LittleRedTrain
Was just checking out tickets for a trip in a couple of weeks, and was very surprised to find that my proposed Leamington Spa-Crewe via Nuneaton trip required two tickets, despite it being a seemingly obvious route, in the right direction, with only a single easy change..
Looking at the Routeing Guide, both are Routeing Points and the only permitted route is via Map RJ, which includes both Nuneaton and Coventry, but not the line between them.
(Screenshot of map RJ - Crewe at top left, Leamington Spa at bottom right)
On the other hand, if I wanted to go Leamington-Stafford, there is a permitted route via Nuneaton (maps BB+TL).
Does anyone know if there's any weird/historical quirk as to why this obvious route is not allowed and you're forced to go through Birmingham? Did someone not update these maps when the service via Bedworth was extended from Coventry to Leamington Spa?
Is there any process by which the powers that be could be gently nudged into reviewing it?
Obviously as a power user, I can easily get around this issue by splitting at Stafford, but those not in the know would easily get caught out and end up having to pay more. (NRE will quite happily suggest a Leamington-Crewe via Nuneaton itinerary without needing to explicitly state it as a Via point).
