Leicester - Chester via Sheffield & Manchester
bb21
Emeritus Moderator
4 Feb 2010
Folks,
Simple question. Is a Leicester - Chester Anytime Return (SOR) valid via Manchester on fast trains between Sheffield and Manchester?
I'm planning the above journey in the morning peak for some day next week. Wouldn't mind a longer journey as long as it takes me into Manchester city centre circa 1030.
The Routeing Guide gives map PS as a valid route which appears to allow travel Leicester - Sheffield - Chinley - Guide Bridge or Bredbury - Manchester - Chester, unless some obscure easements restrict it. However this takes the slower route between Sheffield and Manchester.
Looking at the map, it would appear that Sheffield - (fast) - Manchester - Chester would not be allowed as this causes double-back between Manchester and Stockport. Does this mean that if I take the fast trains I'd have to buy a separate single Stockport - Manchester?
On second thoughts, it appears that going Manchester - Wilmslow - Crewe - Chester avoids Stockport. Does this mean that Leicester - Sheffield - (fast) - Stockport - Manchester - Wilmslow - Crewe - Chester is a valid journey on this ticket? If so then it would be valid for BOJ at Manchester.
This saves me approx £6 compared to a Leicester - Manchester Stns SOR ticket.
Any comments appreciated.
OwlMan
25 Jun 2008
When do you want to return, the same day or later?
Peter
Lampshade
3 Sep 2009
South London
It would be valid for BoJ in Manchester though, as Leicester > Sheffield > Manchester > Warrington/Altrincham > Chester is permitted.
John @ home
1 Mar 2008
I agree that Leicester > Sheffield > Manchester > Altrincham > Chester is Permitted (map PS). I can't find a map combination which permits Leicester > Sheffield > Manchester > Warrington > Chester.
OwlMan
25 Jun 2008
A cheaper way is to used split tickets.
Assuming that you catch the 0757 from Leicester and arrive in Manchester at 1002 the following will work:
Off Peak Return (SVR) Leicester to Shireoaks or Worksop Route Sheffield £26-80
(Validity code BT - valid after 0430 out & return)
and then:
Off Peak Return (SAV) Sheffield to Manchester £17-50
(Code 2M - valid on arrivals in Manchester after 0930)
Total £44-30
They may be cheaper splits that I haven't found yet
I would assume that the Chester ticket is priced via Nuneaton & Birmingham.
Peter
krus_aragon
10 Jun 2009
North Wales
I seem to recall that tickets between Nottingham and Chester/North Wales are valid via Sheffield and Manchester, which may be helpful.
Also, there are some cheap day return tickets from Nottingham to North Wales resorts (such as Prestatyn) which may be cheaper than a SOR for a day trip, to Manchester.
bb21
Emeritus Moderator
4 Feb 2010
Do you want to visit Manchester?
Yes, a day trip to Manchester next Wednesday.
Normally I split at Nottingham taking advantage of the CDR from there but it's only valid after 0900 so no good here.
Valid splits would be great but I must be in Manchester before 1030. Advances for outbound is fine but not return.
It seems the long way round via Manchester on a Chester ticket so I don't want any unnecessariness from the train manager or at the gateline in the morning as I would be in a rush.
Off Peak Return (SVR) Leicester to Shireoaks or Worksop Route Leicester £26-80
and then:
Total £44-30
Peter
Nice one :lol:
MichaelAMW
18 Jun 2010
Leicester - Derby SDR at 10.60 plus Derby - Prestatyn CDR (Available 07.15 onwards) at 21.40, total 32.00 seems to be an improvement.
You'd have to 'claim' that your route, on map PS, is Sheffield - Stockport - Manchester - Crewe via Styal - Chester - Wales.
Michael.
Lampshade
3 Sep 2009
South London
I don't see why it wouldn't be valid on the direct ATW service via Warrington Bank Quay :?
MichaelAMW
18 Jun 2010
As far as I can tell - only had a quick look - there is no mapped route with *both* Sheffield - Manchester *and* Warrington - Chester. I think the only permitted route via Warrington - Chester is Derby - Tamworth/Birmingham - Warrington - Chester.
John @ home
1 Mar 2008
I don't see why it wouldn't be valid on the direct ATW service via Warrington Bank Quay?
It's not valid by the rule
National Routeing Guide said:
Is the customer travelling on an advertised through train? -->
--> Yes -->
--> The route is a permitted route for that journey.
because the ATW service is not a through train between the origin (Leicester) and destination (Chester) on the ticket.
