Liverpool City Region-Bus Franchising
Harryn9000
15 Jan 2010
Yeah the lack of layover spaces is why the Cross River routes 407, 432, 433, 464, 471 & 472 continue through to Cook Street, but the Cross River routes go straight back out when they are late on arrival & often missing Cook Street altogether going straight from Whitechapel to Sir Thomas Street instead, & it was a nightmare the other day when because of a fatal crash the Birkenhead tunnel was shut until early evening, some were Cross River buses were only going to/from Birkenhead as they were that late.
It was also bad Birkenhead side for buses to even just get to the tunnel, the main issue for cross rivers when Queensway is shut for whatever reason every singles bus is late as no buffer in the diagrams to get back on track
gka472l
29 Apr 2016
Merseyside
In regards to school services, what buses are Huyton Travel due to use when their contracts start, and also are Aintree Coachlines operating any franchised schools in the Wirral?
HTL have got a load of ex Stagecoach London E400H's, ranging from 61 to 64 plate, most being 14 plate ex Plumstead examples.....22 known of so far which are listed below (Stagecoach numbers shown)
12132LX61DFJ
12135LX61DFN
12281SN14TWZ
12282SN14TXA
12284SN14TXC
12285SN14TXD
12286SN14TXE
12288SN14TXG
12289SN14TXH
12291SN14TXK
12292SN14TXL
12293SN14TXM
12294SN14TXO
12297SN14TXS
12298SN14TXT
12299SN14TXU
12302SN14TXX
12304SN14TXZ
12306SN14TYB
12323SK14CTU
12337SN64OGK
12358SN64OHH
HTH
Gareth1990
8 May 2026
Oxted
Is there a reason the joint bus routes can’t continue under franchising? Would it not ensure resilience for example in the event of strike action?
Harryn9000
15 Jan 2010
Most of the routes was set for competition which now under 1 depot makes no sense
PaulWC
15 May 2017
I have just glanced momentarily at the timetable of the 612 and it literally follows the path of the 22A between Newton and Wigan in the evenings minutes apart. I hope this doesn't result in the withdrawal of the 22a due to duplication in the common section forcing you to change onto the 322 but if they are keeping it, i sure had misplaced hopes that with franchising the planners would have a wholistic look at all the buses that serve an area and try their best to space out services. The Bee Network has failed to some respect on this regard again. Let's hope Merseytravel don't do the same.
The 22A is directly replaced by the 322 and 612
According to the Warringtons Own Buses website, the 22A continues to the end of October:-
What’s Changing?
  • Service 22 will be renumbered to 322 and will now operate during evenings and on Sundays
  • Timetables will change
  • The route will operate as part of the Liverpool City Region bus network
  • The service will be managed under Liverpool City Region ticketing arrangements
  • Ticketing Changes
  • Service 22a is withdrawn at the end of October
JasonL
13 Nov 2024
Earlestown, Merseyside
It's going to feel strange having the 322 and 22A in service at the same time in the evenings and on Sundays until end of October
PaulWC
15 May 2017
Apologies if it's been covered before, but why are Warrington running the 322 if it's part of the new Metro network? The fact that Warrington tickets won't be acceptable on the 322 could cause some confusion, assuming that they won't be running any buses in the Metro livery.
20 Mar 2012
I was down in Southport last and saw one of the arriva E200MMCs in metro livery. Just curious is southport and the surrounding areas part of the franchise, if so when does it take place.
TheGrandWazoo
18 Feb 2013
They had a batch delivered for Southport and Wirral in Metro livery. Despite what some think, such gestures don't really influence the procurement process so the Wirral ones will be moving on elsewhere once Go Ahead take over.
JasonL
13 Nov 2024
It remains to be seen if any of Warrington's buses could be repainted into the Metro livery.
darylyates17
8 Nov 2015
St Helens
I doubt it considering Warrington will want buses on the 322 to be able to work with other Warrington routes.
They’ll have different ticket machines so won’t be able to interwork any other routes unless Warrington get more franchised routes which I doubt.
3 Mar 2020
Furness
They are already yellow so the metro livery won't look that much different from the front will it? They are already electric, which ticks some boxes. Maybe the thought of removing electric buses and replacing them with diesel/ hybrids doesn't appeal politically?
adam rogan
1 Feb 2026
They'll use ticketer so I assume it will accept solo passes just as they currently do now. Get the 22 now at Ashton and they accept Bee cards, Metro cards between Haydock and Newton and whatever Warrington passes from Winwick onwards.
The only awkward thing will be ticketing for Merseytravel residents using the 322 at its two start points. The question is whether their current Merseytravel passes will be allowed on this service outside the franchising zone or will Metro devise a two tier system like Greater Manchester, a ticket for journeys within the boundary and a ticket for services franchised outside the boundary as well as permit routes by non franchised operators.
I still have reason to believe that Arriva holding onto the 329 and the 360 is the reason for this haphazard decision to make the 322 part of category 2, as these routes would have come under St Helens' remit and the two routes could have interworked seamlessly with the 322 at Warrington with Merseytravel passes working on them end to end.
What will be funny to see is the 22A running in tandem with the new 612 before it gets shelved and the transport authorities realizing that the Newton to Wigan corridor is not profitable which is why the 22a had to be tendered and Arriva reduce its 360 to an hourly baseline. I think the only redeeming feature of the 612 is that it replaces the 20 between St Helens and Earlestown and replaces a few Wigan local services on that side.
Mollman
21 Sep 2016
Preston
The 322 was a stand alone contract rather than part of the St Helens franchise
Statto
8 Feb 2011
At home or at the pub
When Liverpool goes to franchising next year, the Stagecoach 82, & 86 will go to Speke, Stagecoach 53 will go to Bootle, & the Arriva 14 will go to Gillmoss won't it?
gka472l
29 Apr 2016
Merseyside
I wonder a batch of single deck EVs have been ordered for Gillmoss for the routes moving over that cant have deckers?
Only Gillmoss routes that currently use single decks are the Maghull circular (i believe will be in the Sefton franchise), the 4 and the Kirkby circular.....
317 forever
21 Aug 2010
North West
Ironically, franchising will therefore see routes 53, 82 & 86 follow route 10a in losing their electric buses, at least for the time being.
I expect something else to move into Gillmoss, maybe route 15 or 62 for example.
