Lincolnshire OAO?
Fermiboson
7 Jan 2024
Oxford/London/West Yorkshire
How much sense does an OAO serving Grimsby/Cleethorpes to London via Lincoln and Sleaford, or one serving Skegness via Sleaford, make?
I would presume the main issue is low population density and hence a relatively low demand, but there is a rather large area without good connections to London.
Iskra
11 Jun 2014
West Riding
LNER are doing London to Cleethorpes via Newark and Market Rasen. I’m not sure there would be much point in going up against them.
Any service to Skegness would be pretty slow and I’m not convinced there’s that much demand for journeys on that route.
class26
4 May 2011
A decade+ ago Hull Trains did plan such a service routing from Cleethorpes, Lincoln, Sleaford, Spalding and Peterborough. The reason given for not starting then was they didn`t want to start a service whilst work was ongoing on the Joint line but preferred to wait until it was all finished. Not sure what happened there ?
Grimsby town
4 Apr 2011
Grimsby is one of the biggest markets, not served directly on the ECML, with around 17k one way journeys. Only Huddersfield is higher with 18k journeys. Cleethorpes has around 6.5k one way journeys to London, Barnetby and Market Rasen add another couple of thousand trips so there's clearly a market there to be developed.
I'm not sure an open operator is the right way to go though. Lincoln already has the regular service that could be relatively easily extended to Grimsby a couple of times per day. It might even be possible to do that with the same unit that sits at Lincoln, although it'd likely be very tight and require the service to run non-stop to Grimsby.
An open access operator might look at running via Doncaster and Scunthorpe (around 12k journeys to London) but I think such a service would struggle to find paths and be financially viable.
Skegness and Boston only have around 7k trip to London each so are smaller markets. Spalding and Sleaford would add another 12k trips giving a total of 26k which similar to a London to Cleethorpes service but without the advantage of having an easy to extend current LNER ECML path. Looking to run weekend Skegness to London services to cater for the leisure markets travelling in both directions might be possible.
BenS
12 Aug 2023
Hull
Are these figures based on existing journeys?
Presumably an open access operator - which wants to make a profit - would also try to increase the overall market - either (1) by attracting people who currently use the car instead of the train, or (2) by making journeys easier - encouraging new journeys that would not have previously happened.
Obviously this has risks, because if you fail to increase the overall market, you fail to make money.
30907
They are existing journeys - with a change of train of course but they will give an indication of the potential of an improved service.
Indeed. Hull Trains is a good case - even more spectacular (under BR originally) is the Copy Pit route between Yorkshire and Lancashire, from one seasonal train to an hourly service in a few years.
They are only allowed a licence to operate if they can convince ORR that they’ll significantly increase the overall rail market. After that’s agreed they also have to show how they will not be primarily abstractive with respect to existing operators. Both requirements have to be met, but AIUI the increase to the overall market is mandatory..
HullRailMan
8 Oct 2018
So, using your figures (whatever the source may be) and then dividing them by the days the railway operated per year gives around 66 people travelling from Grimsby/Cleethorpes to London per day at the moment. Hardly a huge market for any commercial operator to risk anything on.
BenS
12 Aug 2023
Hull
Hull has approximately 3 times the population of Grimsby. Both places have some additional population in the surrounding areas.
If Hull Trains can run up to 7 trains per day to London, then in theory "Grimsby Trains" should be able to operate two services a day each way.
I realise that this is not a business case, and people putting their money into such a venture would want something more concrete.
Grimsby town
4 Apr 2011
The data is Lennon ticket data. It'll be an underestimate, as it won't include split ticketing occurring at Doncaster. Still it's not going to be huge numbers of people. It certainly could be a viable proposition though if only for a couple of services in each direction per day.
HullRailMan
8 Oct 2018
Yes, far too simplistic I’m afraid. The Hull metro area ( including Beverley and the west Hull villages) is significantly bigger and includes a university which generates inbound traffic. The stops at Brough/Howden/Selby generate as much traffic combined as Hull itself, with Brough having the most first class demand due to the wealth in the area - is there an equivalent on the Grimsby route? The biggest asset are the Doncaster/Retford/Grantham stops where HT has really grown the market and tapped into connecting traffic for bigger places like Sheffield and Nottingham. Again, what equivalent would there be for Grimsby?
The economics are also harder with fewer services as you have fewer seats to spread your fixed costs over. The only thing that might make a Grimsby case work is Lincoln (university and generally wealthier) but that market has already been tapped into by LNER.
I’m all for expanding services but I can’t see this working commercially so is best left to LNER and a subsidy, if at all.
MCR247
7 Nov 2008
Trains aren’t plans - they don’t pick up a full load of people in place A to take them all to Place B. They pick people up and drop people off on the way, so that destination population maths is essentially q
james_the_xv
29 Oct 2019
West Midlands
You can talk about passenger demand all you want but you're gonna struggle getting a path over the Welwyn Viaduct on a weekday anywhere close to peak time...
Grimsby town
4 Apr 2011
The population of North Lincolnshire is 330k. The population of Hull 2011 travel to work area including up to Driffield,Market Weighton, Hornsea, Goole and Howden is 520k. Add Bridlington and Selby and the surronding areas and you're up to around 600k.
This is the main issue which is why extending Lincoln services makes more sense
class26
4 May 2011
Most people I know in the area drive to Peterborough as it is felt going via Grantham is well out of the way. A direct service could well attract more. Recently a group of councilors from Sleaford (I know as my neighbour was one of them) ALL drove to Grantham for the London train as they didn`t want to change trains. Looking at present figures is misleading as I feel there is a hidden market
Grimsby town
4 Apr 2011
I don't think looking at existing figures is neccesarily misleading. Its likely that they're still relatively proportionate. Growing up in Grimsby, I know that a lot of people drove to Newark to catch London trains.
I think another problem with Skegness/Boston to London is that even with a direct service, there's probably still going to be people who drive to Peterborough because the rail line is pretty indirect and slow. If HS2 happened in full then destinations like Skegness might become possible. At the moment I think there are bigger priorities for a better service.
BenS
12 Aug 2023
Hull
The alternative is follow the route from Cleethorpes to Doncaster (same as TPE for services to Liverpool), and then head down to London from there.
This would give stops at Scunthorpe which adds population size, but probably not wealth.
A stop at Barnetby perhaps attracts people from the surrounding towns, some of which might be more wealthy, although that isn't a massive population.
Clarence Yard
18 Dec 2014
By the time the work has been done, the DfT had blocked off the paths from Peterborough with the TL timetable and the Lincoln via Newark service was on the cards.
The HT plan (actually done by GB Railways) was to go Grimsby, Market Rasen, Lincoln, Sleaford, Donington, Spalding, Peterborough, Huntingdon, Kings Cross with Stevenage as an option if it could be done.
Market Rasen was for Louth via the A361 and a reopened Donington Road (which was then a lorry park) was for Boston, being situated directly on the A52. An option for early first and late last trains of the day starting from/ finishing at Boston was also considered.
Fitting batteries to some TL units would allow for a similar service in future - at least as far as Lincoln, if someone ever wanted to do it.
southern442
20 May 2013
Wasn't there quite a far-fetched plan from Renaissance Trains to run a DMU service from Cleethorpes to Stratford via Lincoln, Peterborough, Cambridge and Bishops Stortford about 20 years ago? :lol:
