Map: https://www.openstreetmap.org/#map=14/52.2817/-1.4310
www.warwickshireworld.com
However the following suggests that the part of the route from Stonebridge Lane to the HS2 site is currently pointless and, if you walk it, you have to go back to Stonebridge Lane:
www.sustrans.org.uk
Has anyone walked/cycled this route recently?
Does anyone know when, if not now, it will be possible to walk from Leamington to Long Itchington without a lengthy detour?
New £5 million walking and cycling Greenway in Warwickshire opens to the public
It follows the ‘branch line’ of the old Lias Line railway route creating a safer, and more direct, link between Offchurch Greenway and Long Itchington.
The map suggests it is possible to walk from Leamington Spa to Long Itchington, except it is a bit unclear around the HS2 works, where it appears there is a temporary route until a new bridge is constructed:It follows the ‘branch line’ of the old Lias Line railway route creating a safer, and more direct, link between Offchurch Greenway and Long Itchington....
Lias Line
The Lias Line is a 23.4-mile route on the National Cycle Network, connecting Rugby, Leamington Spa and Warwick.
This will eventually take you over the Fosse Way once HS2 complete the bridge in 2024. In the meantime, to continue on the NCN, you will need to turn back and exit on Stonebridge Lane and follow signs that lead to Leamington.
