That's an unusual reason. Are there any other types of train you've not been able to ride on that much?I can't think of a unit that I don't like, or like the least, probably the 165s, because I haven't been able to ride on them that much
It depends which ones you're talking about..
http://www.youtube.com/watch?v=wyCl5GnaRjo&feature=related
I have only been on Voyagers twice, but can't recall any toilet smellyness and managed to find a seat (no window to look out of though, at least the 2nd time, just a solid wall), just that claustrophobic feeling which I can't explain.220/1's - usually too crowded & anywhere near the toilet is usually too smelly
Had a ride on a Northern 150/1 the other day. Forget rattles, it was more like a bang when we passed other units at speed.So, voyagers aside, I'd have to go for the 150/1
I find that the windows rattle everytime another train goes past
I'd have thought a class 158 would be a perfect regional express unit. I've heard 158s described as a 'Jack of all trades, master of none' unit before, but regional express services (eg. the Fishguard Flyer, Cardiff - Portsmouth and Aberystwyth - Birmingham) seem to be composed of a mix of branch lines, express mainlines and lines that seem to fit somewhere between the two. Therefore, it would seem to me that a 'Jack of all trades, master of none' unit would not be 'master of none' at all, but would be master of regional express services given the diverse nature of the track covered.158s annoy me, since they are such a bodge of a design that is neither fish nor fowl (neither express nor local train) that is OK for some of the bits-n-pieces services in the Midlands and Northern England, but ought to be kept out of Scotland and off the former Alphaline routes. Replace them with proper express stock on expresses (100mph and better internal facilities) or proper regional stock (decent low-end acceleration with no need for more than 75, with a comfortable but basic interior).
However, I've heard mixed comments regarding acceleration of various types of unit. Is there an official source of charts showing acceleration to different speeds, eg. 0-50, 0-75 and 0-90, of units (I'm most interested in Sprinters (inc. 158) and 175/172/170).
Thanks. The 170 seems even more stupid now, with an outer-suburban door layout I'd expect them to be good for stopping services, but if their acceleration is that poor then they should be better for services with long distances between stops, but the door layout is wrong for that.I don't have a chart, but 0-50 I'm pretty sure the list is (between the units you mentioned):
Fastest Accelerating
172 (485hp per engine 75mph*/100mph) (Mechanical Transmission)
175 (450hp per engine, 100mph)
158/159 (400hp per engine, 90mph)
158/159 (350hp per engine, 90mph)
150 (285hp per engine, 75mph) (Same engines as 153/155/156 but lighter as only 20m)
153/155/156 (285hp per engine, 75mph)
142/143/144 (230hp per engine, 70mph) (Not sure about individual types, but Pacers accelerate quicker than a 170 but slower than a SuperSprinter)
170 (422hp per engine, 100mph) (Very Slow)
Slowest Accelerating
*Not sure if LO units are geared differently or just limited
Adam![]()
However, I thought different units have better acceleration at different points, eg. (and these aren't actual figures, just random figures) a class 156 might accelerate from 0 to 45 faster than a 400hp 158, but the 158 might accelerate faster from 45 to 75. Therefore, what you've posted, though useful, isn't quite what I was after.
Sorry, they are the only figures I know, and I'm not 100% on all of them either.
I agree with you that 170s are useless, something with no acceleration and commuter doors isn't even a Jack of all trades, it just seems to be there, poorly doing it's job that many other units could do alot better. They do have nice seats though.
Adam![]()
All 'Pacer' units especially the 141s.
Is it the case that they were hobbled to make them compatible with older units?
Adam![]()
Almost certainly not. They were probably designed to be as powerful as it was thought the transmission could cope with.
Funny, I thought I read that the 170 ended up significantly under-powered as a result of making it Sprinter compatible. Hmm.
I hope that someone with more knowledge comments on this, but that may have been a track-force limit to make sure that it was compliant with SP speed restrictions. In other words, the engine had to be kept small to keep the weight down.
This is why, to meet SP restriction they are weight limited so engines and gearboxes are not ideal.
Thanks.)There's "should be Intercity but isn't" (TPX, Norwich-Liverpool, the Scottish expresses and actually Waterloo-Weymouth/Exeter) for which I would use a 170 - or preferably a 175 (or a 442 obviously).
So you think these routes should be intercity, but would prefer to use outer suburban DMUs on them? Other than the Scottish routes I think the 158s are perfectly suited to these kinds of services.
I would prefer to use 100 mph DMUs on them, no matter what their acceleration capability, it's more about top speed cruising and smooth ride than acceleration. When it comes right down to it, I'd prefer to use 67s and MkIIs, but we don't have anywhere near enough. That's why I mentioned the 175s, although there are nowhere near enough of them either and I'm none too sure of their reliability. Having the doors in the wrong place surely cannot be that big a fault, especially when the same is true of the 185s.
Class 175s are the perfect compromise between 158s and 170s. They have the door arrangement and acceleration of the 158s, and the top speed of the 170s. They are the best 100mph DMUs in service today, and it is a real shame there are not more of them.
Adam![]()
The big problem with 175s is the lack of inter-unit corridor connections. Portion working is a major advantage of 158s. Still, a damn sight more suitable for TransPennineExpress than a 185 with its outer-suburban doors I would have thought.Class 175s are the perfect compromise between 158s and 170s. They have the door arrangement and acceleration of the 158s, and the top speed of the 170s. They are the best 100mph DMUs in service today, and it is a real shame there are not more of them.
Now, a OHLE version of a 5-WES/444 would probablly be nice to see on TPE when it is electrified.
5-DEX? Really? I've never heard that before. What are 450s? 4-DES?
Nope, I meant something like either a class 444 or a 5-WES (Wessex Electric). They both seem kinda similar. I haven't been on either recently enough to say which I prefer, so I just suggest both. The 5-WES is better looking in general though.Provided it's made more comfortable inside, I agree with that. I take it you mean 5-DEX/444.
444s I think have a pantograph well, yes. I don't think 5-WESes do though.They were in fact designed for that in the first place, i believe, hence why they have a pantograph well. I think they were all designed as dual voltage, so it really needn't mean any significant redesign work. Although I don't know if they might insist on those ugly front ends like on 380s on account of EU Regulations.
