Is there any convention on using lettering in route indicators? Sometimes they can be abbreviated line names, e.g MT = Main Through S = Slow F=Fast etc and I have seen them indicating location like the name of a town in which the line is heading
Leaving London Bridge (on the Southern side), S stands for South London rather than Slow.
It's all quite complicated there:
The platform starter signal route indicators can show
D,
C or
B
Plat 8/9/10/11:
D or
C
Plat 12/13:
D,
C or
B
Plat 14/15/16: don't actually have a route indicator. They just lead to section
B*.
D/C/B refer to the next 3 signals out (left to right). The route indicators on these can show:
D:
M (
Main) or
L (passenger
Loop)
C/B:
U (
Up main, wrong direction) or
S (
South London)
M is the Down Main (which at Blue Anchor Jct about a mile and half from London Bridge splits into the Down Fast and Down Slow)
U is the Up Main in the wrong direction, but only for one signal section after which you're routed back onto the Down Main
S is the Down South London which splits at Spa Road Jct into Down South London and Down Reversible (which, in effect, is the up slow as in the Up direction it merges with the Up Fast to become the Up Main at Spa Road Jct)
L would be a wrong route for Southern - not sure that anyone signs it any more (FCC/Southeastern might)
Basically if you're heading for South Bermondsey you need
B+
S or
C+
S or (from plats 14-16) just an
S on the second signal. If you're heading for New Cross Gate you need
D+
M. Except you can take an
S and still get to NXG by taking the Down South London, then onto the reversible at Spa Road, via South Bermondsey Jct, to Bricklayers' Arms Jct (and so onto the Down Slow or Down Fast just before NXG), or stay on the Down South London to South Bermondsey Jct, and take the Down Spur to Bricklayers' Arms Jct.
Got all that? Good.
*There is an A section: the last signals before entering the station are A,B,C,D, left to right, but A is only signalled in the Up direction so you can't leave London Bridge via A section
