Kings Cross-Waterloo- flatest connection?
jopsuk
13 May 2008
There's many routes between Kings Cross and Waterloo. Which one has the least stairs/escalators at the connection point (discarding the loony route of circle+jubilee)? I know it isn't Green park, having made that mistake once, but I've forgotten where the best connection point is...
jon0844
1 Feb 2009
I'd say Victoria to Oxford Circus, then cross over to the Bakerloo.
5 Feb 2009
Milton Keynes
well if you want the flattest route there is a bus (59) that goes to waterloo from kings cross (stop R) it is every 12 minutes and takes 35 mins to get to waterloo, but because it is a bus it will probably take a week but all busses in london are low floor so you won't have to worry about stairs/escalators, but for the quickest route you want the victoria line, then the bakerloo which unfortunately has some stairs/escalators/lifts to contend with but only lasts up to 15 mins
Daniel
5 Oct 2005
(other than by bus), it is indeed the Victoria to Oxford Circus then the Bakerloo to Waterloo :)
williamn
22 May 2008
I'm always surprised there isnt a more regular bus service between these two major stations.
williamn
22 May 2008
yeah, exactly, I don't call that frequent between two such big stations! Its also VERY unreliable.
On weekdays, King's Cross mainline > Finsbury Park > Highbury & Islington > Oxford Circus > Victoria. The only stairs will be at Victoria itself. That is, if you don't mind the double-backing to Finsbury Park! ;)
If you don't mind negotiating King's Cross tube station then the quickest journey is to change at Oxford Circus. Stairs at KGX and VIC can't really be sensibly avoided.
jon0844
1 Feb 2009
You'll need to use the stairs to go from platform 4, 5 or 6 over to 1 to get back to Highbury & Islington and on to the Victoria Line - although not as many as walking down to the tube there.
Unless I'm missing something?
The bus option is never a good choice, as the traffic always messes things up. It's only an option if you really don't want any fuss with steps/walking, and time isn't a major factor. Then I guess it's perfect!
