Hi all, I hold an advance single as an e-ticket for travel from Aberystwyth to Shrewsbury on Monday 6th November.
I want to travel onwards to London using the following fare: https://www.brfares.com/!faredetail?orig=SHR&dest=EUS&rlc=YNG&rte=371&tkt=OPS
(Super off peak single routed LnW/TfW only from Shrewsbury to Euston, £13.35 with my railcard).
I note that it has been mentioned in other threads by @yorkie that the restriction code on this ticket is not implemented correctly in journey planners, ie there is blanket ban on all departures at any station from 15:59-19:01 despite the fact the human-readable restriction is quite clear in stating the only relevant station is the origin on the ticket - I intend to depart Shrewsbury 14:32 (changing at BHM, and eventually arriving Euston 18:17), which, as I understand it would be perfectly valid.
I would prefer to buy this ticket as an e-ticket that can be added to my Google wallet, to match with my original ticket in case of a delay, but I have a few questions...
I) is there a website from which I can buy this ticket and add it to my Google wallet without selecting an itinerary?
II) If not, and, even if so, if I buy the ticket with a different (or no) itinerary and attempt to use it as I intend, am I likely to encounter any issues if scanned (ie, will the ticket come up as invalid to an inspector)?
III) In the event of disruption if I end up with a paper ticket, or a ticket as above, am I likely to encounter issues claiming delay repay (and in the event of a delay on the first leg to the extend that I would be leaving Shrewsbury after 15:59, would I likely be able to demonstrate previous delay to show that the journey would still be valid)?
IV) If someone from London Northwestern Railway is reading this, could you fix this restriction code? It has been highlighted multiple times by Yorkie on this forum, and if I was to buy a ticket normally I would be overcharged for my travel.
