Leeds Disruption - 26/07/25
zjc
27 Oct 2016
Anyone know what’s happened at Leeds that’s taken nearly everything out in Leeds and everywhere around?
A ‘do not travel’ warning has now been issued for the city’s main train hub and hundreds of passengers across several services have been impacted as a result of the closure.
“A fault with the signalling system in the Leeds area means all lines are closed,” the statement said.
“ No trains are able to run to / from / through Leeds and will be cancelled, delayed by up to 120 minutes, revised or diverted.
“Leeds station is currently closed.
“Major disruption is expected until the end of the day.”
londonmidland
22 Dec 2009
Leicester
Major signalling problem at Leeds affecting all services.
TPE on X are now stating that the station is closed.
Leeds station will be closed from now until further notice due to a fault with the signalling system.
Horizon22
Jobs & Careers
8 Sep 2019
NRES refer to a signalling fault. Something this large would suggest a complete loss of signalling in a panel(s)
A fault with the signalling system in the Leeds area means all lines are blocked. Trains running through this station may be cancelled, delayed by up to 60 minutes, revised or diverted.
Customer advice
CrossCountry
Trains may be diverted via Doncaster.
Trains will not call at Wakefield Westgate and Leeds.
Your ticket can be used, at no extra cost on the following services:
  • The two CrossCountry services operating before and after your cancelled service
  • TransPennine Express services on any route via Doncaster
Road transport has been requested to operate between Doncaster and Leeds / Leeds and York and depending on availability, extended to Wakefield Westgate.
Crossover
4 Jun 2009
It’s a mess. It’s not just Leeds station. Trains are stopped as far out as Church Fenton (York bound) and around Micklefield (both directions)
pdq
7 Oct 2010
My train from Manchester to Dewsbury is stopped at Sowerby Bridge
Crossover
4 Jun 2009
A few things are moving, but it may be just getting trains into stations. A train may have also set back to Cottingley
A fault with the signalling system in the Leeds area means all lines are blocked. Trains running through this station may be cancelled, delayed by up to 90 minutes, revised or diverted.
The disruption advice on NRE (link above) does not reflect the alleged new policy that DFTO passengers (ie those on LNER/TPE/Northern trains) can use each other's services without formality.
800001
24 Oct 2015
It does? LNER/TPE and Northern all staying there can use each others services.
And it is not an 'alleged' new policy, it IS policy.
wilsontown
11 Feb 2012
Also nothing via Harrogate to York because of an issue at Cattal. And York races today. Going to be carnage.
trickyvegas
10 Dec 2009
I'm supposed to be on the 1944 Newcastle to Manchester. At the moment TPE are saying it's running, but I'm sceptical.
At that time it would be too late to get home via Carlisle. Are they on the hook for a hotel if I'm stranded?
merry
19 Oct 2011
Of course, AIUI Conditions of Carriage clause 28 requires all operators party to the conditions - including the listed Open Access operators - to assist passengers during disruption (where reasonable), so this "acceptance" lark's formality has no real force anyway (unless there really is no room at all, i.e. unreasonable!).
And AIUI yes, operators are indeed on the hook for taxis and/or hotels if they can't get you to your destination.
Those caught up in it have my sympathy though, and I would not want to be one of the staff on the ground in these circumstances either!
Segedunum
International Transport
22 Dec 2013
Up North
I was meant to get the 1858 Manchester Vic to York then change for Newcastle. I've simply sacked it off and gone to spend the night with a friend. All being well tickets will be accepted tomorrow, but I dread to think what time I'd be home (if at all) if I tried to travel.
800001
24 Oct 2015
jump on first available train Newcastle to York/Leeds changing for a train to Manchester.
Howardh
17 May 2011
I was at Hebden Bridge trying to get back to Bolton, everything cancelled to Victoria so paid extra to go via Blackburn.
There's no other way to Leeds so I imagine anything running will have pax on the roof!
Screenshot of, well, nothing running!
800001
24 Oct 2015
LNER stating tickets will be valid tomorrow, not read anything about other TOCS (yet).
anothertyke
23 Jun 2023
How about getting the 1902 to Doncaster and the 2043 from Donny to Manchester?
Howardh
17 May 2011
Where I was at Hebden Bridge I could have caught a bus to Rochdale using my bus pass, and from there a bus or tram. Wish I'd thought of that as I'm now over a tenner out of pocket!
But at least back in Bolton in time for a pint.
Meanwhile feel for those at Hebden Bridge Pride trying to get home who might be unfamiliar with options.
Howardh
17 May 2011
A lot of hotels in Leeds and surrounds are full as I tried to book on Thursday. Will need a ton of taxis??
Howardh
17 May 2011
Cross Country are saying all lines will reopen shortly!
What about TPE and Northern?! Cross Pennine trains were packed when everything was running normally this afternoon. Be crammed and some later if services are restored
Mcr Warrior
8 Jan 2009
TPE have announced that due to the severity of today's disruption (Leeds) TransPennine Express tickets dated today 26/07/25 can be used on TransPennine Express services, tomorrow, 27/07/25.
Possible that some of their trains from the North East across to Manchester will be re-routed avoiding Leeds, depending on how far the signal problem extends, albeit with longer journey times.
norbitonflyer
24 Mar 2020
SW London
I thought there were a lot of smartly dressed people at Leeds this morning waiting for the York train.
Meanwhile, I seem to have dodged a bullet, as I was doing the Ribble Valley line (Clitheroe to Hellifield, Saturdays only service) today - original plan was out via Manchester and back via Leeds, which means I would be somewhere near Settle, haeding for Leeds, about now. But I decided to have an early start (0735 from Kings Cross) and do it the other way round, which means I'm already back home in London!
And I have now, I think, travelled on all lines in England with a regular passenger service (there is one in Wales, and several in Scotland, still to do........)
Iskra
11 Jun 2014
West Riding
Wow, just what you need on an already hectic payday Saturday in Leeds. I’ll set off in good time for my commute into work this evening. Also, if people are stranded overnight, the hotels are already rammed this weekend, so it could be a good night for taxi drivers.
8 Feb 2021
Manchester
Leeds East WS controls Ulleskelf to Church Fenton & Hudds WS controls Mirfield so can’t divert away from the problem sadly
