Engineering tomorrow has VTEC trains calling at Stevenage (not denoted as set down/pick up only). If i have a boundary zone 6 - huntingdon (annual gold card), can i use vtec to stevenage to change for the stevenage-peterborough shuttle service?
I believe a gold card discounted ticket isn't valid on VTEC services, if you will get checked by a guard in the shortish distance from Kings Cross to Stevenage is another thing
Do you have any evidence to prove this?
Just an ordinary 1-6 Travelcard.What ticket are using to get to the boundary of Zone 6?
If the conditions are still bad then they might cancel the engineering work, but I doubt they would just based on disruption. Long possessions come around so infrequently that NR are loathe to give them up if it can be avoided. Plus the TOCs would probably struggle to run a near-normal service at relatively short notice.Given conditions and disruption I wouldn't be surprised if the engineering was cancelled tomorrow in particular to cater for those deferring travel from today.
THe chance of a ticket inspection on VTEC between Kings Cross and Stevenage is small, in my experience.
Looks academic now, seeing as im probably just going to stay home cos of the weather and all around crazyiness that will be going on tomorrow. Sorry to waste everyones time If the conditions are still bad then they might cancel the engineering work, but I doubt they would just based on disruption.
Engineering work is cancelled.I have a feeling they did in fact cancel the engineering works today. Although services were still running to the amended timetables, northbound GN services from King's Cross were arriving around 7 minutes early into Stevenage and waiting until the amended departure times. RTT also shows no reports for services from Alexandra Palace until Langley Junction, so it figures they were running on the main line rather than via the Hertford loop.
