Level crossings
aylesbury
3 Feb 2012
The barriers on the line through Thetford the crossings have had many problems from motion detectors not working properly,so even the new technology is not perfect.Perhaps a man on the gates is the forward/backward?
Tomnick
10 Jun 2005
Would that be a reasonable response to a relatively very small risk?
Probably not, but that seems to be the logic certain other posters on this thread are pursuing.
And let's not forget, Network Rail has a policy to progressively close more level crossings (I'm sure I saw an advert boasting of how many had been closed recently), so someone in power obviously sees it as a "reasonable" response, regardless of what we think.
fsmr
11 Feb 2009
Might be worth reporting it to Network Rail if it's doing it frequently, if it's not just happening immediately after the barriers are raised. I don't know the exact figures off-hand, but they're usually set up so that the motor starts driving the barrier back up at a greater angle (from horizontal) than that at which detection is lost - i.e. they should sort themselves out before detection's lost. Should also indicate failed in the box too, if they do lose detection.
Thanks Tom yes they have been out to it a few times
Good job the yard is so close
They were on scene within a few minutes when the barrier got taken out that time by a LGV turning out the junction
Indeed they do, it's a particular bee in my bonnet. Almost 800 crossings have been closed in the last few years, mostly farm crossings, but a good number of footpaths too.
The cost of closing a crossing does vary, farm crossings are quite easy, some footpaths can be diverted (although the legal process can be prolonged), but anything needing a bridge is expensive and takes a long time, usually. To put into context there are about a dozen bridges being built now that I kicked off 4 years ago.
