Liverpool to Chester inter-available fares.
hexagon789
2 Sep 2016
Just a quick query.
Wanting to do Liverpool to Chester and back as a day trip soon and ideally I'd like to use Merseyrail one way and the TfW service the other.
Am I correct in thinking that the Anytime Day Return at £16.20
is the only fare valid on both Merseyrail (via Birkenhead) and TfW (via Runcorn) with all the other cheaper fares being restricted to a specific route?
Many thanks :)
Mcr Warrior
8 Jan 2009
Anytime Day Return Liverpool Stns to/from Chester (route "via Birkenhead") is £9.45 and a one way change of route excess to route "via Runcorn" for the journey back should be an extra ~ 5p.
pokemonsuper9
20 Dec 2022
Greater Manchester
If you combine a £6.40 Merseyrail day ranger with a £7.10 via Runcorn single (or if you can get an advanced ticket) that might offer good value if you are going to make more Merseyrail journeys.
hexagon789
2 Sep 2016
Thank you both for the suggestions.
For the excess, my understanding is that one can board the train and obtain it onboard without detriment?
I was thinking the Dayranger was the way to go, before I decided I'd kind of like to do both routes.
I may just use Merseyrail both ways, due to the better frequency.
Anyway, thank you both, inputs much appreciated and given me something to think about.
Tazi Hupefi
1 Apr 2018
Nottinghamshire
Be aware that Merseyrail don't have on-board facilities to issue or excess tickets.
Whilst there is a theoretical ability to obtain an excess on Transport for Wales, you will find it much easier to do at a ticket office, both Liverpool Lime Street and Chester will be more than able to assist you.
hexagon789
2 Sep 2016
Thank you, duly noted
Haywain
3 Feb 2013
That doesn't change the fact that they can't do more than issue an excess fare in the circumstances described.
But there is absolutely no obligation to use a ticket office for this. And some would find it challenging anyway.
Just a quick query.
Many thanks :)
That fare shouldn't really exist, since the principle is that higher priced geographically routed fares are also valid on the routes permitted by cheaper fares.
Via Warrington is the next most expensive fare. As the "via Runcorn" and "via Birkenhead" fares are cheaper, the "via Warrington" fare is also valid via those routes. Therefore it should simply be changed to "Any Permitted" to replace the confusing and unnecessary current route "dot" fare.
Similarly, the "via Runcorn" fare is valid via Birkenhead. (It's also valid that way by virtue of the 'split route check', as Chester to Runcorn is permitted via Birkenhead and Liverpool)
NorthWalian
11 Mar 2025
North Wales
I wonder if the same applies to season tickets where a “via Runcorn” is much cheaper?
jfollows
26 Feb 2011
Wilmslow
For a Chester-Liverpool ticket, yes, as @Watershed says.
But the routeing guide is not recursive.
So don’t think it applies to a Wrexham-Liverpool ticket, which is what I think you’re going to do. Wrexham-Runcorn is not valid via Birkenhead and therefore the ‘split route check’ which works for Chester-Liverpool won’t apply.
Statto
8 Feb 2011
At home or at the pub
Cheshire Day Ranger could be an alternitive, valid on both Merseyrail & TfW Chester - Liverpool services but it £31.20, & if going on a weekday, only valid after 9am Monday to Friday.
NorthWalian
11 Mar 2025
North Wales
How complex
Still baffles me why one needs to split at Hamilton Square in the first place
Kite159
27 Jan 2014
West of Andover
Although wouldn't a £6,50 Saveaway be a better option, as that allows the OP the ability to use buses, the ferry across the Mersey & other trains (Northern/TPE etc).
The £6,40 Merseyrail only ticket in comparison isn't the best value for money.
pokemonsuper9
20 Dec 2022
Greater Manchester
I just checked which rovers were valid at Chester when I did the search, railrover.org didn't display the saveaway for that search.
It looks like the via Runcorn ticket is the same price from Chester to either Liverpool South Parkway or Lime Street, so splitting at South Parkway wouldn't save any money (unless better advances are offered)
WirralLine
4 Jun 2024
Wirral
The Saveaway is a Merseytravel product, it does show on BR fares under rangers and rovers (type in Mtrav). It can be used on any bus or train within Merseyside and also into Cheshire (Hooton to Chester/Ellesmere Port) and Lancashire (Ormskirk) on Merseyrail ONLY. The all area Saveaway can also be used on the Mersey Ferry for a single crossing only (Cant return to your origin without getting off first).
You can usually get some cheaper advance fares on TfW between LIV/LPY and Chester, so I would probably go for those.
If you want an excess for a via Birkenhead ticket Chester booking office are usually quite good at these things, failing that TfW guards are usually good at selling them too. Saveaways are available in CCST train ticket format from the ticket office at Chester - if you buy one from a Merseyrail station you would need to pay £1 for a "Metro" smartcard. TfW guards can also sell Saveaways onboard, if they can't find it, tell them to go to rangers/rovers and type in Mtrav. The Merseyrail only daysaver as mentioned above for 10p less, can be bought at the TVMs at Chester or at the ticket office. We can sell them onboard too, but the way to do it has changed and I cant remember how. I think it was under normal fares with a Merseyrail served station as an origin and Mrail All Zone or something as the destination. It used to be NORTHWIRRALLINE or something but came up with no fares last time. Dont quote me!
Hope this helps.
Statto
8 Feb 2011
The Merseyrail Daysave is quite poor value (i know Merseyrail keeps the money from it though) compared with the Saveaway, both have the same Morning peak restrictions, & quite odd for an off peak ticket, you can use them before 6.30am Monday to Friday, don't know of any other off peak multi mode/journey ticket that allows this, that's for another thread though.
Djgr
30 Jul 2018
The Daysaver scam ticket rears its ugly head again. Saveaway is so much better value.
