Least Delay When Stops Are Missed Out
dmacw
4 Jul 2009
Just passed through Reading and heard the 16.48 to Bedwyn would be missing out Theale, Aldermaston and Thatcham. It was on the board as running 9 minutes late. (For reasons unknown it actually left 19 minutes late)
My question is, what's the least delay you've known of, when stops have been missed out, or a train terminating early?
9 minutes seems quite low to me.
tsr
15 Nov 2011
Between the parallel lines
Redhill was once missed out of a London Victoria > Bognor Regis and Somewhere Else service due to a 3 minute delay.
Actually, I think that's happened more than once.
Robinson
1 Aug 2010
Helensburgh
Although in the case of Redhill you'd've been sent down the avoiding line rather than just speeding through the platform.
As has happened to me twice on Southampton-London Victoria services, after being delayed in the Arun valley...
MidnightFlyer
16 May 2010
5 minutes for Southeastern, I've seen it happen at 2 though.
https://twitter.com/Se_Railway/status/265502920395603968
If you read the second half of that Tweet (https://twitter.com/Se_Railway/status/265502921741975552) it actually was in effect cancelled for the second half of its working (back to London via Sidcup), so not cut stops, indeed just a train terminating short. I would assume it ran back to Slade Green depot for any attention required afterwards.
northwichcat
23 Jan 2009
Northwich
The missed calls aren't always down to the length of the delay though.
One day an ATW 175 had terminated off an ex-Llandudno service at Manchester Piccadilly. When the driver switched ends he found there was a fault in the other driving cab, so the train was sent to platform 12 and formed a 'Llandudno' service running non-stop via Stockport. (Although I imagine there would have been a unit swap at Chester.)
The train ran late but the late running was not the reason for the missed calls.
Captain Chaos
31 Jan 2011
I was on the 16:48 to Bedwyn travelling home. The reason for the delay was that the 16:41 to Swansea had broken down in front of the Bedwyn on Platform 7 leaving the Bedwyn trapped. The Swansea service had a WSP fault and required a rotational test before continuing.
The Bedwyn left at 17:02, which is why it was run fast to Newbury, as the 17:04 to Exeter and the 17:12 stopper would have been both behind it. Running it fast minimised any further knock-on delays. The service waited in the platform at Newbury for the Exeter to arrive to maintain it's connection to Bedwyn.
Oh, and on the subject of lowest delay minutes. I was on a Redhill stopper once that was on-time. It was run fast calling Guildford and Reading. There was a major problem around Reading at the time and the driver was required back at Reading ASAP for another service.
12CSVT
18 Aug 2010
An FCC Sutton service missing out stops south of Blackfriars when it was 0 minutes late (ie on time). It had also missed out stops between St Albans and St Pancras. Obviously a stop order had been issued at Luton or St. Albans.
And I've seen that happen on more than one occasion.
