 2010
Thanks for the replies, just one of those grey areas. As you said ticket checks might not even take place plus being staff usually works in your favour, cheers!
Starmill
18 May 2012
Bolton
I would say that you are covered by the wording quoted above by @Bletchleyite for the morning:
But you should be prepared to have this part to hand to show if there's a ticket check in the morning, and potentially pay again, although that's very unlikely, and to later raise a complaint asking for the additional money back, by relying on the wording Bletchleyite mentioned.
You are in the fortune position that, as there are no possible alternative services, you can easily fit within the meaning of "a connecting service" - even though your connection time is quite long.
Most conductors are sensible people and usually will allow travel on the first service of the day even with an expired ticket from the previous night, if the passenger claims to have missed their last train. You can usually tell when someone's been waiting all night outside a station. Usually the first train of the day is very lightly loaded, so this discretion doesn't cost anything as long as the ticket would have been valid on whatever the last train the previous day was. But that's a discretion you don't need to rely on here because luckily your ticket hasn't expired.
Tazi Hupefi
1 Apr 2018
Nottinghamshire
You're unlikely to have issues with West Midlands Trains staff - aside from being kicked out at Northampton for a few hours, however the ticket barriers at Crewe will almost certainly reject your ticket and it will be the Avanti staff you will need to convince! That may be somewhat easier with a staff travel document.
If it's a barcode ticket, I would do my best to have it scanned as much as possible along the way, even if gates at Euston and Northampton are open, they should still accept scans.
