Leeds disruption again Saturday 09 August
30 Apr 2025
Calder Valley
Any ideas what the issue is at Leeds please , multiple cancellations on the Calder Valley since about 4pm . Another day of network rail disruption...Blackburn had a points failure around start of service today .
skyhigh
14 Sep 2014
Loss of signalling between Leeds and Bradford Interchange.
Last update I saw suggested potential cable theft.
Intercity_225
13 Jan 2024
March
The National Rail website says the following:
Service alteration details
Incident reported: Saturday 09 August 2025 at 16:26
If you would like to follow this incident on X, please useLeeds
Last updated
Saturday 09 August 2025 at 17:30
Train operators affected
Northern
TransPennine Express
Route(s) affected
Northern between Leeds and Wigan Wallgate / Manchester Victoria / Chester, between York and Blackburn / Blackpool North
TransPennine Express between Brighouse and Manchester Victoria
Description
A fault with the signalling system at Leeds means that some lines are blocked. Trains running between Leeds / Brighouse and Hebden Bridge may be cancelled or delayed by up to 60 minutes.
Major disruption is expected until 18:00.
Northern customer advice:
Network Rail engineers are on site to investigate the fault.
Rail replacement road transport has been requested but there is no availability at this time. Should this change, you will be updated here.
To help you complete your journey, your ticket can be used at no extra cost on:
East Midlands Railway
Manchester Metro services
TransPennine Express services
If the train you have a ticket for is cancelled, you can travel on any Northern, TransPennine Express or LNER service within 2 hours before or after your cancelled service was due to depart
Alternatively, customers at Manchester Piccadilly can travel to Leeds via Sheffield.
TransPennine Express customer advice:
To help you complete your journey, rail replacement transport has been requested to run between Manchester Victoria and Brighouse in both directions.
The following times for rail replacement transport:
Departing xx:30 at Manchester Victoria to Brighouse calling at all booked stations.
Departing xx:58 at Brighouse to Manchester Victoria calling at all booked stations.
Please see station information posters for the location of rail replacement pick up points and be advised that journey times may be extended by 90 minutes whilst travelling by rail replacement transport.
Your ticket can be used at no extra cost on:
Metrolink services between Manchester Victoria and Rochdale in both directions until 19:00
Andyh82
19 May 2014
Looks like nothing east of Hebden Bridge with a very limited bus service
And of course Huddersfield/Dewsbury is blocked this weekend due to TRU works so there is no alternative (except via Sheffield)
skyhigh
14 Sep 2014
Second time this week there has been cable theft in that area - couldn't have come at a worse time really with the only real diversionary option shut too.
Andyh82
19 May 2014
Northern ultimately issued a ‘Do Not Travel’ notice for Leeds to Bradford/Halifax/Manchester and Leeds to Blackpool North
There were reports of availability of replacement buses being very limited
M60lad
31 May 2011
I was caught up in this yesterday and had a South Pennine's Rail Ranger now normally I don't think these are valid either via Rotherham or on Cross Country services via Wakefield, considering yesterdays disruption would I have been Ok to use it any permitted route? I asked at Northern Ticket Office at Leeds Station and they said I could go which ever way I wanted to Sheffield.
There were also problems yesterday morning on Hope Valley line as a freight train managed to disgrace itself in Totley Tunnel blocking the route in both directions for a couple of hours.
Mcr Warrior
8 Jan 2009
That earlier issue was being discussed here...
YorkshireBear
23 Jul 2010
If I remember rightly the south Pennines day ranger was valid in XC services Westgate to Sheffield, but not the stoppers. It was an oddity when I did them loads as a teenager (nearly 20 years ago now mind).
Iskra
11 Jun 2014
West Riding
That was valid yesterday as Northern were routing Manchester-Leeds passengers via Sheffield.
Point 28.2 of the Conditions of travel would have allowed it though even if they hadn’t explicitly stated the above.
It’s valid both ways according to the map.
John C
3 Dec 2011
Looks like for the second Saturday in a row the Calder Valley is at a stand still due to a track circuit failure between Manchester Vic and Rochdale. 1J07 at a stand in Todmorden with engines shut down.
Bantamzen
4 Dec 2013
Cheshire
Yep, currently stuck at Warrington BQ on the 09:50 to Leeds going nowhere. Sounds like ticket acceptance has been organised on Metrolink to Rochdale, but it's not clear if anything is running from their.
So with this, Huddersfield and Stockport closed travel across the north of England is pretty much stuffed, again.
Bantamzen
4 Dec 2013
Cheshire
Is Manchester->Sheffield also closed today?
No but it's going to be chaos, if that's the only route. But for me it's getting worse, now moved across to a TfW 197 to get at least to Manchester, and this double 197 is having traction issues and hasn't moved.
pokemonsuper9
20 Dec 2022
Greater Manchester
The crowd here at Manchester Victoria is getting lighter, it appears there is a 10:45 bus to Todmorden.
I'm going to stay here and just hope
skyhigh
14 Sep 2014
Line is about to (or has just) reopened with a reduced service.
Bantamzen
4 Dec 2013
Cheshire
We're finally heading in the right direction, I'm hoping by the time we hit Victoria (after transferring from Oxford Road) things will be moving a bit. Going via Sheffield isn't really an option if I want to be in Bradford for a 3pm kick-off.
800001
24 Oct 2015
Why would the train have its engines shut down? Surely needs them on for lights, air con, toilets etc?
Bantamzen
4 Dec 2013
Cheshire
Just leaving Manchester Victoria as I type, on what was the 10:21 to Leeds. Ironically this was formed off the canned 09:50 from Warrington BQ, which was my original service... Hey ho...
John C
3 Dec 2011
Don’t know but it arrived, sat in the platform for 10 minutes or so then the engines were switched off and passengers let off to stand on the platform if they wished, 1J07 was eventually turned back towards Leeds as 1J06.
hawk1911
3 Oct 2016
Stafford
I got caught in yesterday's chaos. I was at Manchester Victoria just after 09:30. I was advised to get the tram to Rochdale (as were many others) to pick up a train from there to Bradford but, having got there, we were told no trains from there either and no replacement transport either. As Northern's representatives refused point blank to help (no replacement buses, no taxis provided), I ended up paying £35 myself (and a fellow stranded passenger) for a taxi to Hebden Bridge, to pick up a Blackpool to York service to Bradford.
It was well worth it, with another great performance by City and at least the return journey went a lot better.
Now onto the "fun" of trying to get Northern to reimburse my taxi fare. Why oh why does it aways seem to be Northern who refuse to help stranded passengers?
pokemonsuper9
20 Dec 2022
Greater Manchester
Where were the staff saying that? I certainly didn't hear any of that, all the announcements at Victoria were saying to go via Sheffield for Leeds, with people only being advised to get the tram if they want Rochdale.
I saw a 10:45 and 11:45 bus to Todmorden appear on the boards, but I can't imagine many people got it.
