Live general election coverage outside the UK
nw1
9 Aug 2013
Just discovered that the BBC iPlayer cannot be accessed outside of the UK even if you are a licence-paying UK resident, there appears to be no way of signing up with a TV licence number for example.
Is anyone aware of any alternative services whereby I could get live election coverage on the night, ideally TV or if not, radio? I will be in continental Europe.
BBC would be ideal but anything would do as long as it wasn't an overly biased station.
(How incidentally do people access BBC Radio overseas? I often hear people calling in from overseas saying they are listening to Radio 2, for example).
Thanks.
Ediswan
15 Nov 2012
Stevenage
Thanks.
BBC Sounds is available outside the UK.
Darandio
24 Feb 2007
Just use a VPN. Fool iPlayer into thinking you are in the UK when you aren't.
High Dyke
1 Jan 2013
Yellabelly Country
Using a VPN can also act as a proxy, allowing you to surf the web anonymously from wherever you want.
Therefore, you can use one without any legality issues. As mentioned though, BBC Sounds is available.
BBC Sounds information here:
Can I use BBC Sounds when I travel outside the UK?
You can listen to most of our live and on-demand radio content from anywhere in the world.
dosxuk
2 Jan 2011
There will probably be a world-accessible stream available from the BBC News homepage on the night. Many of the news streams do not have the geo-blocking that the iPlayer feeds have.
BBC News seems to be pretty ubiquetious in my experience of foreign hotels! Not sure I've ever come across one that doesn't have it somewhere in the channel list.
jfollows
26 Feb 2011
Wilmslow
It doesn’t help answer the question I know, but I remember watching the entire live ITN election night coverage from the 1992 (John Major) election in the US. Probably C-SPAN I would guess.
cb a1
9 Mar 2015
Exactly this, they are not too expensive and allow access to all services available in the country you choose to connect through.
I occasionally use the monthly free allowances on VPNs Windscribe and Tunnel Bear to access overseas streaming services.
I reckon I can get about 6 hours of live content a month (which is sufficient for my needs) before I would need to start paying for a VPN.
If using this approach, check the live stream settings. You can sometimes downgrade the quality to use less data. Not great if you're say watching sport, but for something like election coverage would be fine.
scarby
20 May 2011
Thanks.
Because lots (if not all) of the BBC radio programmes are available overseas. I regularly listen to county cricket commentaries and some football commentaries (not all matches are available but non-league stuff is) from Sweden and I have also done it in France. I just randomly checked BBC Radio Nottingham and BBC Radio 4 and they both come on straightaway with no blocking.
So you should be able to follow it live through a BBC radio channel.
Trackman
28 Feb 2013
Lewisham
Funny you should mention cricket, I was geo-blocked in the UK for listening to a test match on BBC sport iPlayer (Ashes???) so I had to use a VPN. I do this so I can listen to TMS whilst watching Sky sports with obviously no sound. Synching the both is a challenge within itself, but I've got it down to a fine art, bat and ball noise is when you know it's fully synched.
nw1
9 Aug 2013
Thanks for all the replies - looks like I have a number of options.
Yes. Unless you are in North Korea, Iraq, Belarus.......
Just asked as it sounds like it's "fooling" a site into allowing you access when you'd normally be blocked.
But it sounds like the situation is that it's not illegal to access iPlayer from abroad, they just make it difficult, to minimise the number of people with no TV licence accessing it.
JamesT
25 Feb 2015
Also for many of their programmes they likely only have the rights to broadcast in the UK. But that’s less of a thing for their news coverage.
