Likely strikes in Europe this summer
johncrossley
30 Mar 2021
Where in Europe can we expect strike action on trains and other public transport this summer? How much notice is there likely to be? Triangular trips are problematic during strike action so for visitors from the UK it is safer to book flights in and out of the same airport in case you can't travel between two cities due to strikes.
DanielB
27 Feb 2020
Amersfoort, NL
The Netherlands is likely to be strike-free in public transport this summer. NS was first with strikes, but has a new collective labor agreement since early this year.
What followed were strikes for the CAO OV (the collective agreement for regional bus transport), where the unions have reached a definitive agreement with the employers earlier this month.
Less sure is the situation with the CAO Multimodaal (collective agreement for the regional rail operators, partially also involving bus franchises) where negotiations have been finished but the voting for union members is still ongoing, so not yet sure they'll accept the result of the negotiations.
GVB Amsterdam, HTM The Hague and RET Rotterdam have seperate collective labor agreements, but I'm not aware of ongoing negotiations there. So risk for strike is relatively low.
The most significant threat to visitors is most likely the summer holiday itself: staff shortages are still very much a thing in public transport. It differs a lot from region to region: some have come from much worse situations and are on the way up again in service reliability, but other regions still have significant cancellations. Practically nowhere the full timetable is in operation at the moment.
For bus drivers, the labor market is just extremely tight. I've even seen reports that operators loose staff which elected to apply at another operator in a nearby region. And as the age is high, lots of staff retires as well.
My regional bus operator for example has already decided to run less-used routes using small neighboorhoud buses for maximum 8 passengers this summer. Those vehicles just require the same driving licence you'd need for a car, thus freeing up drivers holding a bus licence for the services needing a large bus.
popeter45
7 Dec 2019
london
european travel this summer really starting to look like a mess
the year that should be about the recovery of international travel is so far plagued by engineering works across germany such as aachen - cologne and around hamburg, capacity issues leading to compulsory reservations on Amsterdam ICE trains, unrealibility of Brussels ICE trains etc and now potential strike action
dutchflyer
17 Oct 2013
Germany (which I have to pass today coming from PL) untill a new deal has been set.
The areas where strikes are most prevalent should be known: Italy, Spain, France. Do be aware that these will mostly not be nation-wide but more often in smaller regions for some local reason and are often not known outside untill you hit such an area. Learn the eufemistic words for that; FR its ´mouvement social´ and never just ´grëve´, IT: scioperta. In theory there should in ES and IT be a minimum garanteed service in he normal peak hrs.
Driver shortage is so big that in NL sometimes when bigger rail-replacement is needed on a busy trunk line, buses get called from POland Slovenia and Slovakia.
