Least reliable diesel loco in preservation
amahy
9 Dec 2024
West Dunbartonshire
Having just seen an equivalent thread for steam, I have been inspired to create one for diesels.
Deltic D9000 "Royal Scots Grey" immediately comes to mind.
SECR 65
2 Apr 2026
East Sussex
I feel the need to contribute Class 73 E6040 'The Bluebell Railway'
With no disrespect to the owner and the hardworking team who maintain it.
A couple of years ago it failed in section running light engine and had to be rescued by a (purple) steam loco 80151!
43096
23 Nov 2015
So one failure makes it the least reliable diesel loco in preservation? :rolleyes: :rolleyes:
SECR 65
2 Apr 2026
East Sussex
No - it has a habit of failing:
Diesel gala 2025 it had an issue with the 27 way cable.
Ahead of the 65th Anniversary gala it sat down whilst shunting
Diesel gala 2024 is wasn't included in the original lineup as it was experiencing issues of some sort
A month or two ago it gave up for a few weeks.
We have the santa special incident I mentioned above.
Methinks there have been other instances of issues with the engine which currently escape my memory.
Forty29
10 Dec 2021
Bicester
58023 doesn't seem to have had a good start in preservation and always seems to suffer some sort of coolant issues. Did these locomotives have these problems when working on the national network with British Rail?
xotGD
4 Feb 2017
Based purely on reputation, surely it has to be a Class 31?
Rail Quest
8 Apr 2023
Warrington
56006 seems to have had quite a few failures in it's early days in preservation, but that's probably just emblematic of how locos behave having been recently restored back to working order. 58023 is another example of this. Must be said though: props to the hardworking volunteers working on both of these locos! They've done a phenomenal job in getting both locos back to a working condition at all and, with time, all the issues will be ironed out.
158760
23 Sep 2023
England
It has an unfortunate habit of failing at the most inconvenient times, and therefore sticking in people’s memories a lot more than it normally would.
Harpo
21 Aug 2024
Newport
If you are referring to the Network Rail Class 97s, they are not preserved.
Nothing that runs is truly preserved, it’s just being life extended by burning through consumables, some of which will eventually run out.
DarloRich
Fenny Stratford
Quite - what metric are we using here? I have been out several times for events where loco's have broken down but I have no idea how reliable they are generally.
or the horrid 97s
Why/how are they "horrid"? Regardless they don't often run on preserved railways.
Harpo
21 Aug 2024
Newport
(tongue firmly in cheek) That D5705, hasn't turned a wheel in revenue-earning service since I saw it engineless at Coalville Open Day 1986. Must be unreliable. ;)
D5705 has done exactly what was expected of it since withdrawal do maybe it’s the most reliable diesel? ;)
Merle Haggard
20 Oct 2019
Northampton
Well it seemed back in the day Tinsley's 47 loco availability status (usually very high) was only taken early in the morning - before they tried (often unsuccessfully) to start any of them up. So on their basis it would be 100% available :)
43096
23 Nov 2015
Rather similar to something a very senior EMT peson told me a few months after the start of the franchise... "158xxx is the most reliable unit in our fleet. It's never failed for us. It's also never been off the depot yet because of the state we received it in."
xotGD
4 Feb 2017
Here it is on the front of a freight train in 1993...
d5705-jpg.90396
tumbles
13 Aug 2020
Portishead
No point arguing over this until the Metro-Vick is in service again, then it should be obvious
Think they are carrying out a lot of the modifications that the Aus/IRE variants had in hope it should be more reliable. Cylinder Liners from the V12 IIRC
amahy
9 Dec 2024
West Dunbartonshire
Dragged, for photographic purposes. As at January 2026's Society update (link below) its Crossley engine is still being restored to operaable condition.
Indeed. D8233 could also be a candidate for the least reliable when that is restored!
Saying this about the Class 15 and 28, Class 17 D8568 has become a reasonably reliable runner!
tumbles
13 Aug 2020
Portishead
Even on both its engines last few years I think!
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
How many of these failures are due to the engines not being used enough; i.e., not being run enough to keep everything in working order. I'm sure if my car sat on the drive unused for weeks at a time, I would struggle to start it
This is a fair point. Locos don't like sitting around, no surprise then you get sticking contactors or other issues. Some are easily solved, some require a little longer to sort.
alexl92
12 Oct 2014
One caught fire on an Embsay and Bolton Abbey Polar Express train last Christmas.
31452? Did it now?! I wondered why we hadn't seen it out in a while.
58023 gets my vote - it only does galas and I don't think it's made it through one yet.
Forty29
10 Dec 2021
Bicester
58023 that's when it actually makes the gala. Fair play to the engineers lm sure they do their best and out of their control failures occur.
It's next gala is the East Lancs next month so here's hoping!
