- Joined
- 7 Apr 2010
- Messages
- 34,263
So it may be the less, ie not as far as Berwick at all? Is it Morpeth next to the north?I read somewhere it was the ECML under the control of York and Newcastle boxes.
The 385s have this ladder to heaven also...Tony miles put a picture in Modern Railways of the banned "ladder" that the safety nannys have taken issue with. Excellent article in this months.
K
With legacy SSI in York IECC, Tyneside IECC and the Morpeth, Alnmouth, Tweedmouth and Edinburgh Signalling Centres there are likely to be multiple locations affected.
Thanks for chasing it all through!Aha, I've just re-read the article published by Roger Ford in the October issue of Modern Railways (obviously the memory is starting to go!) and he has the following to say on the scale of the issue:
R. Ford, 'Informed Sources', in Modern Railways, (October 2018) p. 33.
So it could in theory be from Joan Croft all the way to Edinburgh that Isolating Surge Protection Units need fitting (hence the 200 tweeted earlier by Mr Ford)!
390 & 395 perhaps?I thought 350s did but they don't, they have a run of parallel cables very neatly arranged below solebar level. I'm sure I have seen it on some other UK stock, though, and I've not seen a 385 in the metal so it wasn't one of those.
390 & 395 perhaps?
I wonder if the NR electro-magnetic compatibility(EMC) specification limits have changed to make their own signalling non-compliant (or it could be an aging effect)?
I posted a pic of a 390 earlier in this thread. I thought the 395 appears somewhere in the main 800 thread but could be thinking of somewhere else...Could well be, I can't find a decent photo of the inter-coach bit of either. The 800s do have a very wide gangway unlike the 390s, though, if the 390 does have cables like those it'd be impossible to climb into the gap anyway as it's too narrow - the coach ends aren't tapered and the gangway itself is quite short.
How do you work that out when I already posted it was Berwick from what I read somewhere?So it may be the less, ie not as far as Berwick at all? Is it Morpeth next to the north?
I was probably sidetracked when you wrote “under the control of York and Newcastle boxes”. So I took that as being no further...How do you work that out when I already posted it was Berwick from what I read somewhere?
There is quite a simple and easy fix to the problem.The 385s have this ladder to heaven also...
Well to be honest I had forgotten the smaller boxes north of Newcastle and assumed it extended to Marshall Meadows.I was probably sidetracked when you wrote “under the control of York and Newcastle boxes”. So I took that as being no further...
The DfT didn't specify this; the DfT merely specified that it had to comply with relevant standards, which is what is always done. If NR's equipment doesn't conform to their own standards, that's NR's problem, given NR could potentially change the maximum EMC emissions as far as I'm aware. Neither the DfT nor any other rolling stock customer should have to figure out what's acceptable on every mile of track.I'd expect it to be more case of the NR limits not being based on the kit in use or more to the point the actual EMC limitations of the kit in use. This maybe erroneous vendor specifications or records not having been taken when the kit was installed, quite possibly a legacy BR issue. Surely this one of things to be expected when interfacing a "new" train design with legacy equipment unless of course the specification is written to match emissions of a previously in use type on the route... oh wait DfT didn't do that.
They are. Virgin had already contracted for the seat moquettes etc. to be ripped off and replaced with red ones, which is why LNER had to go with a red livery.Can't see there being much change. They're hardly likely to rip out the seats and replace them with better ones. It'll be a splash of colour here and there and perhaps some bistro style seating in the buffet car.
Insert a 2m high piece of rubber sheeting between the coaches. The rubber will bend with the coaches.
Yes, the longer that they are delayed the better for the passenger.Be the same rubbish seats though won't they. Like I said, a splash of colour here and there.
Any information on the seats? Will they be similar to the GWR variant or a lot more comfortable?
I think this is it.I was chatting with someone who has been on an LNER IET and they've confirmed that they're, as has been widely expected, identical to those fitted to the GWR IETs.
I think this is it.
They're not what's been fitted in the end - LNER have got the same seats as GWR on their 800s instead...I think this is it.
