Leeds station improvement updates
xotGD
4 Feb 2017
I enquired about the status of the LMS canopy that is being removed with Network Rail, below is the response received:
Good Morning,
Thank you for taking the time to submit your service request.
We can confirm that the canopy will be removed as it's expiration date is upon us and we do need to replace in line with our safety requirements.
The canopy is not a listed feature and was known as a heritage roof due to the visual look only.
If you would like to keep up to date with the 'Platform 0' project please see:
https://www.networkrail.co.uk/runni...tes/north-and-east/leeds-station-improvements
Once again, thank you for taking the time to submit your service request and interest in our project.
Kind regards,
Catherine Herbert
I've just noticed that the artist's impression shows a 321/322 in Plat 2. Staying a bit longer than planned, perhaps?
I'm somewhat sceptical of platform canopies having an 'expiry date'
Really it's a shame it wasn't included as part of the Wellington concourse's listing.
Rikki Lamb
24 Jan 2019
I think it is just coincidence an image of those units was used, I'd hope they're staying around abit longer too given they actually work!
Rikki Lamb
24 Jan 2019
Me too, I don't think they are in danger of falling down.
It is probably PR spin on the part of NR.
YorksLad12
5 Feb 2020
And a ScotRail-liveried 170 coming into Platform Zero (I think they mean Platform 0). In retrospect it looks a bit like Bradford Forster Square. That's not a compliment.
Speaking as a Spin Doctor it's probably more that they're repeating what they've been told by someone, somewhere. The canopy would have to be hacked back to the point where it might as well be replaced, especially if the northern-most set of supporting columns has to come out to allow the track to run behind the car park. Which could then make it a safety issue, as the remaining structure might not be as stable.
I may be doing them a disservice of course, and there may well have been an engineering note upon completion at Leeds 1st that said "Oh - don't forget to remove the old Midland Railway canopy in 2020, it'll be rotted through by then"... ;)
The sad thing is that it was built for a double sided platform, so had they laid the track where the second platform face used to be, there would have been no need to hack anything back.
Halifaxlad
5 Apr 2018
The White Rose County
Good Morning,
Kind regards,
Catherine Herbert
Go and ask them when they will be removing the identical canopy at Bingley!
thejuggler
8 Jan 2016
I was in Leeds today for the first time since this year. Anyone know if/when new flooring will be fitted?
Halifaxlad
5 Apr 2018
Does anyone know if platform 1 will be straightened up at all ?
I just wondered since NR is going to great lengths to remove the canopy and straighten up the other side so that the width is equal all the way down, would be a shame if they didn't go the whole hog and have it aligned with platform 2.
johntea
29 Dec 2010
It would be nice for them to find someone to fix the Platform 6-8 down escalator!
Bantamzen
4 Dec 2013
Cheshire
Or have an additional stairwell / escalator to service P1-6, instead of having the usual peak time scramble as passengers rush for connections on P9-17....
YorksLad12
5 Feb 2020
New leaflet sent to residents (presumably also available from your usual stockist). There's some work coming up until the end of April, which involves "demolishing part of the existing platform 1... The nature of the work involves excavating and re-constructing platform 1 and removing the existing roof structure." Since Christmas they've "also been busy dismantling part of the old wooden roof on platform 1 and carrying out some reconstruction work at the ends of platforms 2 & 3."
I'll share any photos I manage to take of the work from this side of the river.
YorksLad12
5 Feb 2020
Following up on my own message (sorry): a photo showing what's left of the platform canopy. Not very much. The holes in the remainder are so a claw can lift them off and drop (not place, drop, loudly) them to the side when they do the work at night. At this pace the ribs and supports might be gone by the end of the month.
YorksLad12
5 Feb 2020
This comes up every few years. The first plan was for East Leeds Parkway near Micklefield, handy for the A1(M). Then there's the station at Thorpe Park to serve businesses and the new housing on the old Barnbow site, which might not come until electrification happens. But then one of Garforth or East Garforth might have to close, or they'd need to four-track. So who knows? Marsh Lane as a station has no business case; but as a turnback facility it might (although you'd hold everything up while units re-cross the tracks, unless you built a dive-under or flyover).
Failing that, perhaps park the LNER set that hogs platform 8 for 30 minutes of each hour 50m further east when it arrives, extend the western end of the platform slightly and you've got a whole extra 100m platform to play with at platform 8A. Run the Doncaster stoppers off that, move the Huddersfield stopper to 10, the Leeds-Sheffield semi-fasts to 13 and they could all be longer trains. And if the train in 8A breaks down or is delayed, add a set of points so that the London train can bypass using the track on platform 9 (it merges together a few metres further along anyway). Not that I know anything...
AndyHudds
17 Jun 2012
In the consultation for Thorpe Park it clearly states that it won't be built at the expense of either of the Garforth stations or Micklefield.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
I'm pretty sure that platform 5 is supposed to be extended to accommodate 10-coach Azumas (Someone correct me if I'm talking complete nonsense). All other Leeds NW services will be shifted one platform down.
Wharfe106
25 Aug 2019
Wharfedale
That's how I understand it, 5 and 6 for LNER, 0-4 for Triangle/Harrogate etc, leaves 8 free for other stuff, and with many LNER trains reversing to H'gate or Bradford, there will be some capaicity on 5 and 6 as well, I think?
YorksLad12
5 Feb 2020
Ah - didn't realise that the other platform extensions were for 10-car Azumas. Aren't those extensions delayed? Haven't been down that way for a while, so relying on a Google Earth view; but that's going to be some work to extend P5 (and presumably part of P4) and move the track northwards. But it might allow P8 to be used by CrossCountry in both directions (thus no need to lifts or escalators with luggage), which has to be a good thing.
ASharpe
4 Feb 2013
West Yorkshire
Is it just me or does the new concourse need a proper clock - not just the little LEDs at the bottom corner of two small screens.
There are a couple of decent (older) clocks through the barriers onto the platform and they are much easier to read provided you have a clear view.
Or do I need to go back to wearing a watch or get my phone out?
61653 HTAFC
18 Dec 2012
Platform 8 is the longest platform at the station, so I'm not sure prioritising 4/5-car Voyagers there is the best idea.
Given the usage at Leeds, the main footbridge is woefully inadequate as are the stairways and escalators. If only we could turn the clock back to the late 90s and build for the growth that followed. Perhaps a more suitably-sized "transfer deck" will come with HS2?
Skipton and Bingley are glazed, and form part of a "matching set," unlike Leeds in both respects.
The ridge and furrow designs are clearly of a common (Midland) family though, as are the stanchions.
Also things don't have to match to aesthetically benefit the environment.
quantinghome
1 Jun 2013
Leeds 1st was built to a price. Nevertheless the new bridge is far better than the underpass it replaced. I guess no one thought to design the thing for a tripling of passengers. Or they didn't have the money. Clogging it up with retail doesn't help much.
A new transfer deck is indeed planned as part of the station rebuild, which will connect to the HS2 bit.
Page 13 of the link below shows an image of what the new high level concourse might look like, looking southwards I think. It shows access left and right to the existing platforms and the HS2 platforms ought to be at the far end although not easily visible here. On the left are, I think, escalators down to the area of the existing main concourse.
https://southbankleeds.co.uk/assets...ds-Integrated-Station-Masterplan-LR-v6-DS.pdf
The new common concourse:
• provides direct links with high speed rail platforms.
• redefines the access to all existing platforms.
• provides new waiting areas.
• enhances kiosk food & beverage offerings.
• enhances passenger facilities & experiences
The existing West Overbridge & recently completed Southern Entrance:
• the east, west and central overbridges are about a holistic solution, so the existing western bridge has been retained to provide flexibility and choice for all users as part of a holistic solution.
• adapted to provide greater future capacity.
This is only a masterplan, so may be more of an architect's vision than an actual prediction.
61653 HTAFC
18 Dec 2012
Thanks for that. The image looks sort-of like what I was picturing in my head (though I wasn't imagining it looking like a greenhouse!) but I'd hope those planters and retail spaces (nice though they are!) are shelved. Otherwise it'll just repeat the issues of the existing bridge.
NorthernSpirit
21 Jun 2013
From what I've seen in that PDF is that the recently installed new front entrance will be ripped out and the bus interchange banished to make way for a Bishopgate Plazza. It don't make any sense whatsoever as where are you suppose to get your bus from once you exit the station?
I wouldn't say no to a glass roof though as it'll brighten up the platforms with natural light, maybe the developers could stick with that and widen the main footbridge wilst they're at it. Owt else will simply get in the way such as retail units or planters.
