List of non surviving locomotives?
NightStar
1 Jul 2011
Across the pond.
GidDay, I have assembled a list of both diesel and electric locomotives that have no survivors of the class at present.
Diesels
British Rail Class 16
British Rail Class 21
British Rail Class 22
British Rail Class 23- New build underway.
British Rail Class 29
British Rail Class 41 (Warship Class)
British Rail Class 43
British Rail Class 48- Sulzer V12 12LVA24 power unit removed
British Rail Class 53
British Rail Class D16/1
British Rail 10100
British Rail Class D16/2
British Rail DHP1
British Rail DP2
British Rail HS4000
Turbines
British Rail 18000
British Rail 18100
British Rail GT3
Electrics
British Rail Class 70 (electric)
British Rail Class 74
British Rail Class 80
However I am interested in a list of all the steam locomotives that have no survivors at the present? Anyone care to compile a complete list?
Robert
scarby
20 May 2011
Robert
Wouldn't that be a collosal task, unless some reference work already exists - I don't know if it does? If you mean from the invention of the steam loco, you would have to run through all of BR, then the big four and then the hardest part, all the pre-grouping pre-1923 companies.
Just look at this list of LMS locos that existed the day before nationalisation, and remember that's not even a complete list of their loco classes through their history, only what still existed on that date:
http://en.wikipedia.org/wiki/List_of_LMS_locomotives_as_of_31_December_1947
ryan125hst
2 Jun 2011
Retford
I know that 18000 definitely exists. I took the two attached photographs at Barrow Hill back in 2009.
Kali
5 Jun 2012
A list of missing steam classes would be enormous: unlike most other places, British railway companies liked to design their own steam engines ( which might be built by some of the independent makers, but that doesn't mean they were independent designs ). Occasionally or if the company was very small they'd buy a design from an independent builder, but not terribly often - very small companies seemed as likely to get a neighbouring big company to run services instead.
Considering how many companies were in existence at grouping ( well over 100 I think? and that's allowing for previous amalgamations ) and the 90ish years or so of development of the main line steam railway locomotive by then you're in for a bit of a monumental task. Good luck!
NightStar
1 Jul 2011
Across the pond.
18000 made the list because it is unpowered. I would love to see the loco return to turbine service or even a new build GT3. However turbines are the least likely to ever run again.
I am thinking of major classes of steam locomotives from the LNER, LMS, etc? I would go for the Big Four to BR and the end in 1967-68. So say 1923 to 1968.
The P2
U1
0-10-0 Big Bertha
LMS garratt
Robert
12CSVT
18 Aug 2010
D1705 at Great Central Railway used to be a class 48.
Another class which ceased to exist due to re-engining was class 30 which became class 31 when their Mirlees engines were replaced by English Electric.
ryan125hst
2 Jun 2011
Retford
That makes sense. I didn't know it was without a power unit. Mind you, I suppose it would be restored and operational if it had!
12CSVT
18 Aug 2010
Perhaps they could give 18000 dummy engine components, like the prototype DELTIC.
Bevan Price
22 Apr 2010
For the LNER, steam loco classes taken over by BR that have no preserved representatives include Classes
Tender locos.: W1, B2, B3, B4, B5, B7, B8, B9, B13, B16, B17, V4, K2, K3, K5, D1, D2, D3, D9, D10, D15, D20, D29, D30, D32, D33, D41, E4, C1, C4, C7, Q4, Q5, O1, O2, O3, J3, J4, J1, J2, J5, J6, J10, J11, J24, J25, J26, J35, J39,
Tank locos: F1, F2, F3, F4, F5, F6, F7, G5, C12, C13, C14, C15, C16, V1, V3, L1, L2, L3, Y4, Y6, Y10, Z4, Z5, J50, J52, J55, J62, J63, J65, J66, J68, J70, J71, J73, J75, J77, J83, J92, J93, M2, N1, N4, N5, N8, N9, N10, N13, N14, N15, A6, A7, A8, A9, S1, T1, Q1 & U1 (In approximate order of appearance in Ian Allan ABC)
Expect similar numbers for ex-LMS, GWR and SR classes and it just shows how much variety has been lost since 1948.
GM078
17 Sep 2010
Leinster
Presumably this would be even harder when you take into account 19th century locomotives, can't imagine all would have been documented?
12CSVT
18 Aug 2010
I think GWR and SR loco classes fared better than LNER thanks to the intervention of a certain Mr Woodham ?
NightStar
1 Jul 2011
Across the pond.
Lets not rule out new builds of historic locomotives either. With the number of new projects in the works that should shrink the list some?
http://newbuildsteam.com/
The reason I was interested in this topic was in regards to building new locomotives of those that did not get preserved. The list is a bit longer than I had hoped it would be.
Robert
E&W Lucas
21 Jan 2010
Robert
But very few of those projects have any real chance of coming to fruition. The most likely, are those that are utilising a significant number of pre - existing components. Even then, the costs involved are horrific!
Also, don't forget the mass of induistrial railway systems that used to exist in the UK. A whole wealth of fascinating locomotives, and now a world that has largely vanished.
Kali
5 Jun 2012
Thanks to Churchward standardising early, the GWR is pretty well off because it didn't have a plethora of classes. Pity nobody grabbed a Grange, but that is one that's being cobbled together out of other components right now - thanks again to standard parts it's probably not far off a genuine one.
Also not present:
Hawksworth County ( I believe another one being knocked up out of an 8F and a Hall? )
5800: just a 14xx with no auto gear
I'm not sure if all the variations of the large 2-6-2 made it given Collett kept tinkering with them, but other than that iirc things are pretty complete for post grouping stuff.
Manchester77
4 Jun 2012
Manchester
Forgive me if I'm wrong or it's already been mentioned but what about kestrel/HS4000? I doubt there are any left unless someone else knows better...
:) m77
NightStar
1 Jul 2011
Across the pond.
It's a shame that the 4000 was scrapped. However since it ended up in Russia and stripped of parts over several years I don't think it would have been easy to rescue the Kestrel? Plus Russian track gauge is 5 feet 2 inches. So unless the original bogies survived? I would imagine finding a new pair for standard gauge would be a real problem?
Robert
sprinterguy
4 Mar 2010
Macclesfield
Robert
I thought that the original bogies were used when the loco went to Russia, but with the wheelsets regauged. All academic of course when the generally accepted view is that the loco was cut up in 1993/4, as you say.
NightStar
1 Jul 2011
Across the pond.
That is a good question? I was under the impression the trucks or bogies were changed out for Eastern European bogies from a Russian locomotive? Not much info seems to be at hand for Kestrel.
Robert
LE Greys
6 Mar 2010
Hitchin
Also not present:
Of course, the GWR also fared really badly in other areas. Not one broad gauge engine survives. Two were plinthed at Swindon, but (so the story goes) William Stanier decided they were no longer needed and had both scrapped, only for the company to have one rebuilt a few years later. An amazing number of original parts - including the chimney, all the cab fittings, the buffers and the nameplate - of North Star magically reappeared and went into the replica. Of course, we now have the Iron Duke and Fire Fly replicas as well. I'd love to see a Rover-class built to fill in the gap between these early engines and the conversion. The things were massive, easily capable of mile-a-minute times.
Kali
5 Jun 2012
There's Tiny, the one that used to sit on Newton Abbot, but nothing sizeable, no. ( I will look for conversions sometime ). Occasionally I look for a suitable disused line that would be suitable to rebuild as a 7' line, but nothing really springs to mind - the Faringdon line might be an idea given it's not all that far from Didcot, but not if they want to reopen it anyway...
Loads of non-preserved standard gauge pre-grouping GWR ( some of which were lovely bits of engineering ), but then it's the same with all the others.
341o2
17 Oct 2011
which is why the broad gauge was used - far greater stability than the "Stephenson narrow gauge"
Consider the Irish situation in 1948, where 491 engines were divided into 79 classes, 23 of which consisted of one locomotive
Bevan Price
22 Apr 2010
Most, if not all, of the early locos. have been documented by Baxter & Baxter in their series of British Locomotive Classes books. They list every steam loco known to have operated up to 1923. Many are also listed in the RCTS Loco history series, although the LMSR series is not yet complete. Ian Allan ABC's and similar books cover the post-1923 period.
Of course, the GWR also fared really badly in other areas. Not one broad gauge engine survives. Two were plinthed at Swindon, but (so the story goes) William Stanier decided they were no longer needed and had both scrapped, only for the company to have one rebuilt a few years later. .
I don't know if it is true, but one version I heard suggests that not all the blame can be placed on Stanier. Apparently they were short of space at Swindon Works, and someone (presumably the GWR board) didn't want to pay to find / provide an alternative location for the preserved locos. I think something similar happened to a couple of Midland Railway locos that had been set aside for preservation.
NightStar
1 Jul 2011
Across the pond.
Thank you to all who have contributed to my inquary regarding non surviving steam locomotives. In the coming year I hope to compile a list all of the post 1923 steam locomotives that do not exist today and post it here for all who are interested.
Robert
David Goddard
8 Aug 2011
Ely
I guess we are at a time now that we should be adding units to this list as well. Their contribution to the railways spans a very long period and should not be underestimated.
Can certainly start with classes 123/125, 304/305 and of course the Blue Pullman 251/261.
Tiny Tim
6 Jan 2012
Devizes, Wiltshire.
Yes, indeed, due to the unusual circumstances at Barry, very few locos were scrapped there. At the beginning, Woodham's were busy scrapping coal wagons, which are easier to process. Later on, Dai Woodham became more receptive to preservation groups. Due to the terms under which BR sold the locos to Woodham's, they could only make a modest profit selling them as complete locos. Other scrapyards cut up locos almost immediately, we have Woodham's to thank for much of our preserved fleet.
I seem to remember that the number of separate railway companies before grouping was 178, although some of these wouldn't have had their own locos. Still a monumental task.
