A
landslip between Purley and Gatwick Airport via Redhill means that all lines are disrupted. Trains running between these stations may be cancelled, or diverted between Purley and Salfords. As a result, trains will not call at Coulsdon South or Merstham, Earlswood.
Disruption is expected until the end of the day.
Customer Advice
If you are travelling on routes between Purley and Gatwick Airport via Redhill, you will need to use an alternative route and it will take you up to 30 minutes longer than usual to reach your destination.
Gatwick Express services:
Fewer trains than usual will run, roughly 1 train per hour in either direction.
Thameslink services between:
- Peterborough and Horsham
- Bedford and Three Bridges
These trains will run via alternative lines and will not call at Coulsdon South or Merstham, Earlswood.
Southern services between:
- London Victoria and Reigate
- Redhill and Gatwick Airport
These services will not run until further notice.
- London Victoria and Littlehampton
- London Victoria and Eastbourne
Fewer of these trains will run, roughly 1 per hour in each direction.
