Lisbons funicular suffers catastrophic runaway (03/09)
Anyone know what emergency braking arrangement the Great Orme Tramway has? This is similar to the Gloria in being an on-street funicular (at least partly), but powered in the more usual way by a motor at the winding station not on the trams.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
I don't the precise arrangement, but form their website:
In the event that the cable hauling the tramcar were to malfunction, the tramcars are also equipped with automatic emergency brakes. These brakes stop a tramcar within a metre.
That to me is the sort of arrangement that I would expect - even in something from the late 19th century.
16 Aug 2017
whatever end of line measures were provided at the bottom
There's nothing there to stop it, other than the track and I suppose more significantly the trench ending, in the pavement. I think it's significant and concerning that the investigators haven't found out who's responsible for safety, which doesn't mean that nobody cared, quite the opposite, the thing had a lot of attention, just of the wrong things - easy to say - perhaps I should instead say they tested the things that were testable and in the absence of a proper legal structure around it that might have required extra equipment they did what they thought was right. The parallel judicial investigations won't be too happy about that, I don't suppose. But at some point it's unforgivable. We've had over 100 years to make conventional lifts work and they're safer than stairs for a reason. Public transport isn't supposed to do this.
bahnause
30 Dec 2016
bülach (switzerland)
During the investigation into the accident in 1932, it was discovered that the emergency brake had been disconnected in 1906 because it often activated accidentally. An alternative had not been found and the cars had remained without an automatic brake or indeed any effective brake on a 25% gradient from then onwards. A new system was only installed in 1934.
Sir Felix Pole
21 Oct 2012
Wilmslow
I see that the cars date from 1957 - presumably the chassis and running gear is older as one would expect a more fail-safe system at that date? The two other funiculars in the city - by the same engineer but heavily modified since - have been suspended as a precaution. Lavra in the east of the city is even steeper at around 23%.
Bovverboy
1 Dec 2013
The original system in 1885 used a rack and water ballast system, in which the car roofs were alternately filled with water to move the trains by gravity.
What did the rack do?
Quote from Egg Centric's post:
I can imagine it being relatively easy to lock a tram's wheels, but how do you stop the tram sliding down the track, or derailing?
Belperpete
17 Aug 2018
If the lower car had been further uphill when the cable snapped, the it would have run down with more force. If this had been sufficient to break the cable grippers in the trench, the lower car would likely have launched itself across the road and square below. Likewise if the upper car had not derailed on the bend, and had made it down to the bottom, there would have been precious little to stop it doing similar.
I rode on the funicular in Stuttgart last year. The information leaflet mentioned that a number of years ago it had been withdrawn from service, and its future had been in doubt, as extensive and expensive rebuilding was needed to meet EU safety standards. Without a safety regulator monitoring the Lisbon funiculars, who would enforce similar actions on them?
Egg Centric
6 Oct 2018
First question answers the second ;) - there are other solutions of course such as wedge something into the cavity where the rope sits. I'm not advocating any particular solution other than saying plenty exist.
Bovverboy
1 Dec 2013
My two questions (which were combined into the same post by the double post prevention system) were in response to different posters and related to different tramways - the first to the Lisbon funicular, the second to the Great Orme Tramway. I'm not aware that the Great Orme Tramway uses a rack.
Belperpete
17 Aug 2018
It would help if posters such as yourself actually mentioned which tramway they are talking about! Or at least not cut the text that you are responding to, such that the context is totally lost.
As this thread is about the Lisbon funicular, it is not unreasonable to think that posts will be about that, unless something in the post specifically says otherwise.
bahnause
30 Dec 2016
I assume it provided the braking.
The more I study the Gloria Funicular's current technology, the more convinced I am that its braking system was designed to stop the railway in its tracks, cable or no cable.
The pincer brake design is not unusual for an emergency brake on a cable car. The only difference from the usual application on other funicular railways is its use on the Z-profile of the cable groove instead on the rail. The rail is not an option in this case, as it is embedded in the road surface.
27 Feb 2013
I know very little about the technology of funiculars, so please forgive me if I'm writing rubbish. But I have wondered, does this Lisbon system have, or could it have, magnetic brakes? Would one or more magnetic brakes be enough to hold the vehicle stopped on that steep incline? I believe that all British trams have an emergency magnetic brake - that is what I am wondering whether could be fitted to a funicular vehicle.
Birkonian
19 Sep 2017
It seems that the cable carriage at the top (below the map) lost control after the cable broke, and it overturned and derailed when it slid down the curve (the top of the map) near the bottom at speed, and the old carriage immediately broke into pieces.
I think the biggest question is why is the brake not working.
My wife and daughter were on the funicular three weeks ago. They took lots of photos on board. Presumably, the unit is now a wreck. They were staying in a hotel next to the track. It's the semi- circular building on the right of your photo - a former theatre.
Magnetic brakes on trams achieve deceleration of about 25% of gravity. The average gradient of the funicular is quoted as 18%. So with no cable and no other brakes effective, the magnetic brake would probably stop a runaway eventually, but unlikely to be quickly enough. It would also need batteries and other equipment on board the car, so it could still operate if traction power was lost.
Paul AC
3 Aug 2025
Timperley
Magnetic track brakes do not get a mention in the preliminary report (English language version here https://www.gpiaaf.gov.pt/upload/processos/d054239.pdf ) so it can be assumed that this system was not fitted with them.
Magnetic track brakes require an independent power source - usually a battery - on the vehicle, and of course require a suitable mechanical fixing, as the braking forces must be passed through the mechanism to the vehicle structure. The battery must be kept 'topped up' charge-wise, presumably this could be done from the overhead power supply; presumably the cabins have saloon lighting fed from a battery in a similar way. You could probably use the same arrangement or even the same battery with suitable system design.
These Lisbon funicular cars do require an air supply for the pneumatic brakes, the brakes get mentioned in the report but the method of creation of the air supply isn't mentioned. Presumably there is a small compressor in each cabin, also powered from the overhead power supply. You would hope that there was a protection mechanism of some sort such that if the available air pressure was too low then you couldn't get traction to start the next 'move' - rather like the 'low main air' protection built into train braking systems (which makes an emergency brake application while there's still enough air in the train to bring the train to a stop).
The arrangement of the overhead power supply system interests me, in terms of how it works.
The preliminary report says "In this system, each of the two cabins is equipped with two 18 kW electric motors, which, through the wheels and their adhesion to the rails, provide the necessary tractive force to overcome the internal forces resisting movement and those resulting from the weight difference between the vehicles resulting from their respective passenger loads. The system's four motors (two in each cabin) are all electrically connected in series through overhead conductors on to which the two cabins are in contact. This means that the two cabins and their connecting cable only start moving when the control system in each cabin is moved to the drive position by the respective brakeman."
Rather than me guessing how it might work, does anyone actually know? Each cabin has two pantographs; how is the overhead wiring arranged, and yet work in the way indicated in the report?
Gag Halfrunt
23 Jul 2019
I read somewhere (probably in this thread) that the two cars are wired the opposite way to each other, such that the current return from one car becomes the traction power for the other. Each car can move only if the other one is drawing power.
stuving
26 Jan 2017
The braking system is described in the posts above, but it's hard to see it among the much greater volume of speculations based on the assumption it's not there. This is my understanding, based on peering intently at Figure 2 in the report and recruiting a couple of little helpers with the Portuguese.
The primary braking system on the cars is built into the parts called in the report "trambolho". Evidently this is just the technical term used locally for this part, which runs inside the conduit. It is attached to the blade that extends down through the slot into the conduit, and the term may include that too. In London trams with underground power pick-up this part is called a plough.
Each car has two of them, and the cable is clamped in both. The brakes have shoes pushing down on the top of the steel sections on each side of the slot, and shoes pulling up on the bottom of the same steel sections. This is a clamp brake, and the force is produced by air pressure, so its braking is not limited by the weight of the car.
This brake can presumably be applied by the operator's brake control as a service brake, but if the cable breaks or detaches a mechanical linkage detects this and applies full air pressure. In addition, loss of cable tension is detected at the pulley at the top of the tracks and the traction power cut off, which also results in a full air brake application in each car. Finally, the operator has a manual parking brake operating on each wheel by friction.
According to the report both these brakes did operate as intended, but the braking force was not enough to stop, or even hold, the cars. They will be investigating why that was: probably not by looking at the original design, for want of records, but from the latest major safety review. If (as one hopes) that review of the design concluded that the brake was adequate, then the key question is why is that no longer the case. I can imagine that changes made without having a major review might have done that - it's not as if a real test of the emergency brake by disconnecting the cable to see what happens will have ever been done.
I'm sure they will be testing the brake on the surviving car. This also dropped back when the cable became detached, which probably means its own brake wasn't adequate either and therefore it is most likely a systematic problem not a one-off defect in the brakes of the other car. The alternative explanation is that the other car might have come to a halt after a short time (pneumatics isn't instantaneous) if it hadn't hit the end of the track first.
Taunton
1 Aug 2013
Just to give some further context, here is a description of the four braking systems on a San Francisco cablecar, on steeper gradients than Lisbon, three friction brakes plus holding the cable at 9 mph cable speed :
I did notice how the cablecars have this substantial reserve stopping capability, whereas the city buses there, running on comparable streets and gradients, are standard commercial models with no specific additional braking.
Whatever braking is provided should surely be able to pull it up within the limits of the trackwork, especially as it had apparently just set off in the opposite direction when the fault developed, and thus passed through stationary to roll back in reverse.
Belperpete
17 Aug 2018
That is quite an important difference. The cable groove will presumably have been kept well greased to reduce wear on the cable, whereas rails are generally not.
bahnause
30 Dec 2016
I did not want to comment on the issue of 'lubrication' because, from the pictures, it is unclear to me how generously and in which places grease is to be found.
However, there is a parallel with the cable car accident in Blatten in 1972. The accident on the Swiss Bettmeralp cable car also revealed technical weaknesses and sloppy maintenance as the cause: after the traction cable broke, twelve people were killed when their gondola crashed into the valley station at 100 kilometres per hour. The judicial investigation revealed that the traction cable had been 'weakened over the years by rust corrosion at the connection point with the cabin, in the so-called grouting head, to 20–22 per cent of its tensile strength'. (Yes, it is alway the connection and never the cable...). It was also proven that the jaw brake, which is designed to engage automatically in the event of a power failure, cable breakage or excessive acceleration, could not engage at all because the cable car operators had continuously applied too much viscous lubricant to the suspension cable, which later became encrusted.
While I am not familiar with the exact regulations governing the Gloria funicular railway, in cases I am aware of, the braking force of the safety brake is typically measured once a year.
Belperpete
17 Aug 2018
Of course, if it is measured at a place where the slot is not well lubricated, it will not give a good indication of how well the brake would perform somewhere where there is excessive lubrication. I can imagine a scenario where they might measure the brake performance at the terminal stations where the cars stop overnight, which might be difficult to access for lubricating because the cars are in the way.
And once grease has got onto the brake heads, through applying them to a greasy surface, they will become near useless.
Paul AC
3 Aug 2025
Timperley
I've deduced some technical information from https://pt.wikipedia.org/wiki/Elevador_da_Glória so now things make more sense to me.
The track layout is totally different from most other funiculars - usually these are single track at the upper and lower terminals, with a dual track section 'halfway' to allow the two cars to pass each other.
Track layout:
This funicular has four 'running rails' all the way from top to bottom. Imagining I'm standing at the upper terminus looking down the hill, car 1 always uses the left pair of rails, car 2 always the right pair. At this point the two tracks are spaced apart, though they could in principle be interlaced - I think one of the Lisbon funiculars has interlaced tracks at the upper end, the others including this one are separated. Perhaps it depends on the available street width. Anyway, beyond the halfway-down point the inner pair of rails cross over to form an interlaced section down to the lower terminus.
Braking slot:
The braking slot is off-centre - to the left (looking down the hill again) for car 1 and to the right for car 2. So, for the interlaced section(s) there is still room for the slot between the sets of rails. This photo https://pt.wikipedia.org/wiki/Elevador_da_Glória#/media/Ficheiro:Tram_in_Lisboa_pic-003.JPG shows this clearly.
Overhead wiring:
Each car has its own pair of overhead wires, so there are four wires all the way from top to bottom. As for the braking slot, each wire pair is offset to one side - to the left for car 1 and right for car 2. The power pick-ups, which seem to be a combination of pantograph and trolley 'pole', are also offset in the same way, so the power pickups always stay under their respective sets of wires. Again, this photo https://pt.wikipedia.org/wiki/Elevador_da_Glória#/media/Ficheiro:Tram_in_Lisboa_pic-003.JPG shows this clearly.
So, it is perfectly feasible for the two cars to be connected in series across the overhead supply. Assuming both cars have some form of resistance control as on older trams, and two traction motors per car all in permanent series as already mentioned, as long as both 'brakesmen' select the correct direction, one can open their power controller to pass current through all four traction motors and 'accelerate' both trams together. The traction motor characteristics will manage the current flow such that all motors produce the right tractive effort for the prevailing load, through being linked by the cable.
When traction motor current isn't required, such as when the cars are stationary at their terminals, it could easily be arranged that the 'half supply voltage' that each car will 'see' can power a compressor (for the air brake) and battery charging (for lighting etc.). Otherwise I don't know how those would be achieved.
Those are my deductions and thoughts, happy to be updated.
I'm not keen on the thought that one driver can power all the motors without the other driver's co-operation. Putting the whole lot in series with both drivers having to close their controllers to make the circuit would mean both having to act before anything could move, but it would also mean no power for auxiliaries unless motoring (unless there is maybe a separate circuit returning via the rails?).
Egg Centric
6 Oct 2018
I'm not sure about that part. It seems to me necessary that both drivers should agree before power goes to the motors, which can also be done with the two trams in series but each driving position having the ability to break the circuit and therefore cut power to all the motors. Also, a traditional DC tram has starting resistances which the driver has to switch out progressively to limit the current at low speed before the back EMF builds up. Zooming one of the Wiki photos does seem to show a controller like this in the cab, but it's not clear enough to tell whether it has resistance notches or it's just a simple stop-go.
I don't know for sure and haven't been on it, but videos of the thing's operation suggest it was too slow for that to probably matter if I guess.
Paul AC
3 Aug 2025
Timperley
The other driver will have to co-operate, in that I've assumed (but didn't mention specifically) the usual sort of three-position direction switch - forward/neutral/reverse. You'd have both in neutral when stationary at the terminals - and in this state you could get half volts for the auxiliaries. To start a movement one driver will select forward, one reverse according to direction of travel; then both would need to select 'first notch' to start the traction motor current flow. You'd want a standard way of notching up; one first then the other? I wonder if there's an ammeter somewhere in each cab?
As long as the dwell time at the terminals is adequate there's no need for the auxiliaries to take power from the overhead while the cars are actually moving. You couldn't have the rails as part of a separate return circuit as one would have to be 'live' under some circumstances (I think! I haven't tried to work it out fully).
If both selected neutral and the auxiliaries were across the supply to each tram then it would end up with both in series on half voltage. Assuming no clever electronics, that would do something pretty odd to the lighting when the compressor started up!
My thought for the rails was for one outer wire to be at +600V, the other outer wire to be at -600V (actual voltage is a guess on my part) and both rails and inner wires to be at 0 volts, but the inner wires "floating" with no electrical connection to anything else.
J663738
20 May 2025
I am not sure if its been mentioned that one of the deaths was a UK man who was a transport enthusiasts.
I wouldn't be surprised if he was a member here. RIP.
The third British victim killed in the Lisbon funicular crash has been named by police.
David Young, 82, from Holyhead on Anglesey, was among 16 people who died last Wednesday when the Glória funicular derailed and crashed into a building in Portugal's capital.
His family described him as a "lifelong transport enthusiast", saying it was a comfort that "his final moments were in pursuit of the hobby which gave him so much happiness".
I have been on this funicular, along with at least fours other cable cars recently that have had crashes and sadly fatalities.
The other half is always saying are they safe? I used to say but of course, but honestly I am doubting this myself.
hexagon789
2 Sep 2016
The cars have sanding equipment.
The cable slot brake has shoes which bear both down and up on the Z profile:
In the second photo, that pipe in the middle is a sanding pipe, there's one each end.
Having re-read the report, I'm now more leaning towards the service brake being designed, at least originally, to be capable of stopping a detached tramcar but either a later modification or some other development reduced its effectiveness. The sanding equipment would certainly help with adhesion, though I don't see its mention in the report - perhaps it was not working for whatever reason?
The phrase in the report "in its present configuration", is certainly open to that interpretation.
