Quenfight
What's the largest domestic (excluding le shuttle locos) locomotive, either diesel or electric that has operated in the UK, in terms of general size?
In fairness, the OP did specify diesel or electric locomotives.As far as I can see the LMS Garratts were the longest, although only 7 1/2“ longer than the LNER U1, a difference that could be accounted for by buffer type. The U1 were significantly heavier.
Source: Wikipedia, so not guaranteed.
In fairness, the OP did specify diesel or electric locomotives.![]()
Though EE Type 4s were longer than BR Type 4s.46s were probably heaviest at 141 tons.
Both EE type 4s, those being 40s and 50s were longer than 44/45/46s.Though EE Type 4s were longer than BR Type 4s.
I only have the imperial measurements: EE Type 4s were 69'6" over buffers compared with 67'11" for BR Type 4s.
Is that this thing...? I'm fairly sure the high axle loading was a deliberate feature in order to assist with tractive effort while shunting around the quarries?Neither on length nor weight, but on height and width then maybe the EMD SW1001s bought 1 each by (then) Foster Yeoman and Hanson for the Mendips quarries rank here somewhere.
OP did not exclude non BR / main line locos.
I can't yet locate dimensions of the precise SW1001 model but is updated version of SW1000 :
Key data for this thread :
15 ft 0 in high
10 ft 3 in wide
Way bigger than GB main line loading gauge.
Also ~25.5 ton each axle - even Derby at it's most inept did not produce something that heavy.
Metric is 21.18m and 20.70mThough EE Type 4s were longer than BR Type 4s.
Yes, even the 'low clearance' (by US standards) SW1001 is 18" taller than a cl. 08IIRC one of those EMDs tried to escape the confines of its quarry and go for a jaunt towards the main line. It had a coming together with the first overbridge, resulting in some restyling of the cab.
USA locos commonly have substantial axle loads to increase tractive effort. Not necessarily basic design as they are typically ballasted up to the desired weight with concrete blocks or even scrap steel. This varies by order, the locos in the UK would have had whatever ballasting was desired, possibly none - locos for USA lines with weight restrictions could be delivered like this.Also ~25.5 ton each axle - even Derby at it's most inept did not produce something that heavy.
It's not better than a 59 - that figure is the maximum tractive effort for a class 13, and the equivalent for a 59 is 114,000lbf (506kN). Are you comparing maximum TE for the 13 with continuous TE for the 59?I did wonder where the class 13s fitted into this.
60'1" (18.31 metres)
120 tons (122 tonnes)
So certainly very big considering their modest power output (just 700hp)
But tractive effort was their thing, 70,000lbf (better than a class 59)
I think I might be - the figure I found for class 13 didn't specify whether it was MTE or CTE. In their case I doubt there was a huge difference, given the job they were designed for.It's not better than a 59 - that figure is the maximum tractive effort for a class 13, and the equivalent for a 59 is 114,000lbf (506kN). Are you comparing maximum TE for the 13 with continuous TE for the 59?
CSX ordered (or modified) some of their AC traction locos with an additional approx 9 tonnes of weight for additional tractive effort - they also subsequently got HTE (High Tractive Effort) software upgrades to improve tractive effort even more.USA locos commonly have substantial axle loads to increase tractive effort. Not necessarily basic design as they are typically ballasted up to the desired weight with concrete blocks or even scrap steel. This varies by order, the locos in the UK would have had whatever ballasting was desired, possibly none - locos for USA lines with weight restrictions could be delivered like this.
I rather think my facetious remark has by passed most of you .USA locos commonly have substantial axle loads to increase tractive effort. Not necessarily basic design as they are typically ballasted up to the desired weight with concrete blocks or even scrap steel. This varies by order, the locos in the UK would have had whatever ballasting was desired, possibly none - locos for USA lines with weight restrictions could be delivered like this.
Lesser known still than these GM switchers, but not dissimilar in appearance and likely weight, were five older Alco S1 switchers of USA style, bought by Port Talbot steelworks in 1949 and run inside the works until the 1980s. As they had UK buffers added outside the USA centre couplers they were probably even heavier than the standard Alco S1 +data sheets would suggest. Picture here:
ALCO Locomotives - IRPS Night Mail
The Night Mail Project and International Railway Preservation Society are dedicated to preserving the Wagons-Lits, postal and Continental Rail vehicles both on the Nene Valley Railway and abroad.www.irps-wl.org.uk
I think it was a fairly straightforward comment; the weight of an initial 2,300hp Peak at I think 133 tons and requiring a 1Co-Co1 set of bogies contrasted with a Swindon Warship at 80 tons and half the number of wheels for much the same power.I rather think my facetious remark has by passed most of you .
I was not commenting on general weight of US traction but overweight of certain machinery from the Derby design school .
and all-wheel drive. The Peaks and 40s couldn't even use all that weight for tractive adhesionI think it was a fairly straightforward comment; the weight of an initial 2,300hp Peak at I think 133 tons and requiring a 1Co-Co1 set of bogies contrasted with a Swindon Warship at 80 tons and half the number of wheels for much the same power.
133 tons according to Wikipedia, slightly less than any Peak, but on only six axles so the axle weight was over specification.I seem to remember reading that 'Kestrel' was too heavy to run as built. It had to be placed on a pair of Class 47 bogies to get it's weight down. No idea how heavy it was originally, or it's axle-load.
Pat
but was that with the original Kestrel bogies, or with the replacement class 47 ones, which were lighter?133 tons according to Wikipedia, slightly less than any Peak, but on only six axles so the axle weight was over specification.
The original onesbut was that with the original Kestrel bogies, or with the replacement class 47 ones, which were lighter?
Anyone got a figure for the weight of 10203?
I would have thought that would be heavier than a 40
Part of the issue was need for heavy locos due to widely used unfitted freights so wasn't much incentive to reduce weight considerably.and all-wheel drive. The Peaks and 40s couldn't even use all that weight for tractive adhesion
