Learning to touch type
amateur
23 Feb 2014
Hi,
Can anyone recommend me the best resource, tool or recommend a book in order to learn to touch type effectively/quickly!
I know it requires a lot of practice... But something to guide me/ self teach would be greatly appreciated.
Regards,
Amateur
Abpj17
5 Jul 2014
Bizarrely, I learnt somehow learnt to touch type on a French keyboard while living there for a year (and then spent several years using a French keyboard at home and an English keyboard at uni/work and managed to touchtype on both with just a few errors until my brain realised which keyboard layout I was using!) As it's largely, the punctuation and numbers that are different, the only keys I will still occassionally look at now are punctuation ones to double check I've got the right one.
I had tried a few touch typing things in the years leading up to that (Mavis Beacon!), but what really did it was simply just typing a lot. Outside of formal courses, the key/basic tips would be (and are more practical than just hitting the letters!):
- remember to use most of your fingers and keep them to their own half of the key board
- use real, diverse text - not the same sentence / source over and over again
- your eyes should be on the screen - or your source document. How you learn probably depends on why you want to learn to type - if it's for your own stuff - then just have text on the screen and duplicate it by typing. If you need to type quickly to transcribe, then you ought to build in practice from audio sources. (And similarly if you'll be mainly typing up notes)
- work out what to do about numbers. For years (and because on a French keyboard the accents are on the number keys along the top), I used the number pad on the right hand side for numbers (was doing math degree so numbers came up a lot!). I had to re-learn all of that when starting to use a laptop at home which didn't have numbers in a block on the right.
- think carefully about the type of keyboard - will you need to type on various (laptop, desktop); do you prefer a particular type - e.g. the ergonomic split ones, do you want responsive / clicking keys? (my preference is for relatively soft keys that you don't really need to press all the way down - the keyboard on a macbook is pretty much perfect for me)
- will you be typing text you're familiar with (if you know all the spellings etc. it is a lot quicker) or is it potentially relatively technical (e.g. medical typists tend to need to know how to spell lots of complicated words)
- how much do you care about errors e.g. do you care about getting typing right first time vs. do you have time to make a few mistakes - will you correct them along the way / will there be proof-reading at the end etc.
While this isn't the text book stuff, it does make a significant different to how comfortable typing is and how quickly you'll type.
(I would add that I'm far from textbook perfect, but I can type consistently (and think) at over 60 wpm without looking at the keys)
CarltonA
22 Apr 2012
Thames Valley
I learned on a typewriter with blank keys originally. I had a diagram of the keys above me on the wall. On a computer you can place your source material over the screen and check what you have typed afterwards. It is important to place your fingers on the "home keys" asdf and jkl;. Notice that on most keyboards there are raised parts on the f and j. This is so you can align your fingers without looking at the keys. Use a thumb to operate the space bar. Start with a few slow repetitions of "The quick brown fox jumps over the lazy dog" then when you have gained confidence copy from exercise material.
EM2
16 Nov 2008
The home of the concrete cow
Get the latest edition of the Mavis Beacon Teaches Typing CD-ROM (or DVD). I used to work in an educational supplies store, and we sold boxes and boxes of this. I've never heard a negative word said against it.
GaryMcEwan
20 Aug 2013
Bridgeton, Glasgow
Definitely agree with Mavis Beacon, I used it at High School which is over 14 years ago and it certainly helped me out.
amateur
23 Feb 2014
Thanks. I'm assuming that would be version 20 then? Quick glance on amazon!
Would it be suitable for complete beginners?
Just practice worked for me. No special tools.
Any useful books or websites?
Have a go at this: http://10fastfingers.com/typing-test/english
I only count a result with no wrong words as otherwise you'd need to add extra time to fix them! (you can fix errors with backspace, but make sure to press backspace before pressing space!)
I have done it just now and got 81wpm, but that's because it's late :P If I put my mind to it and really concentrate I can get up to 94. See: Words per minute test?
Butts
16 Jan 2011
Stirlingshire
You'd be ok in the typing pool - remember them ? :p - can you do shorthand as well !!!
Unfortunately my luddite tendencies leave me as a "two finger specialist" not sure about words per minute - more per hour :lol:
That website will calculate it for you ;)
Just make sure that, if the word goes red denoting an error, you press backspace and correct it before pressing space to go onto the next word.
Butts
16 Jan 2011
Stirlingshire
Sorry that's far to technical for me :oops:
