Leyland pneumatic throttle
d9016
23 Aug 2011
Can anyone confirm if it was just buses that had Leyland epicyclic gearboxes that had an air controlled throttle (TL11, 6LXB Olympians, Atlanteans, Tigers and Nationals)? Or were there any others (ZF/Voith Olympians, Lynxes & retrofit re-engined Nationals/Tigers)? I am also curious to know if the clutched manual Tigers had pneumatic throttle or clutch operation or if this was hydraulic from PSF. Also, was this a thing with Wilson boxed Bristol, Volvo and Daimler buses too?
CN04NRJ
28 Nov 2019
It's over 10 years since I drove one but from memory the two manual TL11 Tigers I've driven had pneumatic throttle at least. The clutch on them was virtually like an on/off switch, tricky to drive until you got used to it.
GusB
Elginshire
I'm not sure about the rest, but I recall a conversation with a driver some years ago, where he mentioned that the Royal Tiger (80s version) had an air throttle that required slightly different handling during gear changes to that of a standard Tiger. The two that my local bus company owned had hydracyclic transmissions.
d9016
23 Aug 2011
Was the clutch hydraulic?
Were the hydracyclic ones air throttle as well?
GusB
Elginshire
As far as I'm aware, but bear in mind this was in 1985 and it was anecdotal evidence only! The Royal Tigers only had Hydracyclic or ZF transmissions because of the higher output of the 245/260 TL11 engines. When the Cummins L10 (290bhp) was introduced later on, I think it was only ZF that was available for similar reasons (was an auto available as well as the 6-speed manual?)
Leyland Bus
20 May 2021
York
Hydraulic clutch, air throttle on the Tiger.
Last non Air throttled Leyland was probably the Atlantean bought by Greater Manchester who religiously stuck with a cable throttle on those... hth.
CN04NRJ
28 Nov 2019
Pretty sure the clutch wasn't pneumatic. Was an absolute nightmare trying to get them (and other Leylands) started on a very cold winters morning as you couldn't rev the engine up to keep it running so they'd keep cutting out.
Either that or you'd wear the battery down by trying to turn it over :lol:
Got a very poor quality potato phone video of me driving this back in the day, the sound isn't too bad though, you can just make out the noise when the clutch is engaged ;
d9016
23 Aug 2011
A pneumatic clutch sounds like it would be a nightmare to feel where the bite point is, anyone know what the fully automatic ZF/Voith Leyland Olympians had? I can see the Voith examples working with a pneumatic throttle setup since they shift hydraulically without trying to intervene with the throttle but I think ZF had a servo on the gearbox which controlled the throttle on some 4HP or 5HP, would these have used an electronic throttle pedal that was wired straight up to the gearbox control module?
Leyland Bus
20 May 2021
York
I'm pretty sure all Leyland Olympians had air throttles, the later Volvo model had fly by wire throttles.
