Kirknewton Level Crossing Question.
MrBurnz
9 Oct 2017
First off, apologies if this is in the wrong post category, I am posting this here because I have a question regarding Kirknewton level crossing.
Today, at 14:57pm, I was driving my lorry towards the level crossing, from the Kirknewton side.
As I approached the crossing, the barriers were up & the lights were not flashing, so I proceeded to go over the crossing as normal.
However, as I got onto the crossing, there was a train sitting at the station on the west bound (Glasgow) line. The train was stationary at the platform, with its lights on.
This is what caught my attention as I drove over the crossing (the illuminated headlights from the train)
Now, there was absolutely no red flashing warning lights for the crossing on & the barrier’s were up as if the crossing was clear.
I don’t know if there was an issue with the barrier’s/warning lights, but I got a fright because I wasn’t expecting to see a train as the crossing was open.
I was not the only vehicle who was crossing the level crossing either.
My question is, (& I think it’s obvious that the answer will be yes), should the barriers have been closed & lights be on, because of the train at the platform?
It was strange & it did give me a bit of a fright, as the Kirknewton line is used by fast/slow & freight trains.
If this is not appropriate or in the wrong post category , admins please feel free to delete or move this post.
pokemonsuper9
20 Dec 2022
Greater Manchester
Looks like the train (seemingly https://www.realtimetrains.co.uk/service/gb-nr:W59132/2023-12-14/detailed#allox_id=0) didn't spend an abnormal time sat in the platform.
Is it not reasonable to allow a passenger train to sit in the platform (with a red signal) while the barriers are open?
Gloster
4 Sep 2020
Up the creek
Looking at streetview, there appears to be a signal at the west end of the platform, so as long as it is showing a red aspect it is quite safe.
louis97
14 May 2008
Derby
Crossing is lowered by the driver of stopping trains there using a plunger on the platform.
irp
14 Aug 2023
Cov, UK
Assuming there was a danger (red) aspect being shown to the Train, protecting the level crossing, I don't see an issue here. Train would not be permitted to move off until the doors were closed and barriers had been lowered anyway
1955LR
11 Dec 2019
Hereford
Same as Bucknall (BUK) Heart of Wales line / Station next to level crossing . Trains to Shrewsbury stop at station platform and cannot proceed over the crossing until white light showing . During this time traffic continues over the level crossing. Crew have to operate the crossing by getting out onto the platform and operating a plunger needing a key to access, road traffic stops at barriers and train proceeds. In the opposite direction the train operates the crossing on approach and when it clears to the platform ,Barriers raise. It can be disconcerting driving as due to the road layout, you turn across the front of the train if the barriers still up.
MrBurnz
9 Oct 2017
I thought Kirknewton was an automatic operation crossing, I never knew about the plunger operation by the driver however.
Interesting.
scotraildriver
15 Jun 2009
Stopping services require the driver to press the plunger to activate the crossing. Otherwise the barriers would be down for a long time whilst the train is at the station. Non stop services will be signalled straight through.
Meerkat
14 Jul 2018
I can see how you would get a fright at night though, if you don't see the train until you are on the crossing and see the train headlights!
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Indeed. There have been occasions when a motorist phoned the Police to report this 'dangerous situation', the Police then contacted the railway but understood when the operation of the crossing was explained.
Pakenhamtrain
26 Jan 2014
Melbourne, Australia
We have a level crossing at Pakenham where every so often someone would get a fright at a train sitting at the signal with the booms up.
Its quite common on our crossings where a signal exists at the end of the platform the signal will stay red until the crossing booms are horizontal. The crossing activates while the train is pulling into the platform.
ruaival
25 Jan 2020
New Mills, Derbyshire
If I read the above discussion thread correctly ... in the event of a stopping train failing to stop at the Red signal/ in the platform and continuing as far as the road, it would cross that with the barriers raised and no lights flashing?
Tester
5 Jul 2020
Watford
The crossing close sequence would start as soon as the train passed the signal (keeping it simple), but it is highly likely that it would not be completed.
One of the many reasons why signals passed at danger are a big deal!
norbitonflyer
24 Mar 2020
SW London
Well, yes. Nasty things do tend to happen if trains pass any red signal. That's why train drivers have to stop at them.
Surreytraveller
21 Oct 2009
A train is supposed to have white lights on the front and red lights on the rear. They do not get switched off just because its stationary.
Although the working of this crossing has been explained, a train may also be at a station with the barriers raised because its waiting time, there may be a train in the section ahead, it may be terminating to go back the other way or there may be a signalling failure.
Perfectly safe and normal.
If a train should fail to stop at the red signal, there wig-wags (red flashing road lights) would activate.
Mcr Warrior
8 Jan 2009
Believe the Glasgow bound train which the OP saw yesterday was already running some 6 or 7 minutes down at Kirknewton having departed late from Edinburgh Waverley.
Would I be right in saying that Kirknewton is one of the few stations in Central Scotland without an overbridge?
SouthSub
16 Oct 2015
It’s the same situation at Kingsknowe, further east on the same line. Again there is a signal at the west end of the platform, which remains red until the button is pressed in advance of the train departing.
Falcon1200
14 Jun 2021
Unless the train and/or Driver had somehow failed or been unable to respond to the cautionary signal aspects preceding the red at Kirknewton the train would be moving slowly and would be stopped by a TPWS activation.
ComUtoR
13 Dec 2013
Assuming you mean by train stop loops at the signal ?
DelW
15 Jan 2015
There are several examples further south on the Heart of Wales line as well, notably Llandovery where the A40 crosses the end of the platforms, but also Llangadog, Ffairfach, Llandybie and Ammanford. Stations were built next to road crossings, and level crossings were cheaper to build than bridges.
driver9000
13 Jan 2008
Good point. I don't have the means of checking whether Kirknewton is so fitted, although I would have thought that (in the Up direction at least) there would be a good case for it.
The Up direction signal at Kirknewton has a Trainstop fitted.
TriumphRat
1 Sep 2021
Edinburgh
The platform starter signal on the up line at Kirknewton has both stop loops at the signal and overspeed loops on approach.
I sign that route and from a train driver's perspective it's also quite surreal drawing into the station with road traffic crossing just a few meters ahead of you.
15 May 2023
Minster
Most accidents involving level crossings are due to impatient people trying to beat the barriers. I think there is a similar crossing near me in yalding. If the train is stopping then the crossing remains open.
Makes sense to not hold up traffic if the train is sitting in the station.
As for mishaps, the driver has extensive knowledge of the route he's driving and should know how to stop the train in the station, also will know about slippery conditions etc and compensate accordingly.
Besides if there's a stop signal at the end of the platform will have fair warning they need to stop up ahead.
I believe network rail are trying to phase out level crossings in the near future anyway.
Not far from me there's still a manually operated crossing with the old hand pump!
GB
16 Nov 2008
Somewhere
There is a little thing called "human error".
