Lines where semaphore signals are still used
miklcct
2 May 2021
Cricklewood
When I visited Deal a few weeks ago, I was surprised that semaphore signalling, something which should have long gone into history, was still used there in front of a modern high-speed bullet train.
Where in the national mainline network are semaphore signals still used?
vic-rijrode
31 Aug 2016
There are still semaphore signals on the Newcastle to Carlisle route, together with some magnificent signalboxes - on a line used occasionally as a deviation by HSTs, bi-modes etc.
If they work and still do what is needed of them, why do they need to be history? They will get replaced in the fullness of time.
Parallel
9 Dec 2013
I think there are still some in Cornwall, around St Erth and Liskeard and probably a few others.
When GWR’s IETs were diverted via Yeovil and Honiton earlier this year, they ran via Yeovil Pen Mill which still has semaphores.
There are still some on the Marches route, if that counts as a main line.
InkyScrolls
20 Jul 2022
North of England
There are loads of them on secondary and branch lines around the British Isles. Of the routes I sign, Skipton to Carlisle and Skipton to Lancaster have quite a bit, including manually worked crossings.
There was a thread in 2021, (since closed), which looked at this from the perspective of trying to predict where the last semaphores would still be in operation, of course it also turned into a fairly long 10 page discussion of the then current locations:
Class172
Quizmaster
20 Mar 2011
West Country
As well as the previously mentioned Shrewsbury and Worcester, there's also Droitwich Spa, Malvern, Ledbury and (I think) Moreton-in-Marsh.
4COR
30 Jan 2019
W Oxon (UWL exile)
It certainly does, as does Norton Junction where the Cotswold Line joins the line to Worcester Shrub Hill, but I think sadly the junction signal with lower quadrant distant controlling the junction towards Oxford and Cheltenham is now an LED colour light.
Lucy1501
9 Nov 2021
Cumbria
On the whole network there are hundreds of boxes with lever frames, some of which don't operate semaphore signals (Like the Stockport 5), or just small semaphore shunt discs (Like St Helens). Not sure what you class as "mainline" but off the top of my head I can think of the following locations:
In England:
  • The Tyne Valley Line (Blaydon to Corby Gates)
  • The Cumbrian Coast (Wigton to Barrow-in-Furness)
  • The Furness Line (Barrow-in-Furness to Carnforth Station Junction)
  • The Bentham Line (Carnforth Station Junction to Settle Junction)
  • The Settle to Carlisle (Howe & Co's Sidings - Hellifield South Junction)
  • Bishop Auckland Branch at Shildon
  • Windermere Branch at Burnside Higher
  • Barton-upon-Humber branch at Barrow Road, Oxmarsh Crossing and Goxhill
  • Skegness Line (Sleaford - Skegness) excluding Thorpe Culvert, Sibsey and Sleaford East
  • Cornish Main Line (Lisekard to Penzance)
  • Parbold on the Wigan to Southport Line
  • Midge Hall on the Preston to Ormskirk line
  • Rainford Junction on the Wigan to Kirby Line
  • Ellesmere Port to Helsby
  • Plumly West on the Stockport to Chester route
  • Horrocksford Junction on the Clitheroe Line
  • St Helens on the Liverpool to Wigan Line
  • Ryde St Johns on the Isle of Wight
  • Bopeep Junction and Hastings
  • Worcester and Droitwitch Spa
  • The Cotswolds Line at Moreton in Marsh and Norton Junction
  • The Malvern Line (Henwick to Hereford)
  • The Derby to Stoke Line (Eggington Junction - Caverswall Crossing)
  • Parts of the Scarborough to York Line
  • Gristhorpe on the Hull to Scarborough line
  • The Harrogate Line (Poppleton to Harrogate)
  • The Whitby Branch at Nunthorpe
  • The Warrington Low Level Line (Fiddlers Ferry - Arpley Junction)
  • The Peak Forest Area (Great Rocks Jct & Peak Forest South)
  • The Buxton Line (Buxton - Furness Vale)
  • Glazebrook East on the Liverpool - Manchester Line
In Scotland:
  • The Stranraer Line (Kilkerran - Stranraer)
  • The Dumfries Line (Annan - Kilmarnock)
  • West Highland Line at the Pass of Brader (stone signals) and Fort William Junction
  • Cupar to Tay Bridge South
  • Stirling to Perth
  • Dundee to Aberdeen (exclusive)
  • Aberdeen to Keith Junction
  • Perth to Aviemore (excluding Dunkeld)
In Wales:
  • The Conwy Valley Line at Llanwrst
  • Deganwy and Llandudno Station
  • The North Wales Coast from Penmaenmawr to Holyhead
  • The Borderlands Line at Penyfford and Dee Marsh Junction
  • The Welsh Marshes Line between Gobowen North and Little Mill Junction
  • The Maesteg Branch at Tondu
  • Ferryside on the South Wales Main Line
I do appologise for the long post but I do hope that you find it somewhat informative!
tomuk
15 May 2010
Just to point out that the Marches and Chester Lines are by majority in England not Wales. Gobowen to Pontrilas including the biggest box in the world at Shrewsbury are all in England.
DelW
15 Jan 2015
Littlehampton, two pairs on brackets at the ends of the platforms.
IIRC some of the semaphores on the Cotswold line were only installed around ten years ago, when sections of the route were redoubled.
The exile
31 Mar 2010
Somerset
In England:
In Scotland:
  • Stirling to Perth
In Wales:
I think both Bognor Regis and Littlehampton stations are still bastions of semaphore signalling (though not 100%) as is the East end of Hastings station. Although this won't apply everywhere on the above lists, if there is no staff saving to be made by the abolition of semaphore and no operational advantage to be had, there's little point. After all - even the 1970s mas signalling schemes are now coming up for renewal and often in a more parlous state than the much older semaphore installations.
MadMac
13 Jun 2008
Moorpark, CA
In Scotland:
  • West Highland Line at the Pass of Brander (stone signals) and Fort William Junction
  • Stirling to Perth
Also: Perth to Dundee
Lugton
Longannet
On Aberdeen-Inverness, semaphores still remain at Insch,
Kennethmont, Huntly and Keith Junction.
The exile
31 Mar 2010
Somerset
I think the nearest to your part of the world is at Greenford - clearly visible from the platform - or has it fallen victim to HS2 construction work?
