Lack of train running info H&C/Circle
ess
9 Feb 2010
Why is there no info on the passenger displays at Paddington and some other stations for trains? Great Portland Street has perfect info so why not Paddington?
rebmcr
15 Nov 2011
St Neots
Paddington is near the current edge of the new signalling, and not far from the complex junctions at Edgware Road. It's going to be difficult to accurately track trains transitioning that area.
Domh245
6 Apr 2013
nowhere
From memory, the Hammersmith branch (until the new signalling goes live) doesn't actually have any form of live train tracking information on it
ess
9 Feb 2010
Some stations on the branch do - maybe it’s done manually. When is the signalling planned to be updated?
Domh245
6 Apr 2013
nowhere
Very soon, the first phase (Hammesmith - Latimer Road) should be live by the end of the summer, and then the last section of the branch to Edgware Road by mid Autumn.
bluegoblin7
10 May 2011
JB
First of all it's important to clarify which Paddington we are talking about: from subsequent replies I will assume Paddington (Suburban), but it could easily be Paddington (Circle). For ease, I will deal with the latter first.
This station does have passenger information screens (one on each platform) and they do work - fairly accurately - with the legacy signalling system. Whilst this area is a hole for realtime running information, it is covered by the 'Train Description' (TD) system which is set up from Edgware Road on the Inner Rail and Earl's Court on the Outer Rail. The TDs transmit generally without issue, and the running times are usually accurate - or as accurate as you can be with a 'distance' based system rather than real time running. Because the TD is an inherent part of the signalling system for automatic junction working at High Street Kensington (and to allow the Service Operator to know where to route the train at Edgware Road) it also means that the destination displayed is generally correct too (there's some exceptions, largely due to the fact that not every destination has an available TD!). Exact train location cannot be determined, but it is possible to get a vague idea using data from the Connect radio system (more on this below...).
Paddington (Suburban) and the rest of the Hammersmith branch is a little bit more complex. No TD system is in place west of Edgware Road (the Service Operator in the Cabin will set up and send them, but they never get received...), so trains are running 'blind'. As such, there's also nothing to drive passenger information screens from the signalling side of things, so it's difficult to know both where a train is headed (on the eastbound, at least!) and how far away it is.
At least, historically that has been the case. In preparation for 4LM (Four Lines Modernisation, the collective name for the upgrade of the sub-surface lines) new passenger information screens have been provided at all stations on the branch (including Paddington [Suburban]) and these have been slowly brought into use over the last year or so. The data is powered by a clever combination of the timetable and the Connect Radio system - every station has a radio cell, and every train is uniquely identified. The system knows roughly where the train is in accordance to the station, and combined with the timetable data it can marry the two together to provide a vaguely accurate countdown and destination. It isn't infallible and trains will often appear twice, or remain after departure, but it's an improvement over what existed before. If no data is being received then the screens will just display the direction of travel and 'Hammersmith & City line'. At Hammersmith there is a 'Next Train Indicator' which is manually controlled by the Service Operator from the Signal Cabin.
As mentioned, all of this will drastically change over the next month. It is anticipated that the first part of the new CBTC signalling will be switched in at close of traffic on 26th May, with Hammersmith (OZ) cabin closing and Automatic Train Control coming into use between Hammersmith and Latimer Road - SMA 0.5. With it will come realtime train information between those stations (inclusive), albeit limited as it will still be relying on legacy feeds east of Latimer Road. Eventually the information will be on a par (at minimum) with the other ATO lines (in particular the Jubilee and Northern lines). Resignalling should extend to Paddington (Suburban) (SMA 1) by the end of June - and by extension realtime information - with the Edgware Road and Baker Street areas (SMA 2) by the end of the year.
For the avoidance of doubt, installation of signalling equipment is broadly complete as far as Euston Square/Finchley Road/Paddington Circle (SMA 0.5-2), and operating passively to gather data. It is not providing any active control functions at this time, with all of the legacy systems remaining in place. Where improvements have been made these are separate, interim improvements and not part of the new control system.
And, finally: Edgware Road does not have a complex junction. One day the myth that Praed Street Junction is hard to operate will dissipate: it's very much the easiest part of Edgware Road (OP) signal cabin.
bluegoblin7
10 May 2011
JB
As a point of clarification, Hammersmith cabin has no TD functionality at all, so cannot send trains eastbound with a description in place. Until the trains drop onto the diagram at Edgware Road, there is no accurate way of knowing where they are (the same is also true on the west) and nor where they are going: the Service Operator at Edgware Road will set up a TD for the train before it departs towards Baker Street (or reverse via the centre roads). From there that data is then transmitted along the line to all points east thereof, but can be altered at certain points if required - be that because it's got out of step or the train's destination has changed. For a very early and basic system it's still very reliable and durable, although it does lack certain destination codes now required - for instance, a number of C+H trains now stable at Upminster depot at the close of traffic. The furthest eastbound TDs possible are 'BS' for Barking sidings and 'B' for Barking bay road. They will depart Edgware Road as a 'B' and will then be corrected further along the line where further codes are available (I believe it happens at Baker Street, but it could be as late as Whitechapel). There are other anomalies, or codes that have been repurposed (for example, WH was original Whitechapel but is now West Ham, and Barbican's TD has been repurposed to a Circle line to Edgware Road, rather than a circular Circle). But that's getting a bit off topic for the exact discussion now, and provided mainly as an interesting aside...
Domh245
6 Apr 2013
nowhere
Does the honour of "hardest part of Edgware Road signal cabin" to operate fall to the Kettle? :P
rebmcr
15 Nov 2011
St Neots
While it might be "easy" from a signalling perspective, it's not exactly straightforward from an operational perspective, right? Compared to, say, plain line or a grade-separated branch.
bluegoblin7
10 May 2011
JB
I am speaking from an operational perspective, considering I'll be operating at through tonight's evening peak.
GodAtum
11 Dec 2009
I've waited over 10 minutes at Paddington circle line with no announcements and a blank CIS.
